    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 52.5k Views 14 Watching
    • G
      Gábor
      The main problem is that in case of Mac we do not have the menu name at the beginning of each action, so the Javascript and maybe also the HTML has to be prepared first to handle this situation. The javascript populates the paragraphs based on the menuname what is missing in case of MAC. More tomorrow.
        driven
        @tig said:
        BUT... do you have any idea why on my MAC Sketchup.get_shortcuts returns [] - so that myscuts == "" - unless I have used one shortcut before that, then it works ?
        on my mac it works from the off...
        ...and, I do have a 'hunch',
        I may depend on some of your startup 'Preferences'...
        I think SU is using these send_actions internally for those as well and 'that' triggers the plist read...
        try enabling 'Auto activate paint tool' and see if they appear...
        I can't get it to revert to 'not' showing...
          We'll Skype on Monday morning [UK time] 😒
          • G
            Gábor
            Version 0.2.0 is out now in the pluginstore. It addresses the MAC issue. MAC users, please test.
              driven
              getting there...no picture'gram' for ⌃ which is labeled as Opt, but is Control
              • G
                Gábor
                @driven said:
                getting there...
                Thanks for the tests and advices. Now my only concern is: How does that ^Opt got there and what does it mean? Any clue?
                  driven
                  ruby returns this "⌃⌥⇧T\tviewTop:"
                  on a mac
                  ⌘ . . . . . ⌘ . . . Command, Cmd, Clover, (formerly) Apple
                  ⌃ . . . . . ⌃ . . . Control, Ctl, Ctrl
                  ⌥ . . . . . ⌥ . . . Option, Opt, (Windows) Alt
                  ⇧ . . . . . ⇧ . . . Shift
                    Doh!
                    My fault... 😒
                    Muddled up the modifier key coding...
                    Preparing v0.3.0 which will fix the missing Ctrl !
                    Gábor - you'll need to redo the symbol mapping for Ctl/Opt/Cmd and Ashift ...
                    Update should be ready tomorrow...
                    • G
                      Gábor
                      OK, we will deal with it tomorrow. Now I have other stufff to complete. Sorry.
                        driven
                        far more worrying...
                        I edited my Preferences to remove that one, as it didn't work anyway
                        [you can't even add them with more than one modifier anymore]
                        after a restart, I'm back to a unfilled dialog...
                        removed and re-downloaded... still blank
                        are you modifying live?
                        EDIT: got them back...
                        it seems after removing a shortcut, the .get_shortcut returns [] [TIG's issue...]
                        you have to make a new one and use it, before SU reports it and all the others...
                        very odd
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          It would be great to be able to edit the shortcuts right inside SU.
                          • G
                            Gábor
                            It's among the plans for further dev.
                              Yes once we get it working acceptably on PC & MAC [coming soon 😉 ], then we plan to look at editing and 'syncing' of your shortcuts across your Computers/SketchUpVersions... but that's in the future...
                              • G
                                Gábor
                                Version 0.3.0 is in the pluginstore now. The new version addressed several MAC related issues found in 0.2.0. Please test. Especially MAC users.
                                  Version 0.3.1 is in the PluginStore.
                                  It address a known problem with MACs - where the native method Sketchup.get_shortcuts erroneously returns [] if you have not used a shortcut during that SketchUp session.
                                  To prevent empty list getting made the Shortcuts.plist is now read in directly and the dialog is compiled using that data...
                                  Can you all please install this update in case it has broken something else - it has already been tested on various SketchUp versions, and on PC and MAC - but you never know... 😕
                                  • KrisidiousK
                                    Krisidious
                                    So let's see some shortcuter file sharing...
                                    By: Kristoff Rand
                                    • JQLJ
                                      JQL
                                      Hi guys!
                                      Any news on the ability to transfer shortcuts from windows to mac?
                                      It would be very handy...
                                      Thanks and best regards,
                                      JQL
                                      www.casca.pt
                                      Visit us on facebook!
                                        Working hard at v3 and under the hood stuff.
                                        • JQLJ
                                          JQL
                                          Thanks for the update Rich!
                                          www.casca.pt
                                          • P
                                            Pherim
                                            The Plugins Menu was renamed to Extensions in SU2015, and Shortcutter does not recognize it any more and does not display the Shortcuts assigned to functions in it.
                                            • 3 / 5
