    SketchUp 2015 is 64bit
    302 Posts 74 Posters 76.8k Views 74 Watching
      driven
      SketchUp now starts with a 30 day trial of SketchUp Pro.
      which is nice...
      • jeff hammondJ Offline
        nice work @suTeam.. much appreciated πŸ‘
        • BoxB Offline
          Two things well worth pointing out.
          It restores the thumbnails function in Explorer
          and
          it can easily be set not to be the default Skp opener, in other words it doesn't ride rough shod over your choice of version. You can install it to test it out and still retain your preferred version as default.
            Cool function! πŸ˜‰
            • andybotA Offline
              andybot
              which is nice...
              interesting, no more 8 hour trial period? That's too bad imo.
              • MsketcherM Offline
                Msketcher
                I'm really excited about the LayOut label tool AutoText features too. It can now read things like dynamic component attributes from your models. I'm trying to get it to be able to read dimension info from windows, so the label tool automatically shows the correct dimensions on windows from inside the layout document. A lot of hidden potential here...
                  driven
                  I believe the majority of people use up the 8hrs in a day or two...
                  now that you can't instal both at the same time and switch just for the pro features, I think it's a good move.
                  I prefer 30 days to test any software before purchase...
                  • soloS Offline
                    See the added RAM in SU.
                    • KrisidiousK Offline
                      Krisidious
                      Glass Chapel... Nice.
                      By: Kristoff Rand
                      • andybotA Offline
                        andybot
                        😳 good move for Trimble I guess. πŸ‘Š
                          Msketcher
                          I can barely fit your screenshot across my screens. I had to scroll over, and over, and over. I'm jealous of your screen size πŸ˜„
                            "Titan" is not an another Planet ? πŸ˜„
                            Maybe it's several screens in line? πŸ˜‰
                              Krisidious
                              Looks like they fixed the Scrapbook window in Layout. It now sizes properly.
                              By: Kristoff Rand
                              • jo-keJ Offline
                                jo-ke
                                Where can I find the prices update pro2014- pro2015?
                                http://www.zz7.de
                                  Look under "What are the pricing options for the Maintenance & Support Plan?" where you'll find:
                                  Single user: $95 USD per year
                                  Network: $150 USD per year
                                  • oceanembersO Offline
                                    oceanembers
                                    Is that so? You're right on the hidden potential there, I will investigate further.
                                    • jo-keJ Offline
                                      jo-ke
                                      Ah, thank you Dave.
                                      http://www.zz7.de
                                      • PixeroP Offline
                                        Pixero
                                        Will thumbnail previews on wondows 64bit work now without any third part software?
                                          jaceguay
                                          @thomthom said:
                                          So all existing plugins must be adapted again ❓
                                          Only if they used binary libraries. Most will work as is.
                                          I had two which needed updating; TT_Lib and Vertex Tools. Compatible versions are on PluginStore and ExtensionWarehouse.
                                          I've set X for my shortcut to Delete, still inside vertex tools it doesn't work, only the delete key delete a vertex, even if I remove it from my shortcut list and keep only the X key to delete
                                          edit: I got it now, inside vertex tools it is called erase not delete,
                                          • BoxB Offline
                                            In a word, Yes.
                                            http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=59648#p543000
                                            • 15
                                            • 16
                                            • 2 / 16
