    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 439.8k Views 109 Watching
    • sdmitchS
      sdmitch
      This plugin is still very much a work in progress. We will try to address all suggestions as time permits.
      http://sdmitch.blogspot.com/
      • sdmitchS
        sdmitch
        @kabezoon said:
        first time it works for me... but now just crush the sketchup, even updating... any help?
        http://www.subeimagenes.com/img/captura-953712.JPG
        All pattern options or just one?
          maikoo25
          HELP!
          how do i install this plug-in if its not an rbz file?
          im using sketchup pro 2014
          • jolranJ
            jolran
            maybe some of the pros could look into some speed optimisations
            Sam IS a pro. πŸ˜„
            I don't think there are massive gains to be made in that area. Adding, intersecting dense geometry within a Sketchup plugin IS a slow process. This has been discussed many times..
            Maybe in 2014, things are better, I don't know, still on 8.
            • tt_suT
              tt_su
              There might be performance to gain by using the second options argument disable_ui in model.start_operation. It prevents the UI from trying to update as the model changes for the duration of the operation. Often this can give signification improvement.
              • KrisidiousK
                Krisidious
                used this yesterday and the wood floor is spectacular... love the random imperfections option.
                By: Kristoff Rand
                • jolranJ
                  jolran
                  Nothing slips thou past πŸ˜„
                  • tt_suT
                    tt_su
                    Only thing that stood out after a quick glance at the source code.
                    • sdmitchS
                      sdmitch
                      @maikoo25 said:
                      HELP!
                      If 2014 doesn't automatically create the Plugins folder, you can create it and copy plugins to
                      C;\Users\YOUR USER NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                      • K
                        kabezoon
                        all patterns, all sizes and all size of faces... its weird 😐
                        • tt_suT
                          tt_su
                          Are you submitting those BugSplats? Did you enter any info in the description or name that we can use to look it up?
                          • L
                            lamandrion
                            @ Pixero
                            could you share your brick textures? I really like the results of your renders!
                            • PixeroP
                              Pixero
                              @lamandrion said:
                              @ Pixero
                              There's a link in my first post of this thread. They are in a sub folder of the one (BTW_Textures) they should be in when used by the script.
                              (And don't forget to move any textures you DON'T want to use into a subfolder.)
                              Might be a good idea to make a shortcut to the plugins folder for easy access since you'll have to move textures in and out.
                              • JQLJ
                                JQL
                                Sdmitch,
                                It doesn't work well for me. I've clicked on wood, it assumed default values and the cursor changed to the face picker. I choose the face and it went on creating the floor tiles:
                                • I couldn't change parameters at firts;
                                • After that I couldn't use the plugin again until I restarted SU
                                • After restart the same thing problem started all over.
                                I hope this is a minor fix, because this is big for arch viz. If you need a video showing the steps, I'll reproduce them as they were consistently repeating.
                                Thank you,
                                JQL
                                www.casca.pt
                                Visit us on facebook!
                                  @Sam
                                  I made some changes to your account privilelges.
                                  You can now visit plugins.sketchucation.com
                                  • sdmitchS
                                    sdmitch
                                    @rich o brien said:
                                    @Sam
                                    Thanks Rich. Maybe I'll have this plugin done someday.
                                    • sdmitchS
                                      sdmitch
                                      @jql said:
                                      Sdmitch,
                                      Thank you,
                                      JQL
                                      I think you had better do the video for me. Also, please provide info on your operating system, SketchUp version, and plugin version you are using.
                                      • sdmitchS
                                        sdmitch
                                        I wish I could help you, but I don't have a clue. It has to be a something unique to you and not a common problem. What version of SketchUp are you using? Are you using a Mac or PC?
                                        • JQLJ
                                          JQL
                                          Here you go,
                                          I thought this sort of info would show up in the forum (it used to):
                                          • SU 2014;
                                          • Windows 7;
                                          • Last plugin version. The first one seemed fine.
                                          I can't embed the video here so it's attached.
                                          Thanks again,
                                          JQL
                                          2014-05-06_1436.swf
                                          www.casca.pt
                                          • C
                                            cuttingedge
                                            Hi SD Mitch..Excellent , excellent , plugin, wow...this will be very useful. There are two things though. How do you control the magnitude of the imperfections. For example in the wood type, the imperfections( like the levels )are a bit to strong.
                                            The other thing is, in reality when tiles are set they are not perfectly leveled in Z , it will be most evident when you see the reflection of objects in aglossy floor. Is it possible to randomly rotate each by its center axis say about .2 to .5 degree in both x & y?
                                            This might be too much to ask.. Otherwise hey, I can do it manually...Thanks for the wonderful plugin...
                                            • 16
                                            • 17
                                            • 3 / 17
