    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 393.8k Views 109 Watching
    • rvizR Offline
      rviz
      1. inconsistent grid origin\rotation (tried on simple cube, see pic.1)
        By design, the plugin aligns the pattern length with the longest edge of the face picked. In this case, I would undo and redo the face with 90 rotation selected.
      After 90 rotating the tool takes origins randomly: sometimes it's the upper corner, sometimes the lower one.
      But the most important: is there place for code optimization? It takes approx 5 min to put 2k tiles (to do it manually would take may be 0.5 min πŸ˜• ).
      • sdmitchS Offline
        sdmitch
        As with any plugin, if you can do it faster manually, then don't use the plugin.
        If you are using Corner origin, the corner closest to the point on the face that you pick will be used.
        http://sdmitch.blogspot.com/
        • zieiosZ Offline
          zieios
          love it.... πŸ‘
          • EarthMoverE Offline
            EarthMover
            Drooling. I've been hoping for this for a long while. Thanks Sam. Brilliant work! πŸ‘
            Content Creator at Skapeup
            • sdmitchS Offline
              sdmitch
              Yet another update!!!
                This should be available in the SCF PluginStore...
                Is it now 'stable' enough to be added ?
                • sdmitchS Offline
                  sdmitch
                  Perhaps not just yet. There will probably more pattern options added in the near future.
                  Is there a way for me to add it to the plugin store or do you have to do that?
                  • TandemT Offline
                    Tandem
                    @sdmitch said:
                    ...Is there a way for me to add it to the plugin store or do you have to do that?
                    There really should be a page or topic that explains the process of adding a plugin to the SketchUcation Plugin Store. I have searched the whole site, but could not find anything. Would be useful for developers and end users.
                      kabezoon
                      first time it works for me... but now just crush the sketchup, even updating... any help?
                      http://www.subeimagenes.com/img/captura-953712.JPG
                        mustafa1972
                        Hi Pixero
                        How can I use BTW_Textures textures.
                        I have copy the file in to the plugin folder
                        but it dont work.
                        • sdmitchS Offline
                          sdmitch
                          This plugin is still very much a work in progress. We will try to address all suggestions as time permits.
                          • sdmitchS Offline
                            sdmitch
                            All pattern options or just one?
                              maikoo25
                              HELP!
                              how do i install this plug-in if its not an rbz file?
                              im using sketchup pro 2014
                              • jolranJ Offline
                                jolran
                                maybe some of the pros could look into some speed optimisations
                                Sam IS a pro. πŸ˜„
                                I don't think there are massive gains to be made in that area. Adding, intersecting dense geometry within a Sketchup plugin IS a slow process. This has been discussed many times..
                                Maybe in 2014, things are better, I don't know, still on 8.
                                • tt_suT Offline
                                  tt_su
                                  There might be performance to gain by using the second options argument disable_ui in model.start_operation. It prevents the UI from trying to update as the model changes for the duration of the operation. Often this can give signification improvement.
                                  • KrisidiousK Offline
                                    Krisidious
                                    used this yesterday and the wood floor is spectacular... love the random imperfections option.
                                    By: Kristoff Rand
                                    • jolranJ Offline
                                      jolran
                                      Nothing slips thou past πŸ˜„
                                      • tt_suT Offline
                                        tt_su
                                        Only thing that stood out after a quick glance at the source code.
                                        • sdmitchS Offline
                                          sdmitch
                                          @maikoo25 said:
                                          HELP!
                                          If 2014 doesn't automatically create the Plugins folder, you can create it and copy plugins to
                                          C;\Users\YOUR USER NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                            kabezoon
                                            all patterns, all sizes and all size of faces... its weird 😐
                                            • 16
                                            • 17
                                            • 2 / 17
