    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 410.6k Views 109 Watching
    • sdmitchS Offline
      sdmitch
      @kabezoon said:
      first time it works for me... but now just crush the sketchup, even updating... any help?
      http://www.subeimagenes.com/img/captura-953712.JPG
      All pattern options or just one?
      http://sdmitch.blogspot.com/
        maikoo25
        HELP!
        how do i install this plug-in if its not an rbz file?
        im using sketchup pro 2014
        • jolranJ Offline
          jolran
          maybe some of the pros could look into some speed optimisations
          Sam IS a pro. πŸ˜„
          I don't think there are massive gains to be made in that area. Adding, intersecting dense geometry within a Sketchup plugin IS a slow process. This has been discussed many times..
          Maybe in 2014, things are better, I don't know, still on 8.
          • tt_suT Offline
            tt_su
            There might be performance to gain by using the second options argument disable_ui in model.start_operation. It prevents the UI from trying to update as the model changes for the duration of the operation. Often this can give signification improvement.
            • KrisidiousK Offline
              Krisidious
              used this yesterday and the wood floor is spectacular... love the random imperfections option.
              By: Kristoff Rand
              • jolranJ Offline
                jolran
                Nothing slips thou past πŸ˜„
                • tt_suT Offline
                  tt_su
                  Only thing that stood out after a quick glance at the source code.
                  • sdmitchS Offline
                    sdmitch
                    @maikoo25 said:
                    HELP!
                    If 2014 doesn't automatically create the Plugins folder, you can create it and copy plugins to
                    C;\Users\YOUR USER NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                      kabezoon
                      all patterns, all sizes and all size of faces... its weird 😐
                      • tt_suT Offline
                        tt_su
                        Are you submitting those BugSplats? Did you enter any info in the description or name that we can use to look it up?
                          lamandrion
                          @ Pixero
                          could you share your brick textures? I really like the results of your renders!
                          • PixeroP Offline
                            Pixero
                            @lamandrion said:
                            @ Pixero
                            There's a link in my first post of this thread. They are in a sub folder of the one (BTW_Textures) they should be in when used by the script.
                            (And don't forget to move any textures you DON'T want to use into a subfolder.)
                            Might be a good idea to make a shortcut to the plugins folder for easy access since you'll have to move textures in and out.
                            • JQLJ Offline
                              JQL
                              Sdmitch,
                              It doesn't work well for me. I've clicked on wood, it assumed default values and the cursor changed to the face picker. I choose the face and it went on creating the floor tiles:
                              • I couldn't change parameters at firts;
                              • After that I couldn't use the plugin again until I restarted SU
                              • After restart the same thing problem started all over.
                              I hope this is a minor fix, because this is big for arch viz. If you need a video showing the steps, I'll reproduce them as they were consistently repeating.
                              Thank you,
                              JQL
                              www.casca.pt
                              Visit us on facebook!
                                @Sam
                                I made some changes to your account privilelges.
                                You can now visit plugins.sketchucation.com
                                • sdmitchS Offline
                                  sdmitch
                                  @rich o brien said:
                                  @Sam
                                  Thanks Rich. Maybe I'll have this plugin done someday.
                                  • sdmitchS Offline
                                    sdmitch
                                    @jql said:
                                    Sdmitch,
                                    Thank you,
                                    JQL
                                    I think you had better do the video for me. Also, please provide info on your operating system, SketchUp version, and plugin version you are using.
                                    • sdmitchS Offline
                                      sdmitch
                                      I wish I could help you, but I don't have a clue. It has to be a something unique to you and not a common problem. What version of SketchUp are you using? Are you using a Mac or PC?
                                      • JQLJ Offline
                                        JQL
                                        Here you go,
                                        I thought this sort of info would show up in the forum (it used to):
                                        • SU 2014;
                                        • Windows 7;
                                        • Last plugin version. The first one seemed fine.
                                        I can't embed the video here so it's attached.
                                        Thanks again,
                                        JQL
                                        2014-05-06_1436.swf
                                        www.casca.pt
                                          cuttingedge
                                          Hi SD Mitch..Excellent , excellent , plugin, wow...this will be very useful. There are two things though. How do you control the magnitude of the imperfections. For example in the wood type, the imperfections( like the levels )are a bit to strong.
                                          The other thing is, in reality when tiles are set they are not perfectly leveled in Z , it will be most evident when you see the reflection of objects in aglossy floor. Is it possible to randomly rotate each by its center axis say about .2 to .5 degree in both x & y?
                                          This might be too much to ask.. Otherwise hey, I can do it manually...Thanks for the wonderful plugin...
                                          • sdmitchS Offline
                                            sdmitch
                                            @jql said:
                                            Here you go,
                                            • SU 2014;
                                            • Windows 7;
                                            Thanks again,
                                            JQL
                                            Since you had used a previous version, the problem may be a conflict in the stored defaults. I suggest that you select the "Reset" option at the bottom of the pattern list. This will initialize all defaults. Hopefully this will clear up the problem.
                                            • 16
                                            • 17
                                            • 3 / 17
