    360 VR questions
    extensions
    41 Posts 11 Posters 7.9k Views 11 Watching
    • PixeroP
      Pixero
      But web GL doesn't work in all browsers and on all platforms. (IOS for example.)
      • FrederikF
        Frederik
        Pixero is right...
        Besides, Solo asked specifically for an easy way to embed on his WordPress website...
        Perhaps an idea for you, Adam, to make a WP plugin, which would make it even easier to embed something made with LightUp on a WP website... πŸ˜‰
        @adamb said:
        Here's a quick test I wrote: http://light-up.co.uk/pano.html
        Hhmmm... It doesn't show anything on my screen... πŸ˜•
        Cheers
        Kim Frederik
        • AdamBA
          AdamB
          Frederick: Yes, it requires a browser that supports WebGL (and has it enabled).
          [EDIT: Try again as I was using a file format Chrome didn't like.]
          AFAIK The use of ANY plugins is going to be soon banned by browsers, so WebGL will be the only solution eventually. Not saying that is a GoodThing, just that its happening.
          • PixeroP
            Pixero
            What I meant was that the solution one should choose depends heavily on who your enduser is.
            If you are aiming at "anyone" then the solution should work for as many as possible without special hardware and software requirements.
            What I used for my panoramas was flash for those who had and html5 for the rest. Pano2VR can export to both and detect which version to use. It can also do a low resolution version for phones.
            • AdamBA
              AdamB
              Hmm.. iPhones do not support WebGL (aka html5) and also do not support Flash. So I wonder what Pano2VR (which is a great product that I also use) outputs for phones..
              Adam
              • FrederikF
                Frederik
                I tried using Firefox and only saw a black box and then the text...
                Any way... Now it works and I see the model... πŸ‘
                Not sure I get you here... πŸ˜•
                A plugin for WordPress isn't something special like a plugin for a browser...
                Do you have any knowledge about WordPress...?
                A plugin simply makes it easier for the average Joe to embed content on his/her website...
                Most people are unable to make even simple web-code, thus a CMS is required...
                Please remember that WordPress isn't just a blog-tool... It was, but today it's nothing less than the most widely used CMS in the world...
                Cheers
                Kim Frederik
                • soloS
                  Getting a VR to work with Wordpress is simple enough, I just upload the .mov file and using a copy and paste script I can easily host the pano, however the issue seems to be trying to get it onto FaceBook, Facebook has created the hurdle there and unless I can get my site white listed with them and use some meta scripts there is no way I can do it, in fact I have been unable to find an example of anyone actually succeeding. So the best one can do is a link at this point, I will investigate Google+ as I'm sure they have a way.
                  • AdamBA
                    AdamB
                    Solo,
                    You can just post a URL to your website page that contains the QuickTime VR (aka .mov) file.
                    • AdamBA
                      AdamB
                      Yes, I develop websites using it and know a lot about how it works under the hood.
                      The problem is not WP or WP plugins. The problem is that browsers handle text and images using HTML, however to deliver interactive graphics they need some help - to date this has come from a "low-level" plugin that extends the functions of your browser. Adobe Flash is a common plugin of this type. Unity player is another example. LightUp WebPlayer is another example of a plugin that extends the functions of your web browser - in this case it adds functions to draw realtime 3D .luca files and know what to do when you drag and drop a .luca file on your browser.
                      However, there has been a push to ban all these plugins and require using HTML5 / WebGL. While that might be a glorious plan in Google HQ, but as Pixero points out, the reality is that not all browsers support it. So deploying interactive 3D that works everywhere is currently not possible using 1 solution.
                      WP plugins are something much lighter and just some templates that make it simple to insert content into your WP webpages that would otherwise involve cutting and pasting HTML.
                      So having a WP plugin does not solve the problem. 😞
                      • soloS
                        @adamb said:
                        Solo,
                        Sure, here is a test version on my site, I still need to do changes and add details and rooms for final.
                        There is a little noise.
                        404 Not Found
                        (www.solos-art.com)
                        • PixeroP
                          Pixero
                          Adam
                          My VR presentation runs on iOS with html5 but without web GL:
                          http://whiteclients.se/obo/vivalla/
                          • soloS
                            @pixero said:
                            Adam
                            Yours are amazing, I need to learn how to get all the fluff you have, the map and hotspots.
                            • olisheaO
                              olishea
                              stunning work pixero! bravo!
                              would be nice if we could texture bake the entire model with several spherical panoramas.
                              oli
                              • cottyC
                                cotty
                                krpano uses HTML5 (and/or webGL) too and many devices are supported this way...
                                my SketchUp gallery
                                • FrederikF
                                  Frederik
                                  It's fairly easy with Pano2VR... πŸ˜‰
                                  @Adam: I didn't know all that... I suppose I got a little confused by your comment about plugins... I interpreted it as if you didn't know what plugins does in WP... 😳 πŸ˜„
                                  Cheers
                                  Kim Frederik
                                  • PixeroP
                                    Pixero
                                    Thanks.
                                    I read some tutorials on their site and forum. Can't say it was easy to get all the different pre/after versions linked correct. The client had quite detailed wishes so I just had to get it to work. πŸ˜†
                                    The road signs on the floor I deformed in Photoshop so they kind of matched the perspective.
                                    • AdamBA
                                      AdamB
                                      @pixero said:
                                      Adam
                                      Had a quick look. Its using Adobe Flash for browsers on Desktop computers which is expected BUT amazingly for iOS it uses CSS3 😲 to get around iPad's lack of WebGL support. Clever workaround by the Pano2VR team!
                                      Adam
                                      • V
                                        valerostudio
                                        Slightly off topic, Pixero, which engine did you use to render those scenes? They are really nicely done!
                                        • PixeroP
                                          Pixero
                                          Thea. I used the TR 1 engine. It was before Presto was introduced.
                                          • V
                                            valerostudio
                                            I am also working on a project using Pano2VR and I am curious as to what resolution you render your final at and what settings you use in Pano2VR so that it loads so quickly but at such a sharp quality. Can you share a screenshot?
                                            • 2 / 3
