    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 55.7k Views 32 Watching
    • E
      enhorning
      I installed, it showed up in the plugins menu, all seemed well. I draw a simple floor plan and when I select a face and run door by embasure it crashes SU instantly.
      Any ideas?
      marianne
      • I
        ilay7k
        Hello Marianne!
        Try to catch messages from ruby-console(open console, do some actions with script and look at console, what happens...)
        Will be nice to have bugsplat-log with ruby?
        • Didier BurD
          Didier Bur
          the problem seems to have been the fact that the faces were reversed for the script to work
          Of course, because the script uses the normal vector of the selected face to decide in which direction it has to pushpull the lintel.
          DB
          • E
            enhorning
            I opened the console and ran the same little model to test lintel and nothing appeared in the console and no Bugsplat appeared. I did get a windows rash report. other than that i had about a 5 second wait before the first crash and then instant on subsequent crashes.
            anything else I can do to help diagnose?
            marianne
            error report.txt
            • F
              farukahmet
              Didier,
              Another excellent plugin. What a time saver!
              But i have a problem with the window option (door option works flawlessly). It simply does nothing. I tried various "window height" and "sill height" combinations but no success. Do you have any idea what might be the problem?
              • I
                ilay7k
                Hello Faruk, select face(red face, image-description from 1st message of topic) try by right click(context menu) and select "window by..."(for 1st if you define all options of window and sill in plug-ins menu)...
                Didier thank you for update!
                I got such error when i tried from "plug-ins"-menu
                Error; #<NoMethodError; undefined method `wbe_by_embrasure' for #<Object;0x42c92d0>>
                (eval);220
                (eval);220;in `call'
                from context - normal
                • F
                  farukahmet
                  Thanks Ilya, it worked like a charm. I wonder why it doesn't work from the Plugins menu though.
                  • I
                    ilay7k
                    i think, Didier will fix it...
                    we are humans...not machines
                    • Didier BurD
                      Didier Bur
                      Done.
                      Was a typo, "w" instead of "d" in Plugins menu option 🎉
                      (Note to french users: pas de probleme avec la version française)
                      DB
                      • PixeroP
                        Pixero
                        Thanks for this great script! 👍
                        • I
                          ilay7k
                          Didier thanks for fix ☀
                          it alive...works
                          Pixero
                          +7 ...sketchup...+7000
                          it closes to parametric... 😲
                          multiple selections of sides will be wonderful for it and connection with multiwall tool 😒 💭
                          • erikBE
                            erikB
                            Thanks for the update. This is a very usefull tool !!!
                            erikB
                            • pbacotP
                              It's been a while since I used this tool and it looks like interest in it has dropped off judging by the activity here. What other methods have people been using? I have been working with solid groups more and components, but sometime I just want to use something like this. There are some drawbacks to the tool at present:
                              I cannot make a shortcut key command operate the tool. Nothing happens. So it is slow if you are doing a lot of doors, pulling down the menus each time. Also I have found if you preselect the embrasures, you can work them all one by one by selecting the tool over and over. I wonder if the tool could be set to work on multiple instances in one command.
                              The tool would also be enhanced by having an active phase, with a toolbar. Then just clicking on an embrasure would perform the preset lintel. That would be the quickest use.
                              I sometimes get an error message that the maximum door height is exceeded. It has no relationship to the drawing that I can see. Then I cannot use the tool until I reduce the door height then set it back up again where I want it. I thought I might look at adjusting the script, but it's encoded.
                              Windows are set by sill and window size. It seems to me that convention would make it appropriate to set window head height and window size instead. Then adjusting for a different window would usually take only one input as window heads are usually constant in a building.
                              This tool works well and cleanly. It's helpful if you have imported CAD wall lines that already have openings. Probably has other uses in joining shapes. Thanks, Peter
                                SUFractal
                                Just discovered this plugin this morning ... very handy when importing a plan drawing in CAD as you suggested. I agree with your comments about some minor tweaking.
                                  ArCAD-UK
                                  I recently discovered TIG's Hole Punching tool...
                                  http://forums.sketchucation.com/viewtopic.php?t=30846
                                  which could work as a more efficient alternative depending on your components and objectives.
                                  • pbacotP
                                    Thanks for the note. I haven't been using that method, though I have looked at the plugin a few times. I'll look into it.
                                      Didier has agreed that I might update some of his Plugins in the PluginStore.
                                      Please get the latest v2014/2015 compatible version from the PluginStore http://sketchucation.com/pluginstore?pln=door_lintel
                                      guanjinG 1 Reply Last reply
                                      • jujuJ
                                        juju
                                        Please get the latest version from the PluginStore
                                        following the download button doesn't take me to the correct page, also, if I search the pluginstore, either by author or by plugin name it does not show this plugin
                                        is it an error there or on my machine somehow?
                                        • KrisidiousK
                                          Krisidious
                                          thanks for doing this Tig...
                                          By: Kristoff Rand
                                            Sorry, but although I had updated the RBZ I forgot to click 'Publish' in the PluginStore Dev-page...
                                            NOW its Download link should work !
                                            • 2 / 4
