    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 357.2k Views 109 Watching
      mustafa1972
      Hi Pixero
      How can I use BTW_Textures textures.
      I have copy the file in to the plugin folder
      but it dont work.
      • sdmitchS Offline
        sdmitch
        This plugin is still very much a work in progress. We will try to address all suggestions as time permits.
        http://sdmitch.blogspot.com/
        • sdmitchS Offline
          sdmitch
          @kabezoon said:
          first time it works for me... but now just crush the sketchup, even updating... any help?
          http://www.subeimagenes.com/img/captura-953712.JPG
          All pattern options or just one?
            maikoo25
            HELP!
            how do i install this plug-in if its not an rbz file?
            im using sketchup pro 2014
            • jolranJ Offline
              jolran
              maybe some of the pros could look into some speed optimisations
              Sam IS a pro. πŸ˜„
              I don't think there are massive gains to be made in that area. Adding, intersecting dense geometry within a Sketchup plugin IS a slow process. This has been discussed many times..
              Maybe in 2014, things are better, I don't know, still on 8.
              • tt_suT Offline
                tt_su
                There might be performance to gain by using the second options argument disable_ui in model.start_operation. It prevents the UI from trying to update as the model changes for the duration of the operation. Often this can give signification improvement.
                • KrisidiousK Offline
                  Krisidious
                  used this yesterday and the wood floor is spectacular... love the random imperfections option.
                  By: Kristoff Rand
                  • jolranJ Offline
                    jolran
                    Nothing slips thou past πŸ˜„
                    • tt_suT Offline
                      tt_su
                      Only thing that stood out after a quick glance at the source code.
                      • sdmitchS Offline
                        sdmitch
                        @maikoo25 said:
                        HELP!
                        If 2014 doesn't automatically create the Plugins folder, you can create it and copy plugins to
                        C;\Users\YOUR USER NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                          kabezoon
                          all patterns, all sizes and all size of faces... its weird 😐
                          • tt_suT Offline
                            tt_su
                            Are you submitting those BugSplats? Did you enter any info in the description or name that we can use to look it up?
                              lamandrion
                              @ Pixero
                              could you share your brick textures? I really like the results of your renders!
                              • PixeroP Offline
                                Pixero
                                @lamandrion said:
                                @ Pixero
                                There's a link in my first post of this thread. They are in a sub folder of the one (BTW_Textures) they should be in when used by the script.
                                (And don't forget to move any textures you DON'T want to use into a subfolder.)
                                Might be a good idea to make a shortcut to the plugins folder for easy access since you'll have to move textures in and out.
                                • JQLJ Offline
                                  JQL
                                  Sdmitch,
                                  It doesn't work well for me. I've clicked on wood, it assumed default values and the cursor changed to the face picker. I choose the face and it went on creating the floor tiles:
                                  • I couldn't change parameters at firts;
                                  • After that I couldn't use the plugin again until I restarted SU
                                  • After restart the same thing problem started all over.
                                  I hope this is a minor fix, because this is big for arch viz. If you need a video showing the steps, I'll reproduce them as they were consistently repeating.
                                  Thank you,
                                  JQL
                                  www.casca.pt
                                  Visit us on facebook!
                                  • Rich O BrienR Online
                                    @Sam
                                    I made some changes to your account privilelges.
                                    You can now visit plugins.sketchucation.com
                                    • sdmitchS Offline
                                      sdmitch
                                      @rich o brien said:
                                      @Sam
                                      Thanks Rich. Maybe I'll have this plugin done someday.
                                      • sdmitchS Offline
                                        sdmitch
                                        @jql said:
                                        Sdmitch,
                                        Thank you,
                                        JQL
                                        I think you had better do the video for me. Also, please provide info on your operating system, SketchUp version, and plugin version you are using.
                                        • sdmitchS Offline
                                          sdmitch
                                          I wish I could help you, but I don't have a clue. It has to be a something unique to you and not a common problem. What version of SketchUp are you using? Are you using a Mac or PC?
                                          • JQLJ Offline
                                            JQL
                                            Here you go,
                                            I thought this sort of info would show up in the forum (it used to):
                                            • SU 2014;
                                            • Windows 7;
                                            • Last plugin version. The first one seemed fine.
                                            I can't embed the video here so it's attached.
                                            Thanks again,
                                            JQL
                                            2014-05-06_1436.swf
                                            www.casca.pt
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
