    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 698.4k Views 121 Watching
    • fredo6F Offline
      NEW RELEASE: FredoTools v2.4a - 17 Nov 14
      FredoTools 2.4a is a release for AngleInspector v1.0, which is a small tool to measure angles anywhere in the model in one click.
      Note: it requires to install LibFredo6 v6.4a
      • micioneM Offline
        micione
        Tig,
        yes I installed the new library, restarted Sketchup,
        but the tool does not appear.
        This happens in SU2014 and SU2105.
        • fredo6F Offline
          @micione,
          Could you open the Trace Log file (in Windows > LibFredo6 Settings...) and check if FredoTools was loaded (or export as txt and send it to me).
          • micioneM Offline
            micione
            Ok Fredo,
            mail sent .
            • F Offline
              fantoosh420
              I have also tried with SU2015 X64 on win7 X64 sp1. i used freedo tools 2.2a (with libfreedo 6.2a, i think). it was (and is) working just fine on my home PC. have to check with this new release of 2.4a.
              Sketchup 14.0.4900
              Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
              • micioneM Offline
                micione
                Problem solved.
                (today re-downloaded and installed).
                Works wonders.
                thanks
                • OxerO Offline
                  Oxer
                  New Spanish Language file v2.4a
                  Spanish Language File
                  • fredo6F Offline
                    Oxer,
                    Thanks very much. This will go in next update
                      mcjoiner
                      Unsure if the following issue is me (likely), or related to FredoTools or LibFredo.
                      When using actively using thrupaint the tool works great. As soon as I double-click out, the changes are not visible. If I re-activate the tool, the previous changes are visible again.
                      I'm currently using sketchup pro 8.
                      Suggestions?
                      • fredo6F Offline
                        It is probably related to the style for displaying Edges.
                        To see the colors you need to set up the style by material in your model
                        • fredo6F Offline
                          NEW RELEASE: FredoTools v2.5a - 10 Jan 15
                          FredoTools 2.5a is a release for ElementStats v1.0, which is a small tool to display statistiscs about entities in the model in an interactive way.
                          [flash=640,480:sirs851j]http://www.youtube.com/v/46IcCUqVf0c&hl[/flash:sirs851j]
                          Note: it requires to install LibFredo6 v6.6a
                          • cottyC Offline
                            cotty
                            Thank you for another great addition to your toolbox!
                            my SketchUp gallery
                            • JClementsJ Offline
                              JClements
                              Another home run.
                              Great for serious modelers and newbies alike. Super great for SU training instructors and plugin demonstrations.
                              • OxerO Offline
                                Oxer
                                Thanks for this new update!! πŸ‘
                                Spanish Language Fredo Tools v2.5a
                                FredoTools_ES.lang.zip
                                • fredo6F Offline
                                  NEW RELEASE: FredoTools v2.5b - 18 Jan 15
                                  FredoTools 2.5b is a small update fixing a few bugs in release v2.5a which was for ElementStats.
                                  Note: version 2.5 (a and b) requires to install LibFredo6 v6.6
                                  • fredo6F Offline
                                    NEW RELEASE: FredoTools v2.5c - 19 Jan 15
                                    FredoTools 2.5c fixes a major bug for SU8 (and SU6, SU7) preventing ElementStats from working properly.
                                    Note: version 2.5 (a, b and c) requires to install LibFredo6 v6.6
                                      schnydix
                                      Hello Fredo Thank you for the great work
                                      All Other Translations following soon.
                                      Roland F. Swiss
                                      Translatet by Hand very carefully
                                      Please Do not put my name into the plugins There is only space for the Author (Your name)
                                      Save any Space for drawing.
                                      FredoTools 2.5a
                                      LibFredo6_DE.zip
                                      SUClock_DE.zip
                                      RoundCorner_DE.zip
                                      HoverSelect_DE.zip
                                      FredoTools_DE.zip
                                      JointPushPull_DE.zip
                                      ToolsOnSurface_DE.zip
                                        KrisM
                                        Feeling kind of dumb here but I can't see how to select both the front and back faces of an object while using ThruPaint. Most useful tool by the way.
                                        KrisM
                                        • massimoM Offline
                                          massimo Moderator
                                          If you mean painting both front and back faces at once then
                                            KrisM
                                            Okay, fixed. The options bar wasn't showing up because it was behind a floating toolbar.
                                            KrisM
                                            • 23
                                            • 24
                                            • 6 / 24
