    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 79.6k Views 69 Watching
    • U Offline
      unclex
      It's really nice!!!!!!!!
      But unfortunately, I can only drug out the Purple Grid, cannot double clicked and continued, just showing
      Bezier Surface Updating.....
      win8.1x64 @SU2015x64 & SU2013, both happened
      Should be there any bugs with others plugins?
        Can you share example model or screenshot?
        Any errors in the Ruby Console?
        • jeff hammondJ Offline
          what the? this thing is cool 👍
          a question..
          is there a way to control the segmentation yet? like, max angle = 5º (or whatever) and anything steeper will break down to two (or more) segments until the maximum mesh angle has been achieved?
            @jeff
            type subdivisions in the VCB
              @rich o brien said:
              @jeff
              got it. thanks
                Ur more than welcome.
                I imagine you'll get lots of mileage outta this?
                  probably.. for me, it seems great to quickly mess around with new shape ideas.. like clay in a way..
                  [edit]
                  it's the controller (widget, gumball, whatshername) that makes it so fast.
                    The song from Ghost is in my head now.
                    • pbacotP Offline
                      There's a procrastinators beware message... Hand it over!
                      Glad it's available in the SCF pluginstore.
                        lucky for me i'm on a super crappy connection right now so i can't be arsed to youtube the scene.
                          At least! ☀
                          Brilliant! 😎
                          Works on the 2014?
                          Seems not! 😞
                          Impossible to valide the second point of the patch!
                          I have the last TT_lib2
                          Error: #<NoMethodError: undefined method parent' for nil:NilClass> C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ChrisP_PutsCompOnFace.rb:21:in definition'
                          C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/instance.rb:23:in definition' C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:1129:in update_mesh'
                          C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:159:in update' C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/tool_create_patch.rb:142:in onLButtonUp'
                            Seems in 2014 no compatibility with SketchyPhysics 3, Scalp
                            Patch is drawn with the grid
                            but now i have just the menu one time on the right Click
                            then no possibility to edit the patch! 😉
                            Just this on the Ruby Console
                            nextFrame()->updateMainWnd()
                            • BoxB Offline
                              What an outstandingly wonderful tool.
                              http://i155.photobucket.com/albums/s296/storeben/genie.gif
                                For any reason after relaunch SU that works! 😒 😎
                                Waiting the manual for translate it in French! ☀
                                  AcesHigh
                                  how come I totally missed this plugin for 4 years? It should be on the list of essential plugins!
                                  • cottyC Offline
                                    cotty
                                    Maybe because Thomthom published it yesterday 😉
                                    my SketchUp gallery
                                    • PixeroP Offline
                                      Pixero
                                      Thanks, will come in handy for all those soft surfaces.
                                      • jolranJ Offline
                                        jolran
                                        This is so cool!
                                        I'm not gonna get any work done now playing with this 😄
                                        How do you add Tripatch to Qaudpatch ? Possible ?
                                        • jolranJ Offline
                                          jolran
                                          Some really nice editing capabilities there, with the Gizmo and all. WOW! 😲
                                          So you decided to release it non commersial, huh ?
                                          For some time now I have been working on curves and surfaces for my node editor, maybe
                                          I can try making it compatible with you patches as well, now that your code is in public...
                                          That would be cool to use your tools after baking down geometry..
                                          Do you use Knotvectors for the patches ? Or are they interval-based type powerbasis functions ?
                                          Edit: Ah right, they are not spline-based, (duh). So you go through the C-extensioncode right ?
                                          • BoxB Offline
                                            Select the edges you want to add to then click add patch and it will follow the shape.
                                            http://i155.photobucket.com/albums/s296/storeben/SU/Adding.gif
                                            • 12
                                            • 13
                                            • 7 / 13
