    [Plugin] QuadFaceTools
    680 Posts 116 Posters 772.0k Views 116 Watching
    • tt_suT
      tt_su
      @gamophyte said:
      I'm golden now, thanks so much!
      EDIT: is there a way to then do quadface on the other side? I want to do just have the diamond black frame of the texture on the back. Do I just reverse faces again?
      You can use my "UV Toolkit" extension to transfer UV mapping between front and back side of faces.
      • Le Quoc HungL
        Le Quoc Hung
        A question: Is there a way to chamfer quad faces? Look like that :
        http://www.mariussilaghi.com/products/quad-chamfer-modifier
          Hmm... I wonder if Fredo's RoundCorner extensions support quads? I know a few of this extensions support quad faces like QuadFaceTools'.
          • K
            Kristusea
            How would i go about texturing this? When i select the road part it only textures those 2 faces and when i select the sidewalk it doesn't work at all. Am i doing something wrong?
            • pbacotP
              Turn off hidden geometry to select whole surfaces.
              • K
                Kristusea
                I did select the whole surface but that's all it paints.
                  View > Hidden Geometry > OFF
                  THEN paint surface ?
                  • K
                    Kristusea
                    That's not the point! I know how to turn off hidden edges.
                    What i'm saying is when i select the UV Mapping Tool i can only select one axes.
                    The only part where i can select 2 axes is that part on the pic. Nothing else gets textured even when the whole thing is selected. I hope i made myself clear now.
                      Can you post the problem SKP, so we can look at it ?
                      • jo-keJ
                        jo-ke
                        I am using this plugin to texture a special curtain model.
                        I used SU7 with Quadfacetools and changed now to SU2015pro. and the UV mappingtool doesn't work anymore.
                        I've downloaded the latest version.
                        did I do something wrong?
                        http://www.zz7.de
                        • KrisidiousK
                          Krisidious
                          Works for me... Maybe you need TT's new library?
                          By: Kristoff Rand
                          • jo-keJ
                            jo-ke
                            Is also installed the latest version with su2015. I'll post both files here....
                            http://www.zz7.de
                            • jo-keJ
                              jo-ke
                              here is the comparison
                              http://www.zz7.de
                              • jo-keJ
                                jo-ke
                                here are the files
                                su7 works
                                su2015 doesn't work
                                quad-su2015.skp
                                quad-su7.zip
                                http://www.zz7.de
                                  If you open the Ruby Console while you try to use QuadFace Tools - do you see any error message?
                                  Also, can you describe the steps you perform in more detail?
                                  • jo-keJ
                                    jo-ke
                                    when I start the uv mapper in version 2015 it doesn't show the horizontal and the vertical line to set the direction of the texture. so I can't use it.
                                    http://www.zz7.de
                                    • jo-keJ
                                      jo-ke
                                      it seems to be that the model in version SU7 is quad face and when I import it to SU2015 it is a sandbox mesh.
                                      I converted it again to quadface and the UV texture mapper worked.
                                      everything fine!
                                      http://www.zz7.de
                                        Did you remember to convert the Sandbox Tool mesh into a QuadFace Tools compatible mesh first?
                                        • jo-keJ
                                          jo-ke
                                          Yes. I've did it like that and saved the component as SU7 some years ago and used it many times, just using the UV Mapper.
                                          But now, when I import the same component to SU2015 it lost the Quadface- Information and I have to reconvert it to quads, as you described above.
                                          http://www.zz7.de
                                            Any chance you can provide a sample model with exact steps (video?) of what you do?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 33
                                            • 34
                                            • 20 / 34
