    [Plugin] QuadFaceTools
    673 Posts 116 Posters 499.3k Views 116 Watching
    • pbacotP Offline
      Turn off hidden geometry to select whole surfaces.
        Kristusea
        I did select the whole surface but that's all it paints.
          View > Hidden Geometry > OFF
          THEN paint surface ?
            Kristusea
            That's not the point! I know how to turn off hidden edges.
            What i'm saying is when i select the UV Mapping Tool i can only select one axes.
            The only part where i can select 2 axes is that part on the pic. Nothing else gets textured even when the whole thing is selected. I hope i made myself clear now.
              Can you post the problem SKP, so we can look at it ?
              • jo-keJ Offline
                jo-ke
                I am using this plugin to texture a special curtain model.
                I used SU7 with Quadfacetools and changed now to SU2015pro. and the UV mappingtool doesn't work anymore.
                I've downloaded the latest version.
                did I do something wrong?
                http://www.zz7.de
                • KrisidiousK Offline
                  Krisidious
                  Works for me... Maybe you need TT's new library?
                  By: Kristoff Rand
                  • jo-keJ Offline
                    jo-ke
                    Is also installed the latest version with su2015. I'll post both files here....
                    http://www.zz7.de
                    • jo-keJ Offline
                      jo-ke
                      here is the comparison
                      http://www.zz7.de
                      • jo-keJ Offline
                        jo-ke
                        here are the files
                        su7 works
                        su2015 doesn't work
                        quad-su2015.skp
                        quad-su7.zip
                        http://www.zz7.de
                          If you open the Ruby Console while you try to use QuadFace Tools - do you see any error message?
                          Also, can you describe the steps you perform in more detail?
                          • jo-keJ Offline
                            jo-ke
                            when I start the uv mapper in version 2015 it doesn't show the horizontal and the vertical line to set the direction of the texture. so I can't use it.
                            http://www.zz7.de
                            • jo-keJ Offline
                              jo-ke
                              it seems to be that the model in version SU7 is quad face and when I import it to SU2015 it is a sandbox mesh.
                              I converted it again to quadface and the UV texture mapper worked.
                              everything fine!
                              http://www.zz7.de
                                Did you remember to convert the Sandbox Tool mesh into a QuadFace Tools compatible mesh first?
                                • jo-keJ Offline
                                  jo-ke
                                  Yes. I've did it like that and saved the component as SU7 some years ago and used it many times, just using the UV Mapper.
                                  But now, when I import the same component to SU2015 it lost the Quadface- Information and I have to reconvert it to quads, as you described above.
                                  http://www.zz7.de
                                    Any chance you can provide a sample model with exact steps (video?) of what you do?
                                    • jo-keJ Offline
                                      jo-ke
                                      the sample model is attached above.
                                      here's the component:
                                      If you load it in SU7 it is already converted to quadface
                                      If you load it in SU2015 you have to convert it to quadface
                                      0-schal-leger-tex.skp
                                      http://www.zz7.de
                                        I do not see a difference in behaviour between the two versions. In both SU7 and SU2015 I had to use SandboxTools Quads to QuadFace Quads for the mapping to work.
                                        • jo-keJ Offline
                                          jo-ke
                                          On my machines in Version 7 the model is already converted and can be mapped directly.
                                          It is not really a problem, I was just a bit surprised of that fact.
                                          http://www.zz7.de
                                            Can you do a screen capture? I might be missing a step or something. There should be no difference between machines.
                                            • 33
                                            • 34
                                            • 6 / 34
