    Spiral help please
    72 Posts 11 Posters 4.2k Views 11 Watching
    • gillesG Offline
      gilles
      @kathryng said:
      gilles:
      Installed and experimenting, but I am not understanding the 5 entities? It worked with the component, but of course that is not the look I am going for, the other one is, and when I follow what you did, I get nothing ?
      "5 entities" just says its raw geometries.
      Screw1_5#01basics.skp
      • KathrynGK Offline
        KathrynG
        Hi ely862me.
        Sorry, gave it a rest last night to watch a little television. I am going back to it today though. Call me stubborn, but I feel the need to get it done exactly as in the tutorial, not with any workarounds, not that they don't work, and not that I am not eternally grateful for any and all help.
        Uploading the model here that did work for some reason for dissection, and I look forward to hearing the analysis, critiques and comments.
        This has actually been wonderful seeing so many people coming together on an enigma for two of us.
        Thanks to all for the huge effort and interest.
        Candy Cane Column.skp
        "With SketchUp - Rome could have been built in a day!"
        • ely862meE Offline
          ely862me
          This model is also faulty, if you follow the helixes you will notice that at some point, there are some extra lines that shouldn't be there.
          I was looking for the model that didn't worked for you.
          test.skp
          Elisei (sketchupper)
          Come and See EliseiDesign
          • KathrynGK Offline
            KathrynG
            Opps - sorry - OK here it is. Will look for the extra lines on the previous one. Learning...
            Incorrect helix.skp
            • BoxB Offline
              There is a gap at the top, simply push the face down to join the lines and it works.
              • ntxdaveN Offline
                ntxdave
                Well, I gave it a rest last night and FINALLY, I GOT IT 😍
                Here is my example.
                I have to admit that Jeff's 3 helix example made me see the light!!
                Press F1...thank me later
                • ntxdaveN Offline
                  ntxdave
                  Here is another one using Jeff's 3 helix method. I used the Helix tool (in the 3D Shapes context menu). A little trickier with the scaling but another interesting affect. Once drawn and scaled, I created a box and trimmed the top so that the scaled helix did not stick up above the cylinder.
                  For any others who may care, here are the steps I used to create this one:
                  1. Created a helix Draw>3D Shapes>Helix
                  2. Rotated 2 copies of the helix by 15[sup:bhfl8sky]0[/sup:bhfl8sky] Selected helix Ctrl-Rotate 15 2x
                  3. Created a circle the same radius as the helix
                  4. Used Push/Pull to extrude the circle to the same height as the helix using inference for the correct height
                  5. Selected all items then right-clicked and selected Explode
                  6. Selected the top row of the helix's on the cylinder face and used the scale too to extrude
                  7. Selected the cylinder faces and used the scale tool to get the cylinder back into shape (this had to be done multiple times to get things back into the proper cylinder shape)
                  8. Used the bucket tool to add color to the faces the way I wanted it
                  9. Since one of the extruded helix faces now extended above the cylinder, I created a box that was larger than the diameter of the cylinder and helix faces and then made it a group
                  10. Selected the helix/cylinder shapes and made them a group
                  11. Placed the box at the top of the helix/cylinder at the height I wanted and then selected both the box and helix/cylinder and clicked on the Subtract Solids tool to trim the top
                  Hope someone finds these steps useful and/or informative.
                  Once again - Thanks Jeff, Box and others for opening my eyes. I had watch that original video several times but the real trick was in some of the subtle things that you do not really see clearly in the video. In particular, the Select All - Explode and being able to triple click on the line segments to select them all.
                  Learning new things can be fun even if you do not have any particular place to go apply them.
                  • jeff hammondJ Offline
                    that's happening because you're scaling using the shift key (uniform) while using a middle scale handle or- not using the shift key and planar inference with a top-corner handle
                    anyway, grab one of the corner-middle scale handles, press&hold option/alt key, scale then use the measurements box for uniformity.. i.e. enter 2.5,2.5 in the box
                    • ntxdaveN Offline
                      ntxdave
                      Thanks Jeff - again a good piece of information to tuck away for future reference.
                      Seems like there is just no end to things to learn. Particularly if they are features you do not use on a regular basis. Again, all part of the continued learning process.
                        Indeed!
                          i cheated ;)
                          • BoxB Offline
                            I didn't. πŸ˜‰
                            http://i155.photobucket.com/albums/s296/storeben/SU/Ball Race.gif
                            I did reduce the quality of the gif to make it easier on the page though.
                              @box
                              is your gif playing backwards or is it artistic license?
                              • BoxB Offline
                                I used magnets.
                                  I didn't cheat, either.
                                    heh.. i didn't cheat either.. by cheating, i meant that i showed it in sketchup when it was modeled in a different application.
                                        Ah. I see. I drew mine entirely in SketchUp. πŸ˜‰
                                        • ntxdaveN Offline
                                          ntxdave
                                          You guys make me want to run and hide Here I was proud and happy that I finally got the screw created and then you guys just blew me away.
                                          @box that is a really neat animation. Curios about the software you used for the animation.
                                          @Jeff - that was a really interesting video.
                                          @DaveR - I like the way you had multiple pitches to your helix and the transparency to the finished blade.
                                          Honestly, I enjoy feedback like in this thread. For people like myself you certainly help me to advance my skills by reaching out and, at the very minimum, trying to learn new things which I do not normally use in the work I do. One never knows when one of he "tricks" you learn from these exercises will help solve something you are trying to do.
                                            @Jeff
                                            There is an auto intersection at one place! πŸ’š
                                            • 3 / 4
