    Plugins Not Compatible with SU2015-64bit
    73 Posts 21 Posters 11.5k Views 21 Watching
    • tt_suT Offline
      tt_su
      @tig said:
      There's a BugSplat after the seemingly successful creation of geometry, as the tool exits.
      Did you submit the splat?
        Many authors have incorporated progressbar code within their own scripts - like ShapeBender, which no longer needs it.
        A few older scripts might still 'require' it as a separate file - particularly Smustard.com ones ?
        If you don't have it installed then any affected plugins will just 'break', probably as they try to load
        It can be copied across into v2015 plugins folder if needed - there is no 'updated version'.
          Yes: Under 'TIG' within the last hour or so...
          • KrisidiousK Offline
            Krisidious
            thank you...
            By: Kristoff Rand
            • tt_suT Offline
              tt_su
              Hmm... something is happening in SketchUp!CRubyTool::UpdateVCB after SketchUp!CRubyTool::OnLButtonDown. The stack trace is a bit junk after that though. I need to dig deeper. But do you have the snippet of what the tool does in OnLButtonDown? Are you by any chance selecting a new tool?
                def onLButtonDown(flags,x,y,view)
                    ph=view.pick_helper
                    ph.do_pick(x,y)
                    best=ph.best_picked
                    if best and best.valid?
                      case @state
                       when 0
                        if best.class==Sketchup;;Edge and best.curve
                          @sel.add(best.curve.edges)
                          @profile=best
                          Sketchup;;set_status_text(db("Extrude Edges by Rails by Face; Select the 1st 'Rail' Curve..."))
                          @state=1
                        else
                          UI.beep
                          view.invalidate
                          view.tooltip=(db("Pick Profile"))
                        end#if
                       when 1
                        if best.class==Sketchup;;Edge and best.curve and not @profile.curve.edges.include?(best.curve.edges[0])
                          @rail1=best
                          Sketchup;;set_status_text(db("Extrude Edges by Rails by Face; Select the 2nd 'Rail' Curve..."))
                          @state=2
                        else
                          UI.beep if @profile.curve.edges.include?(best.curve.edges[0])
                          view.invalidate
                          view.tooltip= db("Pick 1st Rail")
                        end#if
                       when 2
                        if best.class==Sketchup;;Edge and best.curve and not @profile.curve.edges.include?(best.curve.edges[0]) ###and not @rail1.curve.edges.include?(best.curve.edges[0])
                          @rail2=best
                          Sketchup;;set_status_text(db("Extrude Edges by Rails by Face; Select the 'Melding-Profile' Curve..."))
                          @state=3
                        else
                          view.invalidate
                          view.tooltip=(db("Pick 2nd Rail"))
                        end#if
                       when 3 ### melding profile
                        if best.class==Sketchup;;Edge and best.curve and not @rail1.curve.edges.include?(best.curve.edges[0])and not @rail2.curve.edges.include?(best.curve.edges[0])
                          @mprofile=best
                          view.invalidate
                          if @rail1.curve==@rail2.curve
                            Sketchup;;set_status_text(db("Extrude Edges by Rails by Face; Making Mesh from Profile and 1 Rail."))
                          else
                            Sketchup;;set_status_text(db("Extrude Edges by Rails by Face; Making Mesh from Profile and 2 Rails."))
                          end#if
                          self.make_mesh()
                        else
                          UI.beep if @rail1.curve.edges.include?(best.curve.edges[0])or @rail2.curve.edges.include?(best.curve.edges[0])
                          view.invalidate
                          view.tooltip=(db("Pick Melding Profile"))
                        end#if
                      end#case
                    end#if
                  end#onLButtonDown
                in EEbyRailsByFace.rb Tool you preselect the face and an optional cpoint, BUT then click the four curves in turn to define the profile/rail1/rail2/melding_profile [rail2 can be rail1 and profile can be picked twice too]
                Much the same picking code is used in EEbyRails and that works fine on v2015 ! πŸ˜’
                YES it does select another tool - EEbyFace is run after the picking, it is called in a loop for each of the 'ribs'. If one rib is processed it's OK, but if more it Splats in v2015...
                • tt_suT Offline
                  tt_su
                  I don't recall all the details right now, but I think I ran into an issue some time ago where selecting a new tool in the mouse event might cause a crash. I need to dig into my notes.
                    The mouse event doesn't immediately select the other tool.
                    It runs 'self.make_mesh()' which generates some temporary objects etc...
                    And in turn does some processing... and then calls EEbyFace to make the 'ribs'...
                    And of course it has worked fine in versions < v2015 for years !
                      @thomthom
                      You suggested that jumping out of a tool's mouse click method by calling another tool can cause splats.
                      Although the other tool is accessed after considerable other code has run outside of the mouse click method, AND it worked fine in <v2015...
                      I cobbled together the code from the second tool into the first problem one, and it processes everything just fine - no splats, so there MUST be some cause relating to the tool-swapping, BUT why in v2015 and not earlier versions ?
                      I'll use that fix for now... πŸ˜’
                      • tt_suT Offline
                        tt_su
                        Can you send me the original tool that splat? I'll see if I can dig into the guts of this to be sure.
                          I've PM'd you v2.6 which has the Bugsplat issue in v2015, and current v2.7 which works OK...
                          • jeff hammondJ Offline
                            Fluid Importer (obj import) isn't working on mac/2015
                            http://www.fluidimporter.com
                            • tt_suT Offline
                              tt_su
                              So a few weeks ago I investigated a similar issue - a tool that was using select_tool a lot to switch functionality of the tool instead of using stages. Nothing wrong with that per se, but we have a bug in SketchUp where under certain circumstances SU is trying to call the old tool after it was removed from the tool stack. It's filed as an issue internally for us to look at - though a fix for SU2015 didn't make it.
                              When I investigated this the first time it was happening in SU2014 - so you have been "lucky" it hasn't happened to you until now. Why SU2015 provoked it in your case I'm not 100% sure, could be due to memory corruption what manifest itself differently in 64bit or simply that fact it's a new binary of SketchUp.
                              I personally use tool juggling in Vertex Tools, but then I use push_tool and pop_tool to nest the tools on the stack instead of replacing which select_tool. That might be one workaround to use.
                                Krisidious
                                Vue Exporter has been updated to 2015 64bit compatible.
                                By: Kristoff Rand
                                  Krisidious
                                  while upgrading my installs to 2015 I reinstalled twilight. while it worked in the newer installs it broke 2013. I had to remove it to be able to open sketchup. Bugsplat. Beware when you install, where it installs. it will ask you to migrate settings when you open another version of SU.
                                  By: Kristoff Rand
                                    Krisidious
                                    Looks like Cabinet Tools and Bi-Fold Door by tomot are not compliant either. I've got an email into him to confirm.
                                    By: Kristoff Rand
                                    • jcharltoncarpJ Offline
                                      jcharltoncarp
                                      Scalp is causing my copy of SU2015 to crash on opening. I just tried installing a fresh copy from the plugin store and got the same results
                                      • BoxB Offline
                                        Try installing the version on the skalp website. It's possible the sketchucation store version is out of date.
                                        I just downloaded and installed the website version and if functions correctly.
                                        http://download.skalp4sketchup.com/downloads/latest/
                                          Krisidious
                                          Tomot is aware of the issue and says it will be a while before he can get to fixing it. Possibly January. He thinks all of his plugins might be broken, but I have Window and Door Tools installed and it seems to work ok. Book Shelf also seems to work fine.
                                          By: Kristoff Rand
                                            Krisidious
                                            Marginal UV Editor seems to be not working in 2015 64bit.
                                            By: Kristoff Rand
                                            • 2 / 4
