360 VR questions
Getting a VR to work with Wordpress is simple enough, I just upload the .mov file and using a copy and paste script I can easily host the pano, however the issue seems to be trying to get it onto FaceBook, Facebook has created the hurdle there and unless I can get my site white listed with them and use some meta scripts there is no way I can do it, in fact I have been unable to find an example of anyone actually succeeding. So the best one can do is a link at this point, I will investigate Google+ as I'm sure they have a way.
Solo,
You can just post a URL to your website page that contains the QuickTime VR (aka .mov) file.
@frederik said:
Not sure I get you here...
A plugin for WordPress isn't something special like a plugin for a browser...
Do you have any knowledge about WordPress...?Yes, I develop websites using it and know a lot about how it works under the hood.
@frederik said:
A plugin simply makes it easier for the average Joe to embed content on his/her website...
Most people are unable to make even simple web-code, thus a CMS is required...Please remember that WordPress isn't just a blog-tool... It was, but today it's nothing less than the most widely used CMS in the world...
The problem is not WP or WP plugins. The problem is that browsers handle text and images using HTML, however to deliver interactive graphics they need some help - to date this has come from a "low-level" plugin that extends the functions of your browser. Adobe Flash is a common plugin of this type. Unity player is another example. LightUp WebPlayer is another example of a plugin that extends the functions of your web browser - in this case it adds functions to draw realtime 3D .luca files and know what to do when you drag and drop a .luca file on your browser.
However, there has been a push to ban all these plugins and require using HTML5 / WebGL. While that might be a glorious plan in Google HQ, but as Pixero points out, the reality is that not all browsers support it. So deploying interactive 3D that works everywhere is currently not possible using 1 solution.
WP plugins are something much lighter and just some templates that make it simple to insert content into your WP webpages that would otherwise involve cutting and pasting HTML.
So having a WP plugin does not solve the problem.
@adamb said:
Solo,
Sure, here is a test version on my site, I still need to do changes and add details and rooms for final.
There is a little noise.
@adamb said:
Hmm.. iPhones do not support WebGL (aka html5) and also do not support Flash. So I wonder what Pano2VR (which is a great product that I also use) outputs for phones..
Adam
My VR presentation runs on iOS with html5 but without web GL:
http://whiteclients.se/obo/vivalla/ -
@pixero said:
Adam
http://whiteclients.se/obo/vivalla/Yours are amazing, I need to learn how to get all the fluff you have, the map and hotspots.
stunning work pixero! bravo!
would be nice if we could texture bake the entire model with several spherical panoramas.
http://whiteclients.se/obo/vivalla/krpano uses HTML5 (and/or webGL) too and many devices are supported this way...
Thanks.
I read some tutorials on their site and forum. Can't say it was easy to get all the different pre/after versions linked correct. The client had quite detailed wishes so I just had to get it to work.
The road signs on the floor I deformed in Photoshop so they kind of matched the perspective. -
@pixero said:
Adam
http://whiteclients.se/obo/vivalla/Had a quick look. Its using Adobe Flash for browsers on Desktop computers which is expected BUT amazingly for iOS it uses CSS3
to get around iPad's lack of WebGL support. Clever workaround by the Pano2VR team!Adam
Slightly off topic, Pixero, which engine did you use to render those scenes? They are really nicely done!
Thea. I used the TR 1 engine. It was before Presto was introduced.
I am also working on a project using Pano2VR and I am curious as to what resolution you render your final at and what settings you use in Pano2VR so that it loads so quickly but at such a sharp quality. Can you share a screenshot?
As a rule of thumb, if you are rendering a 360 panorama, you'll want double the maximum height resolution it will be viewed at. So if you plan on viewing in a window of height 1000 pixels, the pano will need to be ~2000 high (and therefore 4000 wide).
I rendered 6000x3000 pixels since you only see a small bit of the pano at a time.
The final size of the sides in the pano cube was 1500 pixels. -
Pixero, can you show us a screenshot of your Pano2VR Settings?
Sorry, but I'm swamped with work at the moment and won't have time to dig it out from backup.
Spent some time knocking up a plugin-free panorama viewer using CSS3 (or WebGL if supported).
Seems to work nicely on iPad etc. Let me know if you find a browser that doesn't work.
Adam
