    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 70.5k Views 69 Watching
    • jeff hammondJ Offline
      what the? this thing is cool πŸ‘
      a question..
      is there a way to control the segmentation yet? like, max angle = 5ΒΊ (or whatever) and anything steeper will break down to two (or more) segments until the maximum mesh angle has been achieved?
      • Rich O BrienR Online
        @jeff
        type subdivisions in the VCB
          @rich o brien said:
          @jeff
          got it. thanks
            Ur more than welcome.
            I imagine you'll get lots of mileage outta this?
              probably.. for me, it seems great to quickly mess around with new shape ideas.. like clay in a way..
              [edit]
              it's the controller (widget, gumball, whatshername) that makes it so fast.
                The song from Ghost is in my head now.
                • pbacotP Offline
                  There's a procrastinators beware message... Hand it over!
                  Glad it's available in the SCF pluginstore.
                    lucky for me i'm on a super crappy connection right now so i can't be arsed to youtube the scene.
                      At least! β˜€
                      Brilliant! 😎
                      Works on the 2014?
                      Seems not! 😞
                      Impossible to valide the second point of the patch!
                      I have the last TT_lib2
                      Error: #<NoMethodError: undefined method parent' for nil:NilClass> C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ChrisP_PutsCompOnFace.rb:21:in definition'
                      C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/instance.rb:23:in definition' C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:1129:in update_mesh'
                      C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/bezier_surface.rb:159:in update' C:/Users/Pilou/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_bezier_surface/tool_create_patch.rb:142:in onLButtonUp'
                        Seems in 2014 no compatibility with SketchyPhysics 3, Scalp
                        Patch is drawn with the grid
                        but now i have just the menu one time on the right Click
                        then no possibility to edit the patch! πŸ˜‰
                        Just this on the Ruby Console
                        nextFrame()->updateMainWnd()
                        • BoxB Offline
                          What an outstandingly wonderful tool.
                          http://i155.photobucket.com/albums/s296/storeben/genie.gif
                            For any reason after relaunch SU that works! πŸ˜’ 😎
                            Waiting the manual for translate it in French! β˜€
                              AcesHigh
                              how come I totally missed this plugin for 4 years? It should be on the list of essential plugins!
                              • cottyC Offline
                                cotty
                                Maybe because Thomthom published it yesterday πŸ˜‰
                                my SketchUp gallery
                                • PixeroP Offline
                                  Pixero
                                  Thanks, will come in handy for all those soft surfaces.
                                  • jolranJ Offline
                                    jolran
                                    This is so cool!
                                    I'm not gonna get any work done now playing with this πŸ˜„
                                    How do you add Tripatch to Qaudpatch ? Possible ?
                                    • jolranJ Offline
                                      jolran
                                      Some really nice editing capabilities there, with the Gizmo and all. WOW! 😲
                                      So you decided to release it non commersial, huh ?
                                      For some time now I have been working on curves and surfaces for my node editor, maybe
                                      I can try making it compatible with you patches as well, now that your code is in public...
                                      That would be cool to use your tools after baking down geometry..
                                      Do you use Knotvectors for the patches ? Or are they interval-based type powerbasis functions ?
                                      Edit: Ah right, they are not spline-based, (duh). So you go through the C-extensioncode right ?
                                      • BoxB Offline
                                        Select the edges you want to add to then click add patch and it will follow the shape.
                                        http://i155.photobucket.com/albums/s296/storeben/SU/Adding.gif
                                        • jolranJ Offline
                                          jolran
                                          Yes I noticed that. But Tripatch ?
                                          edit: ah, it may not be included yet. There are some things not added in this version.
                                          Doesent matter. Bloody marvelous anyway πŸ‘
                                          • BoxB Offline
                                            Sorry About that Jolran, I misread your question, didn't realise it was specifically the tris you were after.
                                            In case anyone is wondering how useful and fast this is to work with.
                                            This rough test torso is less than five minutes work.
                                            • 12
                                            • 13
                                            • 7 / 13
