    Spiral help please
    72 Posts 11 Posters 8.3k Views 11 Watching
    • KathrynGK
      KathrynG
      Opps - sorry - OK here it is. Will look for the extra lines on the previous one. Learning...
      Incorrect helix.skp
      "With SketchUp - Rome could have been built in a day!"
      • BoxB
        There is a gap at the top, simply push the face down to join the lines and it works.
        • ntxdaveN
          ntxdave
          Well, I gave it a rest last night and FINALLY, I GOT IT 😍
          Here is my example.
          I have to admit that Jeff's 3 helix example made me see the light!!
          Press F1...thank me later
          • ntxdaveN
            ntxdave
            Here is another one using Jeff's 3 helix method. I used the Helix tool (in the 3D Shapes context menu). A little trickier with the scaling but another interesting affect. Once drawn and scaled, I created a box and trimmed the top so that the scaled helix did not stick up above the cylinder.
            For any others who may care, here are the steps I used to create this one:
            1. Created a helix Draw>3D Shapes>Helix
            2. Rotated 2 copies of the helix by 15[sup:bhfl8sky]0[/sup:bhfl8sky] Selected helix Ctrl-Rotate 15 2x
            3. Created a circle the same radius as the helix
            4. Used Push/Pull to extrude the circle to the same height as the helix using inference for the correct height
            5. Selected all items then right-clicked and selected Explode
            6. Selected the top row of the helix's on the cylinder face and used the scale too to extrude
            7. Selected the cylinder faces and used the scale tool to get the cylinder back into shape (this had to be done multiple times to get things back into the proper cylinder shape)
            8. Used the bucket tool to add color to the faces the way I wanted it
            9. Since one of the extruded helix faces now extended above the cylinder, I created a box that was larger than the diameter of the cylinder and helix faces and then made it a group
            10. Selected the helix/cylinder shapes and made them a group
            11. Placed the box at the top of the helix/cylinder at the height I wanted and then selected both the box and helix/cylinder and clicked on the Subtract Solids tool to trim the top
            Hope someone finds these steps useful and/or informative.
            Once again - Thanks Jeff, Box and others for opening my eyes. I had watch that original video several times but the real trick was in some of the subtle things that you do not really see clearly in the video. In particular, the Select All - Explode and being able to triple click on the line segments to select them all.
            Learning new things can be fun even if you do not have any particular place to go apply them.
            • jeff hammondJ
              that's happening because you're scaling using the shift key (uniform) while using a middle scale handle or- not using the shift key and planar inference with a top-corner handle
              anyway, grab one of the corner-middle scale handles, press&hold option/alt key, scale then use the measurements box for uniformity.. i.e. enter 2.5,2.5 in the box
              • ntxdaveN
                ntxdave
                Thanks Jeff - again a good piece of information to tuck away for future reference.
                Seems like there is just no end to things to learn. Particularly if they are features you do not use on a regular basis. Again, all part of the continued learning process.
                  Indeed!
                  • jeff hammondJ
                    i cheated ;)
                    • BoxB
                      I didn't. πŸ˜‰
                      http://i155.photobucket.com/albums/s296/storeben/SU/Ball Race.gif
                      I did reduce the quality of the gif to make it easier on the page though.
                      • jeff hammondJ
                        @box
                        is your gif playing backwards or is it artistic license?
                        • BoxB
                          I used magnets.
                            I didn't cheat, either.
                            • jeff hammondJ
                              heh.. i didn't cheat either.. by cheating, i meant that i showed it in sketchup when it was modeled in a different application.
                              • jeff hammondJ
                                  Ah. I see. I drew mine entirely in SketchUp. πŸ˜‰
                                  • ntxdaveN
                                    ntxdave
                                    You guys make me want to run and hide Here I was proud and happy that I finally got the screw created and then you guys just blew me away.
                                    @box that is a really neat animation. Curios about the software you used for the animation.
                                    @Jeff - that was a really interesting video.
                                    @DaveR - I like the way you had multiple pitches to your helix and the transparency to the finished blade.
                                    Honestly, I enjoy feedback like in this thread. For people like myself you certainly help me to advance my skills by reaching out and, at the very minimum, trying to learn new things which I do not normally use in the work I do. One never knows when one of he "tricks" you learn from these exercises will help solve something you are trying to do.
                                      @Jeff
                                      There is an auto intersection at one place! πŸ’š
                                      • jeff hammondJ
                                        @pilou said:
                                        @Jeff
                                        rhino doesn't have collision detection.. maybe solidworks does πŸ˜‰
                                        (if we're talking about the same thing)
                                          I suppose yes πŸ˜„
                                          Else Albertsoft is like your Rhino! πŸ’š
                                          • jeff hammondJ
                                            @pilou said:
                                            I suppose yes πŸ˜„
                                            haha.. i like your line choice for pointing out the problem in that picture πŸ˜†
                                            • 3 / 4
