    Plugins Not Compatible with SU2015-64bit
    73 Posts 21 Posters 9.5k Views 21 Watching
      @thomthom
      You suggested that jumping out of a tool's mouse click method by calling another tool can cause splats.
      Although the other tool is accessed after considerable other code has run outside of the mouse click method, AND it worked fine in <v2015...
      I cobbled together the code from the second tool into the first problem one, and it processes everything just fine - no splats, so there MUST be some cause relating to the tool-swapping, BUT why in v2015 and not earlier versions ?
      I'll use that fix for now... πŸ˜’
      • tt_suT Offline
        tt_su
        Can you send me the original tool that splat? I'll see if I can dig into the guts of this to be sure.
          I've PM'd you v2.6 which has the Bugsplat issue in v2015, and current v2.7 which works OK...
          • jeff hammondJ Offline
            Fluid Importer (obj import) isn't working on mac/2015
            http://www.fluidimporter.com
            • tt_suT Offline
              tt_su
              So a few weeks ago I investigated a similar issue - a tool that was using select_tool a lot to switch functionality of the tool instead of using stages. Nothing wrong with that per se, but we have a bug in SketchUp where under certain circumstances SU is trying to call the old tool after it was removed from the tool stack. It's filed as an issue internally for us to look at - though a fix for SU2015 didn't make it.
              When I investigated this the first time it was happening in SU2014 - so you have been "lucky" it hasn't happened to you until now. Why SU2015 provoked it in your case I'm not 100% sure, could be due to memory corruption what manifest itself differently in 64bit or simply that fact it's a new binary of SketchUp.
              I personally use tool juggling in Vertex Tools, but then I use push_tool and pop_tool to nest the tools on the stack instead of replacing which select_tool. That might be one workaround to use.
              • KrisidiousK Offline
                Krisidious
                Vue Exporter has been updated to 2015 64bit compatible.
                By: Kristoff Rand
                  Krisidious
                  while upgrading my installs to 2015 I reinstalled twilight. while it worked in the newer installs it broke 2013. I had to remove it to be able to open sketchup. Bugsplat. Beware when you install, where it installs. it will ask you to migrate settings when you open another version of SU.
                  By: Kristoff Rand
                    Krisidious
                    Looks like Cabinet Tools and Bi-Fold Door by tomot are not compliant either. I've got an email into him to confirm.
                    By: Kristoff Rand
                    • jcharltoncarpJ Offline
                      jcharltoncarp
                      Scalp is causing my copy of SU2015 to crash on opening. I just tried installing a fresh copy from the plugin store and got the same results
                      • BoxB Offline
                        Try installing the version on the skalp website. It's possible the sketchucation store version is out of date.
                        I just downloaded and installed the website version and if functions correctly.
                        http://download.skalp4sketchup.com/downloads/latest/
                          Krisidious
                          Tomot is aware of the issue and says it will be a while before he can get to fixing it. Possibly January. He thinks all of his plugins might be broken, but I have Window and Door Tools installed and it seems to work ok. Book Shelf also seems to work fine.
                          By: Kristoff Rand
                            Krisidious
                            Marginal UV Editor seems to be not working in 2015 64bit.
                            By: Kristoff Rand
                            • john2J Offline
                              john2
                              Can't we have a collaborative online cloud type document listing all the incompatible plugins? This is a discussion thread and the first post can have a link to a collaborative document which only SCF members can edit and report incompatible plugins.
                              That would be the most organized system to get things in our control. I guess the administrators can design some webby thing or somewhat like that. What say? πŸ˜„
                              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                              • PixeroP Offline
                                Pixero
                                I get this when trying to start SU2015,64bit with Julia Eneroths Texture positioning plugin installed:
                                Error Loading File ene_texturepositioning.rb
                                Error; C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;47; invalid multibyte char (UTF-8)
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;47; syntax error, unexpected tIDENTIFIER, expecting keyword_end
                                ...given edge Rotate 90Β° clockwise or counter clockwise in one ...
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;47; syntax error, unexpected keyword_in, expecting keyword_end
                                ...ockwise or counter clockwise in one click. Rotate in custom ...
                                ...ockwise in one click. Rotate in custom angle. Get rid of pat...
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;47; syntax error, unexpected tSTRING_BEG, expecting '('
                                ...patterns formed between faces."
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;48; syntax error, unexpected tFLOAT, expecting keyword_end
                                ex.version = "1.0.1"
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;48; no .<digit> floating literal anymore; put 0 before dot
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;49; syntax error, unexpected tCONSTANT, expecting keyword_end
                                ex.copyright = "Julia Christina (eneroth3) Eneroth 2013"
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;50; syntax error, unexpected tCONSTANT, expecting keyword_end
                                ex.creator = "Julia Christina (eneroth3) Eneroth"
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;50; unterminated string meets end of file
                                C;/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/ene_texturepositioning.rb;50; syntax error, unexpected end-of-input, expecting keyword_end
                                end#module
                                It's soo good. Please fix. πŸŽ‰
                                  Krisidious
                                  I don't think many things will stay broken long enough to need it... Maybe just a couple. I'll take everything from the thread that doesn't work still and compile it at the front.
                                  It might have been a good idea to do something like that from the beginning of the roll out... But having a version compatibility variable in the plugin store would probably be more efficient.
                                  By: Kristoff Rand
                                    driven
                                    It's soo good. Please fix. :bounce:
                                    version = "1.0.3" from EW warehouse works...
                                    • tt_suT Offline
                                      tt_su
                                      That looks to be related to Ruby 2.0 - meaning SU2014. What version do you have?
                                      • PixeroP Offline
                                        Pixero
                                        What version of what?
                                        I have both 2014 32 bit and 2015 64 bit latest versions.
                                        Edit. Do you mean her script?
                                        I downloaded with Sketchucation tool I believe.
                                        Will check version tomorrow.
                                          driven
                                          the version is in the error
                                          sorry, I wasn't clearer, that's why I pointed to the EW version, which is 2 versions higher 1.0.3
                                          • PixeroP Offline
                                            Pixero
                                            Now I've removed the old version and reinstalled 1.0.3 and the error message is gone.
                                            Still nothing happens when I try to use it.
                                            Not even errors in the console. πŸ˜•
                                            I have it installed in: C:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Plugins
                                            • 3 / 4
