    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 439.8k Views 109 Watching
    • sdmitchS
      sdmitch
      Yet another update!!!
      http://sdmitch.blogspot.com/
        This should be available in the SCF PluginStore...
        Is it now 'stable' enough to be added ?
        • sdmitchS
          sdmitch
          Perhaps not just yet. There will probably more pattern options added in the near future.
          Is there a way for me to add it to the plugin store or do you have to do that?
          • TandemT
            Tandem
            @sdmitch said:
            ...Is there a way for me to add it to the plugin store or do you have to do that?
            There really should be a page or topic that explains the process of adding a plugin to the SketchUcation Plugin Store. I have searched the whole site, but could not find anything. Would be useful for developers and end users.
            • K
              kabezoon
              first time it works for me... but now just crush the sketchup, even updating... any help?
              http://www.subeimagenes.com/img/captura-953712.JPG
                mustafa1972
                Hi Pixero
                How can I use BTW_Textures textures.
                I have copy the file in to the plugin folder
                but it dont work.
                • sdmitchS
                  sdmitch
                  This plugin is still very much a work in progress. We will try to address all suggestions as time permits.
                  • sdmitchS
                    sdmitch
                    All pattern options or just one?
                      maikoo25
                      HELP!
                      how do i install this plug-in if its not an rbz file?
                      im using sketchup pro 2014
                      • jolranJ
                        jolran
                        maybe some of the pros could look into some speed optimisations
                        Sam IS a pro. πŸ˜„
                        I don't think there are massive gains to be made in that area. Adding, intersecting dense geometry within a Sketchup plugin IS a slow process. This has been discussed many times..
                        Maybe in 2014, things are better, I don't know, still on 8.
                        • tt_suT
                          tt_su
                          There might be performance to gain by using the second options argument disable_ui in model.start_operation. It prevents the UI from trying to update as the model changes for the duration of the operation. Often this can give signification improvement.
                          • KrisidiousK
                            Krisidious
                            used this yesterday and the wood floor is spectacular... love the random imperfections option.
                            By: Kristoff Rand
                            • jolranJ
                              jolran
                              Nothing slips thou past πŸ˜„
                              • tt_suT
                                tt_su
                                Only thing that stood out after a quick glance at the source code.
                                • sdmitchS
                                  sdmitch
                                  @maikoo25 said:
                                  HELP!
                                  If 2014 doesn't automatically create the Plugins folder, you can create it and copy plugins to
                                  C;\Users\YOUR USER NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                  • K
                                    kabezoon
                                    all patterns, all sizes and all size of faces... its weird 😐
                                    • tt_suT
                                      tt_su
                                      Are you submitting those BugSplats? Did you enter any info in the description or name that we can use to look it up?
                                      • L
                                        lamandrion
                                        @ Pixero
                                        could you share your brick textures? I really like the results of your renders!
                                        • PixeroP
                                          Pixero
                                          @lamandrion said:
                                          @ Pixero
                                          There's a link in my first post of this thread. They are in a sub folder of the one (BTW_Textures) they should be in when used by the script.
                                          (And don't forget to move any textures you DON'T want to use into a subfolder.)
                                          Might be a good idea to make a shortcut to the plugins folder for easy access since you'll have to move textures in and out.
                                          • JQLJ
                                            JQL
                                            Sdmitch,
                                            It doesn't work well for me. I've clicked on wood, it assumed default values and the cursor changed to the face picker. I choose the face and it went on creating the floor tiles:
                                            • I couldn't change parameters at firts;
                                            • After that I couldn't use the plugin again until I restarted SU
                                            • After restart the same thing problem started all over.
                                            I hope this is a minor fix, because this is big for arch viz. If you need a video showing the steps, I'll reproduce them as they were consistently repeating.
                                            Thank you,
                                            JQL
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 16
                                            • 17
                                            • 3 / 17
