    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 77.6k Views 69 Watching
    • cottyC Offline
      cotty
      @aceshigh said:
      how come I totally missed this plugin for 4 years?
      Maybe because Thomthom published it yesterday πŸ˜‰
      my SketchUp gallery
      • PixeroP Offline
        Pixero
        Thanks, will come in handy for all those soft surfaces.
        • jolranJ Offline
          jolran
          This is so cool!
          I'm not gonna get any work done now playing with this πŸ˜„
          How do you add Tripatch to Qaudpatch ? Possible ?
          • jolranJ Offline
            jolran
            Some really nice editing capabilities there, with the Gizmo and all. WOW! 😲
            So you decided to release it non commersial, huh ?
            For some time now I have been working on curves and surfaces for my node editor, maybe
            I can try making it compatible with you patches as well, now that your code is in public...
            That would be cool to use your tools after baking down geometry..
            Do you use Knotvectors for the patches ? Or are they interval-based type powerbasis functions ?
            Edit: Ah right, they are not spline-based, (duh). So you go through the C-extensioncode right ?
            • BoxB Offline
              Select the edges you want to add to then click add patch and it will follow the shape.
              http://i155.photobucket.com/albums/s296/storeben/SU/Adding.gif
              • jolranJ Offline
                jolran
                Yes I noticed that. But Tripatch ?
                edit: ah, it may not be included yet. There are some things not added in this version.
                Doesent matter. Bloody marvelous anyway πŸ‘
                • BoxB Offline
                  Sorry About that Jolran, I misread your question, didn't realise it was specifically the tris you were after.
                  In case anyone is wondering how useful and fast this is to work with.
                  This rough test torso is less than five minutes work.
                    Rodin! πŸ˜„
                    • jolranJ Offline
                      jolran
                      No worries πŸ˜„ Nice chest.
                      • panixiaP Offline
                        panixia
                        it looks super nice thank you but it doesn't work for me (sketchup 8 on win7).. 😒
                        i suppose i installed it properly and also updated ttlib to last version..
                        i suspect it may depends on some conflict with tons of other plugins.. πŸ˜’
                        • jolranJ Offline
                          jolran
                          Same here. I only had it working in 2014.
                          Error "defined method `force_encoding' for #String:0xb10993c"
                          This is "probably" and Ruby 1.8 error. I have the impression that many authors will stop supporting SU 8 soon.
                          • panixiaP Offline
                            panixia
                            yeah. force encoding blablabla.. getting similar message when loading sketchup
                            but.. it says su8 is supported..
                              d12dozr
                              Thanks, Thomthom. Time to play!
                              http://goo.gl/f7ooYh
                              • jolranJ Offline
                                jolran
                                Ah, yeah you are right. Then I guess he just probably forgot to set up some conditions for Su8. Well see when he get's back.
                                Meanwhile do a testspin in 2014. πŸ˜„
                                It may have be a condition set on line 26 in the loader rb
                                "file = FILE.dup.force_encoding("UTF-8")"
                                If I remember correctly Ruby 1.8 (Su8) does not have that method..
                                I'm not gonna mess with that since I don't know how he has things set up with TT_Lib so I suggest waiting for his return..
                                • panixiaP Offline
                                  panixia
                                  never thought for a second to fix the code by myself πŸ˜†
                                  anyway i downloaded su15 and it works perfectly.. too bad su2015 doesn't fit my needs at the moment (mainly for the other 31454535 plugin i use)
                                  this tool is great! sort of pseudo-nurb brother of vertex tools..
                                  waiting for su8 news.. πŸŽ‰
                                  • U Offline
                                    unclex
                                    Yes
                                    For 2013 or 8 user
                                    just change that like this
                                    "file = FILE"
                                    • BoxB Offline
                                      Did you restart Sketchup after installing it?
                                      • jolranJ Offline
                                        jolran
                                        Yes
                                        For 2013 or 8 user
                                        "file = FILE"
                                        Like I said, better let Thomthom do it properly. Even if it looks like a simple fix, it "may" have consequences for TT_lib since removing encoding.
                                        Although, nothing "bad" should happend if you only experiment at 1 place..
                                        • U Offline
                                          unclex
                                          It's just always updating...
                                          Cannot Click or DoubleClick
                                          and when SU opening, nothing prompt
                                            It's simple bezier quad patches with 4x4 control points each. The bezier calculation is based on the bezier example script posted by @last many years ago, I just ported it to C for faster calculations. You can see the source in TT_Lib2.
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
