    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • sprocket_S
      sprocket_
      @tig said:
      If the SCFLicense folder is missing something is stopping it being created, or found.
      Is this folder there ?
      C:\Users\javi\AppData\Local\SCF Licenses
      Check the permissions to your Local folder allow folders to be added and files made/read...
      Also look in your Roaming folder and ensure that its contents are writable etc...
      Perhaps SketchUp is having an issue with the contents of subfolders in Plugins etc...
      The folder named exactly " SCFLicense" is part of the installation of the SketchUcation extension installation... It contains many vital files and subfolders used in the licensing system.
      Is it there ?
      C:\Users\javi\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins\SketchUcation\SCFLicense
      If it's not there please try reinstalling the latest toolset from the SCF Plugin|ExtensionStore [v4.3.1].
      That folder is most definitely included in the RBZ installer...
      The folders are there, permissions are ok, Roaming folder and its contents are writable.
      The folder named exactly " SCFLicense" is where it should be:
      I've reinstalled SU 2022, started and just installed SketchUcation Tools. Extensions > SketchUcation > SCFLicense: Global Status... does nothing.
      This is gonna be next "X Files" movie... 😠 😠
        The above path doesn't contain your licenses. It is extension related.
        The path below is where you are experiencing issues...
        This folder should have the .txt files and the signature file.
        • sprocket_S
          sprocket_
          Well, first problem solved: SU now reads my licenses at C:\Users\Javi\AppData\Local\SCF Licenses.
          Fredo6 Plugins Information on 2023-08-01 15;27;29 +0100
          - Platform; x64-mswin64_140 - Ruby; 2.7.2
          - Sketchup; 22.0.354
          - LibFredo6; v14.1a
          - LibFredo6 Binary loaded
          - Sketchucation ExtensionStore; 4.3.1
          - SCFLicense; v6.1a - 72
          - Fredo6 Plugins
          - SCFLicense directory present
              > Signature File; 2022-03-30 01;28;02 +0100
              > Curviloft; 2022-04-28 20;01;36 +0100
              > FredoScale; 2022-04-16 20;20;36 +0100
              > JointPushPull; 2022-06-22 20;11;35 +0100
              > RoundCorner; 2022-05-11 10;12;30 +0100
              > ToolsOnSurface; 2022-04-28 21;50;30 +0100
          Second part is still unreachable: if I install a Fredo6 plugin, I get the same error. This is what I get after installing Curviloft:
          Fredo6 Plugins Information on 2023-08-01 15;28;54 +0100
          - LibFredo6; v14.1a
          - Fredo6 Plugins
          Error; #<TypeError; no implicit conversion of nil into String>
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `exist?'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;603;in `licensed?'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;331;in `initialize'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `new'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;73;in `licensed?'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;797;in `block in info'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `each'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe;791;in `info'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;368;in `block in populate_support_menu'
          c;/users/javi/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
          I'm thinking it's because I have customized Windows paths at Advanced System Setup (even though I haven't had this problem in years):
          • C:\Windows\Temp --> D:-WinCache\Windows\Temp
          • C:\Users\javi\AppData\Local\Temp --> D:-WinCache\Temp
          I think this because in my work laptop, SCF and SCF Licenses are subfolders at C:\Users\Javi\AppData\Local, but in my home PC is SCF is at D:\-WinCache\SCF and SCF Licences keeps as a C:\Users\Javi\AppData\Local subfolder.
          • sprocket_S
            sprocket_
            It seems I'm in a dead end... "SCFLicense: Global Status" refuses to show, even LibFredo6 is installed or not. Then, the same issues as posted before.
            Any idea?
              I think this unconventional path is likely your issue...
              D:\-WinCache\SCF
              TIG and Fredo would be better placed to comment on the nuances of the 'ideal' setup for such scenarios.
              • sprocket_S
                sprocket_
                D:\-WinCache\SCF
                I tried with stock Windows paths (no work) and creating a Windows symbolic link C:\Users\Javi\AppData\Local\SCF --> D:\-WinCache\SCF, so it uses the first one, but really stores in the second one (no work).
                The strangest is it's been working in SU 2021 for years with this path configuration, and suddenly it doesn't... that's the point.
                • fredo6F
                  NEW RELEASE: LibFredo6 v14.2a - 26 Aug 23
                  LibFredo6 14.2a includes:
                  • Future compatibility
                  • Various bug fixes and adjustments
                  _____________________________________a
                  • zivotinjaZ
                    zivotinja
                    Constant error
                    I am getting the same error after installing the latest plugin (libfredo) I do not what to do. It cannot install
                      Have you tried the installation that's recommended ?
                      And restarted SketchUp...
                        sjn001tvh
                        After Installing your tools, it wouldn't work as described and it froze up my regular mesh tools so that they also didn't function. I tried to uninstall it and no matter what I did it still shows up on my Extensions Manager as installed. It have really frustrating not to have a reliable tool that not only will not function properly but then doesn't have an appropriate and reliable method to uninstall. The product may work for others, but for me I just want to get rid of it. HOW CAN I REMOVE THIS UTILITY FROM MY SYSTEM????
                          Are you still using SketchUp 2016 as indicated in your forum profile?
                            jasminsreichle Newcomers
                            it does not offer the otion to download anything. Not even after signing up for a free profile.
                              You download RBZs from the PluginStore and install them using the Extension Manager dialog's install button...
                              Restart SketchUp to sync everything...
                              LibFredo6 offers support to Fredo's other extensions [which you also need to install].
                              You also need the SketchUcation toolset installing,because that does the licensing stuff used by many of Fredo's paid-for extensions.
                              Using the SketchUcation ExtensionStore dialog to auto-install other plugins sidesteps the need to down their RBZs... so perhaps install that first, then use it to auto-install the others...
                                Scamper4ever Newcomers
                                How do I download into sketchup 2023. Did I get scammed? its so stupid. Explain to me NOW!
                                • P
                                  prinjke Newcomers
                                  I have issues loading FredoScale. Message keeps popping up saying it requires LibFredo6 version >= 129 but I have the most recent version.
                                    stkfig Newcomers
                                    Hey Fredo6
                                    I have the 3 seat JointPushPull plugin, but my old work laptop graphics card died and it will not let me open SketchUp to release the seat on the old machine and IT has taken the laptop away from me.
                                    Is there a way to remotely release that seat from the old laptop?
                                    Tim
                                      See this topic which covers license management vis SketchUcation.com
                                      If the defunct device had an old licensing setup then you might not be able to do it this way...
                                      In which case PM Fredo or Rich with a list of the licenses to be released and will probably be able to help you...
                                      However, it'll be quicker to do it yourself, if you can...
                                      • L
                                        leranong Newcomers
                                        Hi there!
                                        SketchUp Pro 2023.
                                        I tried yo install libfredo (the latest version),and RoundCorner (the latest versionm) but something went wrong. it is shown that it is installed in the Extension Manager but nothing is displayed. I found that I have to install ExtensionStore, I did it, but nothing changed. the message that I need to install the latest version of libfredo always appears, but it has been already installed. I've read that many people has the same issue but i haven't found the answer how to repair it. Please help me!
                                          @leranong
                                          While we wait for Fredo to reply...
                                          Being unable to read installed files is often a clue to an incorrect installation of SketchUp.
                                          You don't need to reinstall it, but do the following... which will not impact on any customization thus far...
                                          Close SketchUp.
                                          Find its installer exe file [usually in your Downloads folder]
                                          Select its icon, right-click > context-menu > 'Run as administrator'
                                          When prompted by the dialog that will open choose 'Repair'.
                                          When if is completed, retry SketchUp and see if the problems are gone.
                                          Installing a complex app by double-click its installer's exe file to 'Run' it, is not the same as doing it as I describe; even if you have admin powers the results will vary unpredictably - often messing up permissions.
                                          Also make sure you have the latest versions of Fredo's exensions, his LibFredo, and the SketchUcation Tools [for licensing] installed and SketchUp restarted to sync everything...
                                          • L
                                            leranong Newcomers
                                            @tig said:
                                            @leranong
                                            Close SketchUp.
                                            Thank you for trying to help me, appreciate it. But it doesn't work for me, the problem is repeated - these files can't be opened. I did what you said and also tried to uninstall everything and reinstall - but nothing helps. It seems that the only way is to reinstall my Windows))))))
                                            • 97
                                            • 98
                                            • 99
                                            • 100
                                            • 101
                                            • 113
                                            • 114
                                            • 99 / 114
