    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 107.6k Views 69 Watching
      The song from Ghost is in my head now.
      • pbacotP
        There's a procrastinators beware message... Hand it over!
        Glad it's available in the SCF pluginstore.
        • jeff hammondJ
          lucky for me i'm on a super crappy connection right now so i can't be arsed to youtube the scene.
            At least! β˜€
            Brilliant! 😎
            Works on the 2014?
            Seems not! 😞
            Impossible to valide the second point of the patch!
            I have the last TT_lib2
            Error: #<NoMethodError: undefined method parent' for nil:NilClass> C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ChrisP_PutsCompOnFace.rb:21:in definition'
            C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/instance.rb:23:in definition' C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:1129:in update_mesh'
            C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:159:in update' C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/tool_create_patch.rb:142:in onLButtonUp'
              Seems in 2014 no compatibility with SketchyPhysics 3, Scalp
              Patch is drawn with the grid
              but now i have just the menu one time on the right Click
              then no possibility to edit the patch! πŸ˜‰
              Just this on the Ruby Console
              nextFrame()->updateMainWnd()
              • BoxB
                What an outstandingly wonderful tool.
                http://i155.photobucket.com/albums/s296/storeben/genie.gif
                  For any reason after relaunch SU that works! πŸ˜’ 😎
                  Waiting the manual for translate it in French! β˜€
                    AcesHigh
                    how come I totally missed this plugin for 4 years? It should be on the list of essential plugins!
                    • cottyC
                      cotty
                      Maybe because Thomthom published it yesterday πŸ˜‰
                      my SketchUp gallery
                      • PixeroP
                        Pixero
                        Thanks, will come in handy for all those soft surfaces.
                        • jolranJ
                          jolran
                          This is so cool!
                          I'm not gonna get any work done now playing with this πŸ˜„
                          How do you add Tripatch to Qaudpatch ? Possible ?
                          • jolranJ
                            jolran
                            Some really nice editing capabilities there, with the Gizmo and all. WOW! 😲
                            So you decided to release it non commersial, huh ?
                            For some time now I have been working on curves and surfaces for my node editor, maybe
                            I can try making it compatible with you patches as well, now that your code is in public...
                            That would be cool to use your tools after baking down geometry..
                            Do you use Knotvectors for the patches ? Or are they interval-based type powerbasis functions ?
                            Edit: Ah right, they are not spline-based, (duh). So you go through the C-extensioncode right ?
                            • BoxB
                              Select the edges you want to add to then click add patch and it will follow the shape.
                              http://i155.photobucket.com/albums/s296/storeben/SU/Adding.gif
                              • jolranJ
                                jolran
                                Yes I noticed that. But Tripatch ?
                                edit: ah, it may not be included yet. There are some things not added in this version.
                                Doesent matter. Bloody marvelous anyway πŸ‘
                                • BoxB
                                  Sorry About that Jolran, I misread your question, didn't realise it was specifically the tris you were after.
                                  In case anyone is wondering how useful and fast this is to work with.
                                  This rough test torso is less than five minutes work.
                                    Rodin! πŸ˜„
                                    • jolranJ
                                      jolran
                                      No worries πŸ˜„ Nice chest.
                                      • panixiaP
                                        panixia
                                        it looks super nice thank you but it doesn't work for me (sketchup 8 on win7).. 😒
                                        i suppose i installed it properly and also updated ttlib to last version..
                                        i suspect it may depends on some conflict with tons of other plugins.. πŸ˜’
                                        • jolranJ
                                          jolran
                                          Same here. I only had it working in 2014.
                                          Error "defined method `force_encoding' for #String:0xb10993c"
                                          This is "probably" and Ruby 1.8 error. I have the impression that many authors will stop supporting SU 8 soon.
                                          • panixiaP
                                            panixia
                                            yeah. force encoding blablabla.. getting similar message when loading sketchup
                                            but.. it says su8 is supported..
                                            • 12
                                            • 13
                                            • 7 / 13
