    [Plugin] QuadFaceTools
    680 Posts 116 Posters 700.5k Views 116 Watching
      Hmm... I wonder if Fredo's RoundCorner extensions support quads? I know a few of this extensions support quad faces like QuadFaceTools'.
        Kristusea
        How would i go about texturing this? When i select the road part it only textures those 2 faces and when i select the sidewalk it doesn't work at all. Am i doing something wrong?
        • pbacotP Offline
          Turn off hidden geometry to select whole surfaces.
            Kristusea
            I did select the whole surface but that's all it paints.
              View > Hidden Geometry > OFF
              THEN paint surface ?
                Kristusea
                That's not the point! I know how to turn off hidden edges.
                What i'm saying is when i select the UV Mapping Tool i can only select one axes.
                The only part where i can select 2 axes is that part on the pic. Nothing else gets textured even when the whole thing is selected. I hope i made myself clear now.
                  Can you post the problem SKP, so we can look at it ?
                  • jo-keJ Offline
                    jo-ke
                    I am using this plugin to texture a special curtain model.
                    I used SU7 with Quadfacetools and changed now to SU2015pro. and the UV mappingtool doesn't work anymore.
                    I've downloaded the latest version.
                    did I do something wrong?
                    http://www.zz7.de
                    • KrisidiousK Offline
                      Krisidious
                      Works for me... Maybe you need TT's new library?
                      By: Kristoff Rand
                      • jo-keJ Offline
                        jo-ke
                        Is also installed the latest version with su2015. I'll post both files here....
                        http://www.zz7.de
                        • jo-keJ Offline
                          jo-ke
                          here is the comparison
                          http://www.zz7.de
                          • jo-keJ Offline
                            jo-ke
                            here are the files
                            su7 works
                            su2015 doesn't work
                            quad-su2015.skp
                            quad-su7.zip
                            http://www.zz7.de
                              If you open the Ruby Console while you try to use QuadFace Tools - do you see any error message?
                              Also, can you describe the steps you perform in more detail?
                              • jo-keJ Offline
                                jo-ke
                                when I start the uv mapper in version 2015 it doesn't show the horizontal and the vertical line to set the direction of the texture. so I can't use it.
                                http://www.zz7.de
                                • jo-keJ Offline
                                  jo-ke
                                  it seems to be that the model in version SU7 is quad face and when I import it to SU2015 it is a sandbox mesh.
                                  I converted it again to quadface and the UV texture mapper worked.
                                  everything fine!
                                  http://www.zz7.de
                                    Did you remember to convert the Sandbox Tool mesh into a QuadFace Tools compatible mesh first?
                                    • jo-keJ Offline
                                      jo-ke
                                      Yes. I've did it like that and saved the component as SU7 some years ago and used it many times, just using the UV Mapper.
                                      But now, when I import the same component to SU2015 it lost the Quadface- Information and I have to reconvert it to quads, as you described above.
                                      http://www.zz7.de
                                        Any chance you can provide a sample model with exact steps (video?) of what you do?
                                        • jo-keJ Offline
                                          jo-ke
                                          the sample model is attached above.
                                          here's the component:
                                          If you load it in SU7 it is already converted to quadface
                                          If you load it in SU2015 you have to convert it to quadface
                                          0-schal-leger-tex.skp
                                          http://www.zz7.de
                                            I do not see a difference in behaviour between the two versions. In both SU7 and SU2015 I had to use SandboxTools Quads to QuadFace Quads for the mapping to work.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 33
                                            • 34
                                            • 20 / 34
