    [Plugin] QuadFaceTools
    673 Posts 116 Posters 543.5k Views 116 Watching
    • Le Quoc HungL Offline
      Le Quoc Hung
      A question: Is there a way to chamfer quad faces? Look like that :
      302 Found
      (www.mariussilaghi.com)
        Hmm... I wonder if Fredo's RoundCorner extensions support quads? I know a few of this extensions support quad faces like QuadFaceTools'.
          Kristusea
          How would i go about texturing this? When i select the road part it only textures those 2 faces and when i select the sidewalk it doesn't work at all. Am i doing something wrong?
          • pbacotP Offline
            Turn off hidden geometry to select whole surfaces.
              Kristusea
              I did select the whole surface but that's all it paints.
                View > Hidden Geometry > OFF
                THEN paint surface ?
                  Kristusea
                  That's not the point! I know how to turn off hidden edges.
                  What i'm saying is when i select the UV Mapping Tool i can only select one axes.
                  The only part where i can select 2 axes is that part on the pic. Nothing else gets textured even when the whole thing is selected. I hope i made myself clear now.
                    Can you post the problem SKP, so we can look at it ?
                    • jo-keJ Offline
                      jo-ke
                      I am using this plugin to texture a special curtain model.
                      I used SU7 with Quadfacetools and changed now to SU2015pro. and the UV mappingtool doesn't work anymore.
                      I've downloaded the latest version.
                      did I do something wrong?
                      http://www.zz7.de
                      • KrisidiousK Offline
                        Krisidious
                        Works for me... Maybe you need TT's new library?
                        By: Kristoff Rand
                        • jo-keJ Offline
                          jo-ke
                          Is also installed the latest version with su2015. I'll post both files here....
                          http://www.zz7.de
                          • jo-keJ Offline
                            jo-ke
                            here is the comparison
                            http://www.zz7.de
                            • jo-keJ Offline
                              jo-ke
                              here are the files
                              su7 works
                              su2015 doesn't work
                              quad-su2015.skp
                              quad-su7.zip
                              http://www.zz7.de
                                If you open the Ruby Console while you try to use QuadFace Tools - do you see any error message?
                                Also, can you describe the steps you perform in more detail?
                                • jo-keJ Offline
                                  jo-ke
                                  when I start the uv mapper in version 2015 it doesn't show the horizontal and the vertical line to set the direction of the texture. so I can't use it.
                                  http://www.zz7.de
                                  • jo-keJ Offline
                                    jo-ke
                                    it seems to be that the model in version SU7 is quad face and when I import it to SU2015 it is a sandbox mesh.
                                    I converted it again to quadface and the UV texture mapper worked.
                                    everything fine!
                                    http://www.zz7.de
                                      Did you remember to convert the Sandbox Tool mesh into a QuadFace Tools compatible mesh first?
                                      • jo-keJ Offline
                                        jo-ke
                                        Yes. I've did it like that and saved the component as SU7 some years ago and used it many times, just using the UV Mapper.
                                        But now, when I import the same component to SU2015 it lost the Quadface- Information and I have to reconvert it to quads, as you described above.
                                        http://www.zz7.de
                                          Any chance you can provide a sample model with exact steps (video?) of what you do?
                                          • jo-keJ Offline
                                            jo-ke
                                            the sample model is attached above.
                                            here's the component:
                                            If you load it in SU7 it is already converted to quadface
                                            If you load it in SU2015 you have to convert it to quadface
                                            0-schal-leger-tex.skp
                                            http://www.zz7.de
                                            • 33
                                            • 34
                                            • 4 / 34
