[Plugin Library] LibFredo6 - v14.5b - 24 May 24
New Spanish Language File
I have tried to use the Sketchucation Plugin, download, install, copy paste the latest version but I keep getting errors. Any help on what I may be doing wrong?
Fredo, I have upgraded LibFredo6 via Plugin Store auto-install and installed VisuHole. Now when I start up SketchUp I get the following error.
I also tried downloading the RBZ file and installing it with Install Extension. Same result.
"You must install LibFredo6 version 5.2 or higher to run Fredo6_VisuHole"
Could you be more precise on the error you get.
Dave,
Strange. I think you need to check the footprint to see if there is nothing wrong in the Plugins directory. You get this message if the LibFredo6 files cannot be found in the same directory as VisuHole.
Thanks for the help!
Error Loading File Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:206:inblock (2 levels) in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:in
foreach'
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:205:inblock in manage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:in
each'
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:201:inmanage_compatibility' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:121:in
startup'
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:306:in<module:LibFredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in
<top (required)>'
Error Loading File Fredo6_JointPushPull.rb
Error: #<NameError: uninitialized constant Fredo6::Traductor>
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:41:in<module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull.rb:25:in
<top (required)>'
Error Loading File Fredo6_RoundCorner.rb
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:41:in<module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_RoundCorner.rb:25:in
<top (required)>'
Error Loading File Fredo6_ToolsOnSurface.rb
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:41:in<module:Fredo6>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:25:in
<top (required)>'
Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb
Could not find included file 'C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/maxwell/init.rb'
Error Loading File C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb
Error: #<SyntaxError: C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting =>
defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}^
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting :: or '[' or '.'
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid/grid.rb:63: syntax error, unexpected ',', expecting keyword_end
defaults = {"dx", 8.feet, "dy", 8.feet, "nx", 4, "ny", 4}^>
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in
require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in
load'
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:inregister_extension' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:36:in
module:Grid'
C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:26:in<module:Samples>' C:/Users/Tina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/su_grid.rb:25:in
<top (required)>' -
I'll look into that Fredo but I don't see why it should get installed in a different directory either via the Pluginstore (which is pointing to ~/User/Library/.../SketchUp 2014/Plugins) or via Install Extension.
Tinanne
You seem to have a version of Fredo6_!LibFredo6.rb which is not correct (as it is not correctly encoded).
Strange, because many users should have this problem too.
NEW RELEASE: LibFredo6 v6.1b - 22 Sep 14
LibFredo6 6.1b is a release mainly for VisuHole 1.0.
I republish it because there seems to be a problem with the encoding of the main rb file.
See main post of this thread for Download of LibFredo6.
@fredo6 said:
Tinanne
So what do I do from here? I used the Sketchucation plugin to install it and then tried the other types of installs.
Thanks again for looking into it.
Tianne,
I have republish a version of LibFredo6 - 6.1b - in the PluginStore.
Can you try it.Fredo
@fredo6 said:
Tianne,
I republish a version LibFredo6 6.1b on PluginStore. Can you try it.
I just installed from the plugin store and still getting this error...
foreach'
each'
startup'
<top (required)>'
<top (required)>'
<top (required)>'
<top (required)>'
load'
module:Grid'
<top (required)>' -
Tinanne,
You must have an old version of some of my plugins, or some plugins that have their UTF encoding changed for whatever reason.
Can you check
I'm sorry to be such a pain! I've uninstalled all the Fredo6 plugins and reinstalled using the plugin store and now I get this error.
load'
module:Grid'
<top (required)>' -
At least you seem to have no problem with my scripts.
Try to remove the su_grid plugin which seems faultyFredo
A ha! Finally! No more errors. Thank you!
I use SU2014. Install automatic from SketchupUcation plugin. Help please.
It gives me same msg, LibFredo6:Folder Libfredo6 not found in directory....
I install it, folders (Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 directory) are seen in plugging directory.(C:\Users****\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins)
Might be related to the username if it includes non-ascii characters.
This is a known problem with SU, which I hope will be fixed.Fredo
