    [Plugin] QuadFaceTools
    680 Posts 116 Posters 713.8k Views 116 Watching
      By fail I mean the mesh generated is not what you had in blender.
      Tons of reversed faces and duplicate faces.
        gamophyte
        I am a noob at uv mapping but know SU pretty well. I simply wanted a texture to wrap around the outer lamp shade, I am building for a game.
        No matter how many times I try, I can't seem to get the materiel on the outside of the shade (I selected out from the rest of the model). It keeps appearing on the inside. I realized that selecting faces outside is also selecting faces inside. I know I can make the shade thicker but I need it to be one poly thick to keep polys down.
        http://i.imgur.com/ZpGq2CW.png
        Is there a way to do this?
        THANKS!
          The 'fronts' of those faces are probably oriented so that they facing 'inwards'.
          Faces have backs and fronts...
          Change the default back face color in the Style to be distinctive from the front color [say bright blue v off-white] and then View in Monochrome mode...
          You'll see what is wrong...
          To fix reversed faces select the faces that are wrongly oriented [a dragged fence will make a multiple selection, hold Ctrl to add to a selection] - then use the context-menu 'Reverse', and the faces will flip over to be correctly arranged...
          The similar tool 'Orient' will make all faces connected to the selected one face to have the same orientation - it might cause issues if an edge is shared by more than two faces as then you can never get them all to share the same orientation...
            gamophyte
            It was just as you said. I guess it became that way when I did the fallowme tool to make my lamp from a cross section. I actually fixed it by selecting whole shade without worry of selecting certain faces.
            I'm golden now, thanks so much!
            EDIT: is there a way to then do quadface on the other side? I want to do just have the diamond black frame of the texture on the back. Do I just reverse faces again?
              gamophyte
              It looks like this method won't work for my game design. I thought the textures where placed not duplicated to make it work.
              http://i.imgur.com/xCh4Jjh.png
              If I made this lamp by straight applying and positioning materials on faces the export 3ds would only be four materials (four pngs to put in my game assets folder). Using this way, well.. the screenshot. I can't have hundreds of the same texture.
              Is there a way around this? Have texture alignment coordinates instead of multiple textures?
              • tt_suT Offline
                tt_su
                You can use my "UV Toolkit" extension to transfer UV mapping between front and back side of faces.
                • Le Quoc HungL Offline
                  Le Quoc Hung
                  A question: Is there a way to chamfer quad faces? Look like that :
                  http://www.mariussilaghi.com/products/quad-chamfer-modifier
                    Hmm... I wonder if Fredo's RoundCorner extensions support quads? I know a few of this extensions support quad faces like QuadFaceTools'.
                      Kristusea
                      How would i go about texturing this? When i select the road part it only textures those 2 faces and when i select the sidewalk it doesn't work at all. Am i doing something wrong?
                      • pbacotP Offline
                        Turn off hidden geometry to select whole surfaces.
                          Kristusea
                          I did select the whole surface but that's all it paints.
                            View > Hidden Geometry > OFF
                            THEN paint surface ?
                              Kristusea
                              That's not the point! I know how to turn off hidden edges.
                              What i'm saying is when i select the UV Mapping Tool i can only select one axes.
                              The only part where i can select 2 axes is that part on the pic. Nothing else gets textured even when the whole thing is selected. I hope i made myself clear now.
                                Can you post the problem SKP, so we can look at it ?
                                • jo-keJ Offline
                                  jo-ke
                                  I am using this plugin to texture a special curtain model.
                                  I used SU7 with Quadfacetools and changed now to SU2015pro. and the UV mappingtool doesn't work anymore.
                                  I've downloaded the latest version.
                                  did I do something wrong?
                                  http://www.zz7.de
                                  • KrisidiousK Offline
                                    Krisidious
                                    Works for me... Maybe you need TT's new library?
                                    By: Kristoff Rand
                                    • jo-keJ Offline
                                      jo-ke
                                      Is also installed the latest version with su2015. I'll post both files here....
                                      http://www.zz7.de
                                      • jo-keJ Offline
                                        jo-ke
                                        here is the comparison
                                        http://www.zz7.de
                                        • jo-keJ Offline
                                          jo-ke
                                          here are the files
                                          su7 works
                                          su2015 doesn't work
                                          quad-su2015.skp
                                          quad-su7.zip
                                          http://www.zz7.de
                                            If you open the Ruby Console while you try to use QuadFace Tools - do you see any error message?
                                            Also, can you describe the steps you perform in more detail?
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 33
                                            • 34
                                            • 19 / 34
