    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 424.6k Views 109 Watching
    • sdmitchS Offline
      sdmitch
      @tig said:
      This should be available in the SCF PluginStore...
      Is it now 'stable' enough to be added ?
      Perhaps not just yet. There will probably more pattern options added in the near future.
      Is there a way for me to add it to the plugin store or do you have to do that?
      http://sdmitch.blogspot.com/
      • TandemT Offline
        Tandem
        @sdmitch said:
        ...Is there a way for me to add it to the plugin store or do you have to do that?
        There really should be a page or topic that explains the process of adding a plugin to the SketchUcation Plugin Store. I have searched the whole site, but could not find anything. Would be useful for developers and end users.
          kabezoon
          first time it works for me... but now just crush the sketchup, even updating... any help?
          http://www.subeimagenes.com/img/captura-953712.JPG
            mustafa1972
            Hi Pixero
            How can I use BTW_Textures textures.
            I have copy the file in to the plugin folder
            but it dont work.
            • sdmitchS Offline
              sdmitch
              This plugin is still very much a work in progress. We will try to address all suggestions as time permits.
              • sdmitchS Offline
                sdmitch
                All pattern options or just one?
                  maikoo25
                  HELP!
                  how do i install this plug-in if its not an rbz file?
                  im using sketchup pro 2014
                  • jolranJ Offline
                    jolran
                    maybe some of the pros could look into some speed optimisations
                    Sam IS a pro. πŸ˜„
                    I don't think there are massive gains to be made in that area. Adding, intersecting dense geometry within a Sketchup plugin IS a slow process. This has been discussed many times..
                    Maybe in 2014, things are better, I don't know, still on 8.
                    • tt_suT Offline
                      tt_su
                      There might be performance to gain by using the second options argument disable_ui in model.start_operation. It prevents the UI from trying to update as the model changes for the duration of the operation. Often this can give signification improvement.
                      • KrisidiousK Offline
                        Krisidious
                        used this yesterday and the wood floor is spectacular... love the random imperfections option.
                        By: Kristoff Rand
                        • jolranJ Offline
                          jolran
                          Nothing slips thou past πŸ˜„
                          • tt_suT Offline
                            tt_su
                            Only thing that stood out after a quick glance at the source code.
                            • sdmitchS Offline
                              sdmitch
                              @maikoo25 said:
                              HELP!
                              If 2014 doesn't automatically create the Plugins folder, you can create it and copy plugins to
                              C;\Users\YOUR USER NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                kabezoon
                                all patterns, all sizes and all size of faces... its weird 😐
                                • tt_suT Offline
                                  tt_su
                                  Are you submitting those BugSplats? Did you enter any info in the description or name that we can use to look it up?
                                    lamandrion
                                    @ Pixero
                                    could you share your brick textures? I really like the results of your renders!
                                    • PixeroP Offline
                                      Pixero
                                      @lamandrion said:
                                      @ Pixero
                                      There's a link in my first post of this thread. They are in a sub folder of the one (BTW_Textures) they should be in when used by the script.
                                      (And don't forget to move any textures you DON'T want to use into a subfolder.)
                                      Might be a good idea to make a shortcut to the plugins folder for easy access since you'll have to move textures in and out.
                                      • JQLJ Offline
                                        JQL
                                        Sdmitch,
                                        It doesn't work well for me. I've clicked on wood, it assumed default values and the cursor changed to the face picker. I choose the face and it went on creating the floor tiles:
                                        • I couldn't change parameters at firts;
                                        • After that I couldn't use the plugin again until I restarted SU
                                        • After restart the same thing problem started all over.
                                        I hope this is a minor fix, because this is big for arch viz. If you need a video showing the steps, I'll reproduce them as they were consistently repeating.
                                        Thank you,
                                        JQL
                                        www.casca.pt
                                        Visit us on facebook!
                                          @Sam
                                          I made some changes to your account privilelges.
                                          You can now visit plugins.sketchucation.com
                                          • sdmitchS Offline
                                            sdmitch
                                            @rich o brien said:
                                            @Sam
                                            Thanks Rich. Maybe I'll have this plugin done someday.
                                            • 16
                                            • 17
                                            • 3 / 17
