    [Plugin] QuadFaceTools
    680 Posts 116 Posters 636.8k Views 116 Watching
      gamophyte
      @tig said:
      To fix reversed faces select the faces that are wrongly oriented [a dragged fence will make a multiple selection, hold Ctrl to add to a selection] - then use the context-menu 'Reverse', and the faces will flip over to be correctly arranged...
      It was just as you said. I guess it became that way when I did the fallowme tool to make my lamp from a cross section. I actually fixed it by selecting whole shade without worry of selecting certain faces.
      I'm golden now, thanks so much!
      EDIT: is there a way to then do quadface on the other side? I want to do just have the diamond black frame of the texture on the back. Do I just reverse faces again?
        gamophyte
        It looks like this method won't work for my game design. I thought the textures where placed not duplicated to make it work.
        http://i.imgur.com/xCh4Jjh.png
        If I made this lamp by straight applying and positioning materials on faces the export 3ds would only be four materials (four pngs to put in my game assets folder). Using this way, well.. the screenshot. I can't have hundreds of the same texture.
        Is there a way around this? Have texture alignment coordinates instead of multiple textures?
        • tt_suT Offline
          tt_su
          You can use my "UV Toolkit" extension to transfer UV mapping between front and back side of faces.
          • Le Quoc HungL Offline
            Le Quoc Hung
            A question: Is there a way to chamfer quad faces? Look like that :
            302 Found
            (www.mariussilaghi.com)
              Hmm... I wonder if Fredo's RoundCorner extensions support quads? I know a few of this extensions support quad faces like QuadFaceTools'.
                Kristusea
                How would i go about texturing this? When i select the road part it only textures those 2 faces and when i select the sidewalk it doesn't work at all. Am i doing something wrong?
                • pbacotP Offline
                  Turn off hidden geometry to select whole surfaces.
                    Kristusea
                    I did select the whole surface but that's all it paints.
                      View > Hidden Geometry > OFF
                      THEN paint surface ?
                        Kristusea
                        That's not the point! I know how to turn off hidden edges.
                        What i'm saying is when i select the UV Mapping Tool i can only select one axes.
                        The only part where i can select 2 axes is that part on the pic. Nothing else gets textured even when the whole thing is selected. I hope i made myself clear now.
                          Can you post the problem SKP, so we can look at it ?
                          • jo-keJ Offline
                            jo-ke
                            I am using this plugin to texture a special curtain model.
                            I used SU7 with Quadfacetools and changed now to SU2015pro. and the UV mappingtool doesn't work anymore.
                            I've downloaded the latest version.
                            did I do something wrong?
                            http://www.zz7.de
                            • KrisidiousK Offline
                              Krisidious
                              Works for me... Maybe you need TT's new library?
                              By: Kristoff Rand
                              • jo-keJ Offline
                                jo-ke
                                Is also installed the latest version with su2015. I'll post both files here....
                                http://www.zz7.de
                                • jo-keJ Offline
                                  jo-ke
                                  here is the comparison
                                  http://www.zz7.de
                                  • jo-keJ Offline
                                    jo-ke
                                    here are the files
                                    su7 works
                                    su2015 doesn't work
                                    quad-su2015.skp
                                    quad-su7.zip
                                    http://www.zz7.de
                                      If you open the Ruby Console while you try to use QuadFace Tools - do you see any error message?
                                      Also, can you describe the steps you perform in more detail?
                                      • jo-keJ Offline
                                        jo-ke
                                        when I start the uv mapper in version 2015 it doesn't show the horizontal and the vertical line to set the direction of the texture. so I can't use it.
                                        http://www.zz7.de
                                        • jo-keJ Offline
                                          jo-ke
                                          it seems to be that the model in version SU7 is quad face and when I import it to SU2015 it is a sandbox mesh.
                                          I converted it again to quadface and the UV texture mapper worked.
                                          everything fine!
                                          http://www.zz7.de
                                            Did you remember to convert the Sandbox Tool mesh into a QuadFace Tools compatible mesh first?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 33
                                            • 34
                                            • 20 / 34
