    360 VR questions
    extensions
    41 Posts 11 Posters 7.9k Views 11 Watching
    • AdamBA
      AdamB
      @pixero said:
      @adamb said:
      Hmm.. iPhones do not support WebGL (aka html5) and also do not support Flash. So I wonder what Pano2VR (which is a great product that I also use) outputs for phones..
      Adam
      My VR presentation runs on iOS with html5 but without web GL:
      http://whiteclients.se/obo/vivalla/
      Had a quick look. Its using Adobe Flash for browsers on Desktop computers which is expected BUT amazingly for iOS it uses CSS3 ๐Ÿ˜ฒ to get around iPad's lack of WebGL support. Clever workaround by the Pano2VR team!
      Adam
      • V
        valerostudio
        Slightly off topic, Pixero, which engine did you use to render those scenes? They are really nicely done!
        • PixeroP
          Pixero
          Thea. I used the TR 1 engine. It was before Presto was introduced.
          • V
            valerostudio
            I am also working on a project using Pano2VR and I am curious as to what resolution you render your final at and what settings you use in Pano2VR so that it loads so quickly but at such a sharp quality. Can you share a screenshot?
            • AdamBA
              AdamB
              As a rule of thumb, if you are rendering a 360 panorama, you'll want double the maximum height resolution it will be viewed at. So if you plan on viewing in a window of height 1000 pixels, the pano will need to be ~2000 high (and therefore 4000 wide).
              • PixeroP
                Pixero
                I rendered 6000x3000 pixels since you only see a small bit of the pano at a time.
                The final size of the sides in the pano cube was 1500 pixels.
                • V
                  valerostudio
                  Pixero, can you show us a screenshot of your Pano2VR Settings?
                  • PixeroP
                    Pixero
                    Sorry, but I'm swamped with work at the moment and won't have time to dig it out from backup.
                    • AdamBA
                      AdamB
                      Spent some time knocking up a plugin-free panorama viewer using CSS3 (or WebGL if supported).
                      http://light-up.co.uk/pano_test.html
                      Seems to work nicely on iPad etc. Let me know if you find a browser that doesn't work.
                      Adam
                        @adam
                        Great stuff.
                        Personally I'd change the swipe direction.
                        • FrederikF
                          Frederik
                          ๐Ÿ˜ฒ ๐Ÿ˜ฎ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                          That's awesome, Adam...!
                          http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
                          I've tested it on Firefox 29.0.1 and IE 11 v. 11.0.9600.17107 - without any issues... ๐Ÿ‘
                          So... How does this work from LightUp...?
                          I agree... Not that it matters that much - it just would make more sense... ๐Ÿ˜‰
                          Cheers
                          Kim Frederik
                          • PixeroP
                            Pixero
                            I think it is fine. ๐Ÿ‘
                            If anything an option to choose.
                            • AdamBA
                              AdamB
                              @frederik said:
                              :shock: ๐Ÿ˜ฎ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                              LightUp can output a skybox for the current view position which is directly compatible with this (test) viewer.
                              ie it can render 6 images ending in "_up", "_dn" etc. If you put them on a website you may be able to do:
                              http://light-up.co.uk/pano_test.html?p=URL_OF_YOUR_SKYBOX
                              I say "may" because modern browsers are tediously picky about cross-site loading of resources.
                              Lastly, take all your points about swipe preferences. The idea would be to turn SketchUp Scenes into hotspots - thats the weird busy icon on the floor if you're using CSS3D rendering.
                              EDIT: I've swapped swipe direction around.
                              • jo-keJ
                                jo-ke
                                @solo said:
                                I will investigate Google+ as I'm sure they have a way.
                                Just stumbled today over that interessting thread!
                                In Google+ it is possible to upload an pano directly. You have to set the file with the geodata and google+ will find out that it is a pano and will put it to its own viewer.
                                here's my example:
                                https://plus.google.com/u/0/102379974904160468503/posts/GUhgBvYh6Ff?pid=6001500064550208818%26amp;oid=102379974904160468503
                                http://www.zz7.de
                                • 2 / 3
