    360 VR questions
    extensions
    41 Posts 11 Posters 6.5k Views 11 Watching
    • V Offline
      valerostudio
      Slightly off topic, Pixero, which engine did you use to render those scenes? They are really nicely done!
      • PixeroP Offline
        Pixero
        Thea. I used the TR 1 engine. It was before Presto was introduced.
        • V Offline
          valerostudio
          I am also working on a project using Pano2VR and I am curious as to what resolution you render your final at and what settings you use in Pano2VR so that it loads so quickly but at such a sharp quality. Can you share a screenshot?
          • AdamBA Offline
            AdamB
            As a rule of thumb, if you are rendering a 360 panorama, you'll want double the maximum height resolution it will be viewed at. So if you plan on viewing in a window of height 1000 pixels, the pano will need to be ~2000 high (and therefore 4000 wide).
            • PixeroP Offline
              Pixero
              I rendered 6000x3000 pixels since you only see a small bit of the pano at a time.
              The final size of the sides in the pano cube was 1500 pixels.
              • V Offline
                valerostudio
                Pixero, can you show us a screenshot of your Pano2VR Settings?
                • PixeroP Offline
                  Pixero
                  Sorry, but I'm swamped with work at the moment and won't have time to dig it out from backup.
                  • AdamBA Offline
                    AdamB
                    Spent some time knocking up a plugin-free panorama viewer using CSS3 (or WebGL if supported).
                    LightUp Panorama
                    (light-up.co.uk)
                    Seems to work nicely on iPad etc. Let me know if you find a browser that doesn't work.
                    Adam
                    • Rich O BrienR Online
                      @adam
                      Great stuff.
                      Personally I'd change the swipe direction.
                      • FrederikF Offline
                        Frederik
                        ๐Ÿ˜ฒ ๐Ÿ˜ฎ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                        That's awesome, Adam...!
                        http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
                        I've tested it on Firefox 29.0.1 and IE 11 v. 11.0.9600.17107 - without any issues... ๐Ÿ‘
                        So... How does this work from LightUp...?
                        I agree... Not that it matters that much - it just would make more sense... ๐Ÿ˜‰
                        Cheers
                        Kim Frederik
                        • PixeroP Offline
                          Pixero
                          I think it is fine. ๐Ÿ‘
                          If anything an option to choose.
                          • AdamBA Offline
                            AdamB
                            @frederik said:
                            :shock: ๐Ÿ˜ฎ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                            LightUp can output a skybox for the current view position which is directly compatible with this (test) viewer.
                            ie it can render 6 images ending in "_up", "_dn" etc. If you put them on a website you may be able to do:
                            http://light-up.co.uk/pano_test.html?p=URL_OF_YOUR_SKYBOX
                            I say "may" because modern browsers are tediously picky about cross-site loading of resources.
                            Lastly, take all your points about swipe preferences. The idea would be to turn SketchUp Scenes into hotspots - thats the weird busy icon on the floor if you're using CSS3D rendering.
                            EDIT: I've swapped swipe direction around.
                            • jo-keJ Offline
                              jo-ke
                              @solo said:
                              I will investigate Google+ as I'm sure they have a way.
                              Just stumbled today over that interessting thread!
                              In Google+ it is possible to upload an pano directly. You have to set the file with the geodata and google+ will find out that it is a pano and will put it to its own viewer.
                              here's my example:
                              https://plus.google.com/u/0/102379974904160468503/posts/GUhgBvYh6Ff?pid=6001500064550208818%26amp;oid=102379974904160468503
                              http://www.zz7.de
                              • 2 / 3
