    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
      matthew.robert
      Is there any way to convert multiple welded lines (contours for example) to segmented lines with set segment lengths? I have used Bezier Spline in the past to get better "From Contour" results by converting contour lines one at a time to lines made with consistent segment lengths. This works considerably better than the "simplify contours" plugin that still creates snow drifts all over the place.
      EDIT, kinda related... here is a video I created showing how to use the Polyfit LISP (from polyface.de) in Autocad to ultimately get a more efficient model to do a From Contour in SketchUp.
      http://youtu.be/6bQtJhDn_lc?t=3m40s
      (Easier to see in HD directly on Youtube, also jump to the 3:40 mark to see the polyfit part.)
      I've done a similar thing using BezierSpline with the Polyline Divider option, but I need to weld and apply the tool to each contour line rather than all at once with the Polyfit LISP.
      -- matt
        MarinerSketch
        Awesome plugin.
        Is there any option or method to make a spline's ends to be tangent to a straight line?
        • robertWanR Offline
          robertWan
          http://www.screencast.com/t/B1BJ3k1V
          Robert
          • SkeeterdS Offline
            Skeeterd
            Wonderful plugin! Is there a way to keep a tool persistent like in the tools on surface plugin?
              tellkurt
              How would I install the plugin for Sketchup 2014 ?
              • fredo6F Offline
                The strongly suggested method is that you first install the Sketchucation PluginStore tool, so that you can easily and safely install any plugin.
                Then, you can auto-install Bezierspline and all other plugins in one click.
                  mamagroene
                  so, I just installed the plugin, but as soon as I try to use it with sketch up (my version is sketchup pro 2014, the toolbar that appears is just empty. I hope you understand my problem as I'm not a native english speaker. we tried pretty much everything to make it work, but we simply can't. I hope you can help!
                    How did you install it ?
                    Sounds like some files are missing...
                    Please reinstall it using the PluginStore's AutoInstall tool, OR if you have the RBZ, then use it with v2014's Preferences > Extensions > Install... button...
                    Also note that many of Fredo's tools need LibFredo - also install the latest version of that [also available at the PluginStore...].
                    Restart after the installing to ensure everything is synchronized...
                      antonio.calvo
                      Hello Fredo, thank you for your plugin. Is fantastic and works great. Any way of making it persistent to glue to surface/or group/or edge..? Maybe be with a key stroke? Thank you so much again.
                      • W Offline
                        witjazz
                        thanks
                        • Y Offline
                          yaseerr
                          like it thank you
                          • fredo6F Offline
                            NEW RELEASE 1.7a - 19 Oct 2014
                            This release is required for SU 2014 when your username contains non-ascii characters
                            Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
                            Download new release at main post
                            • W Offline
                              WebBeau
                              Thanks a lot
                              • E Offline
                                Esense3d
                                Hello Fredo
                                I would like to translate this plugin on all German but can not find language files
                                Bezier spline is only partially translated
                                Fredo I now have this new address
                                Roland F Swiss
                                • fredo6F Offline
                                  @esense3d said:
                                  Hello Fredo
                                  Roland F Swiss
                                  Thanks for this proposal.
                                  BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
                                  Anyway, the current version already includes a German translation.
                                  • E Offline
                                    Esense3d
                                    Hello Fredo
                                    I See but it is not Full Translated
                                    Just Parts of it
                                    I also have your other plugins translated fully ie including the main folder
                                    and other
                                    Therefore, any icons etcetera in German
                                    If you want I send you these versions as rbz versions to
                                    If you do not mind I would publish in the German part please
                                    Roland F.
                                    • fredo6F Offline
                                      NEW RELEASE 1.7b - 22 Mar 2015
                                      This release removes noisy traces at startup of Sketchup
                                      • fredo6F Offline
                                        NEW RELEASE 1.7c - 23 Mar 2015
                                        This release removes noisy traces at startup of Sketchup - second trial
                                          rdcraighead
                                          This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
                                            Gábor
                                            What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
                                            • 22
                                            • 23
                                            • 7 / 23
