    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 461.3k Views 109 Watching
    • zieiosZ
      zieios
      love it.... πŸ‘
      • EarthMoverE
        EarthMover
        Drooling. I've been hoping for this for a long while. Thanks Sam. Brilliant work! πŸ‘
        Content Creator at Skapeup
        • sdmitchS
          sdmitch
          Yet another update!!!
          http://sdmitch.blogspot.com/
            This should be available in the SCF PluginStore...
            Is it now 'stable' enough to be added ?
            • sdmitchS
              sdmitch
              Perhaps not just yet. There will probably more pattern options added in the near future.
              Is there a way for me to add it to the plugin store or do you have to do that?
              • TandemT
                Tandem
                @sdmitch said:
                ...Is there a way for me to add it to the plugin store or do you have to do that?
                There really should be a page or topic that explains the process of adding a plugin to the SketchUcation Plugin Store. I have searched the whole site, but could not find anything. Would be useful for developers and end users.
                • K
                  kabezoon
                  first time it works for me... but now just crush the sketchup, even updating... any help?
                  http://www.subeimagenes.com/img/captura-953712.JPG
                    mustafa1972
                    Hi Pixero
                    How can I use BTW_Textures textures.
                    I have copy the file in to the plugin folder
                    but it dont work.
                    • sdmitchS
                      sdmitch
                      This plugin is still very much a work in progress. We will try to address all suggestions as time permits.
                      • sdmitchS
                        sdmitch
                        All pattern options or just one?
                          maikoo25
                          HELP!
                          how do i install this plug-in if its not an rbz file?
                          im using sketchup pro 2014
                          • jolranJ
                            jolran
                            maybe some of the pros could look into some speed optimisations
                            Sam IS a pro. πŸ˜„
                            I don't think there are massive gains to be made in that area. Adding, intersecting dense geometry within a Sketchup plugin IS a slow process. This has been discussed many times..
                            Maybe in 2014, things are better, I don't know, still on 8.
                            • tt_suT
                              tt_su
                              There might be performance to gain by using the second options argument disable_ui in model.start_operation. It prevents the UI from trying to update as the model changes for the duration of the operation. Often this can give signification improvement.
                              • KrisidiousK
                                Krisidious
                                used this yesterday and the wood floor is spectacular... love the random imperfections option.
                                By: Kristoff Rand
                                • jolranJ
                                  jolran
                                  Nothing slips thou past πŸ˜„
                                  • tt_suT
                                    tt_su
                                    Only thing that stood out after a quick glance at the source code.
                                    • sdmitchS
                                      sdmitch
                                      @maikoo25 said:
                                      HELP!
                                      If 2014 doesn't automatically create the Plugins folder, you can create it and copy plugins to
                                      C;\Users\YOUR USER NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                      • K
                                        kabezoon
                                        all patterns, all sizes and all size of faces... its weird 😐
                                        • tt_suT
                                          tt_su
                                          Are you submitting those BugSplats? Did you enter any info in the description or name that we can use to look it up?
                                          • L
                                            lamandrion
                                            @ Pixero
                                            could you share your brick textures? I really like the results of your renders!
                                            • 16
                                            • 17
                                            • 3 / 17
