    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    SketchUp 2015 is 64bit
    302 Posts 74 Posters 34.8k Views 74 Watching
      driven
      @andybot said:
      interesting, no more 8 hour trial period? That's too bad imo.
      I believe the majority of people use up the 8hrs in a day or two...
      now that you can't instal both at the same time and switch just for the pro features, I think it's a good move.
      I prefer 30 days to test any software before purchase...
      • soloS Offline
        See the added RAM in SU.
        • KrisidiousK Offline
          Krisidious
          Glass Chapel... Nice.
          By: Kristoff Rand
          • andybotA Offline
            andybot
            ๐Ÿ˜ณ good move for Trimble I guess. ๐Ÿ‘Š
            • MsketcherM Offline
              Msketcher
              I can barely fit your screenshot across my screens. I had to scroll over, and over, and over. I'm jealous of your screen size ๐Ÿ˜„
                "Titan" is not an another Planet ? ๐Ÿ˜„
                Maybe it's several screens in line? ๐Ÿ˜‰
                  Krisidious
                  Looks like they fixed the Scrapbook window in Layout. It now sizes properly.
                  By: Kristoff Rand
                  • jo-keJ Offline
                    jo-ke
                    Where can I find the prices update pro2014- pro2015?
                    http://www.zz7.de
                      Look under "What are the pricing options for the Maintenance & Support Plan?" where you'll find:
                      Single user: $95 USD per year
                      Network: $150 USD per year
                      • oceanembersO Offline
                        oceanembers
                        @msketcher said:
                        I'm really excited about the LayOut label tool AutoText features too. It can now read things like dynamic component attributes from your models. I'm trying to get it to be able to read dimension info from windows, so the label tool automatically shows the correct dimensions on windows from inside the layout document. A lot of hidden potential here...
                        Is that so? You're right on the hidden potential there, I will investigate further.
                        • jo-keJ Offline
                          jo-ke
                          Ah, thank you Dave.
                          http://www.zz7.de
                          • PixeroP Offline
                            Pixero
                            Will thumbnail previews on wondows 64bit work now without any third part software?
                              jaceguay
                              @thomthom said:
                              So all existing plugins must be adapted again โ“
                              Only if they used binary libraries. Most will work as is.
                              I had two which needed updating; TT_Lib and Vertex Tools. Compatible versions are on PluginStore and ExtensionWarehouse.
                              I've set X for my shortcut to Delete, still inside vertex tools it doesn't work, only the delete key delete a vertex, even if I remove it from my shortcut list and keep only the X key to delete
                              edit: I got it now, inside vertex tools it is called erase not delete,
                              • BoxB Offline
                                In a word, Yes.
                                http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=59648#p543000
                                • tt_suT Offline
                                  tt_su
                                  @krisidious said:
                                  Well, hello Steve... Nice to meet you.
                                  First time I saw the template figure I thought it was Mike... ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜†
                                  • tt_suT Offline
                                    tt_su
                                    Yes - the thumbnail handler will now be 64bit if you install the 64bit version. Though I'm not sure if you will see thumbnails in 32bit applications when you use the file dialogs.
                                    • hellnbakH Offline
                                      hellnbak
                                      Don't know if SU2015 will be a big success or another Windows 8, but at least it is breathing new life and an air of excitement back into the forums.
                                      And after the (IMO) lackluster attempts at taking SU forward with R13 and 14, my fears for Sketchup's future after Trimble are now somewhat laid to rest.
                                      They seem to be getting serious about making changes that really matter.
                                      Kudos, Trimble ๐Ÿ‘
                                        Mike's taller
                                        • BoxB Offline
                                          I like the Rotated rectangle tool, but it is very easy to get Z-Fighting with it.
                                            Don't draw one rectangle on top of another. ๐Ÿ˜„
                                            • 15
                                            • 16
                                            • 4 / 16
