    360 VR questions
    extensions
    41 Posts 11 Posters 7.9k Views 11 Watching
    • soloS
      @adamb said:
      Solo,
      You can just post a URL to your website page that contains the QuickTime VR (aka .mov) file.
      Sure, here is a test version on my site, I still need to do changes and add details and rooms for final.
      There is a little noise.
      404 Not Found
      (www.solos-art.com)
      • PixeroP
        Pixero
        @adamb said:
        Hmm.. iPhones do not support WebGL (aka html5) and also do not support Flash. So I wonder what Pano2VR (which is a great product that I also use) outputs for phones..
        Adam
        My VR presentation runs on iOS with html5 but without web GL:
        http://whiteclients.se/obo/vivalla/
        • soloS
          @pixero said:
          Adam
          Yours are amazing, I need to learn how to get all the fluff you have, the map and hotspots.
          • olisheaO
            olishea
            stunning work pixero! bravo!
            would be nice if we could texture bake the entire model with several spherical panoramas.
            oli
            • cottyC
              cotty
              krpano uses HTML5 (and/or webGL) too and many devices are supported this way...
              my SketchUp gallery
              • FrederikF
                Frederik
                It's fairly easy with Pano2VR... ๐Ÿ˜‰
                @Adam: I didn't know all that... I suppose I got a little confused by your comment about plugins... I interpreted it as if you didn't know what plugins does in WP... ๐Ÿ˜ณ ๐Ÿ˜„
                Cheers
                Kim Frederik
                • PixeroP
                  Pixero
                  Thanks.
                  I read some tutorials on their site and forum. Can't say it was easy to get all the different pre/after versions linked correct. The client had quite detailed wishes so I just had to get it to work. ๐Ÿ˜†
                  The road signs on the floor I deformed in Photoshop so they kind of matched the perspective.
                  • AdamBA
                    AdamB
                    @pixero said:
                    Adam
                    Had a quick look. Its using Adobe Flash for browsers on Desktop computers which is expected BUT amazingly for iOS it uses CSS3 ๐Ÿ˜ฒ to get around iPad's lack of WebGL support. Clever workaround by the Pano2VR team!
                    Adam
                    • V
                      valerostudio
                      Slightly off topic, Pixero, which engine did you use to render those scenes? They are really nicely done!
                      • PixeroP
                        Pixero
                        Thea. I used the TR 1 engine. It was before Presto was introduced.
                        • V
                          valerostudio
                          I am also working on a project using Pano2VR and I am curious as to what resolution you render your final at and what settings you use in Pano2VR so that it loads so quickly but at such a sharp quality. Can you share a screenshot?
                          • AdamBA
                            AdamB
                            As a rule of thumb, if you are rendering a 360 panorama, you'll want double the maximum height resolution it will be viewed at. So if you plan on viewing in a window of height 1000 pixels, the pano will need to be ~2000 high (and therefore 4000 wide).
                            • PixeroP
                              Pixero
                              I rendered 6000x3000 pixels since you only see a small bit of the pano at a time.
                              The final size of the sides in the pano cube was 1500 pixels.
                              • V
                                valerostudio
                                Pixero, can you show us a screenshot of your Pano2VR Settings?
                                • PixeroP
                                  Pixero
                                  Sorry, but I'm swamped with work at the moment and won't have time to dig it out from backup.
                                  • AdamBA
                                    AdamB
                                    Spent some time knocking up a plugin-free panorama viewer using CSS3 (or WebGL if supported).
                                    http://light-up.co.uk/pano_test.html
                                    Seems to work nicely on iPad etc. Let me know if you find a browser that doesn't work.
                                    Adam
                                      @adam
                                      Great stuff.
                                      Personally I'd change the swipe direction.
                                      • FrederikF
                                        Frederik
                                        ๐Ÿ˜ฒ ๐Ÿ˜ฎ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                                        That's awesome, Adam...!
                                        http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
                                        I've tested it on Firefox 29.0.1 and IE 11 v. 11.0.9600.17107 - without any issues... ๐Ÿ‘
                                        So... How does this work from LightUp...?
                                        I agree... Not that it matters that much - it just would make more sense... ๐Ÿ˜‰
                                        Cheers
                                        Kim Frederik
                                        • PixeroP
                                          Pixero
                                          I think it is fine. ๐Ÿ‘
                                          If anything an option to choose.
                                          • AdamBA
                                            AdamB
                                            @frederik said:
                                            :shock: ๐Ÿ˜ฎ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                                            LightUp can output a skybox for the current view position which is directly compatible with this (test) viewer.
                                            ie it can render 6 images ending in "_up", "_dn" etc. If you put them on a website you may be able to do:
                                            http://light-up.co.uk/pano_test.html?p=URL_OF_YOUR_SKYBOX
                                            I say "may" because modern browsers are tediously picky about cross-site loading of resources.
                                            Lastly, take all your points about swipe preferences. The idea would be to turn SketchUp Scenes into hotspots - thats the weird busy icon on the floor if you're using CSS3D rendering.
                                            EDIT: I've swapped swipe direction around.
                                            • 2 / 3
