    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 53.9k Views 14 Watching
      FWIW, this is what I get on my Mac after clearing the Safari caches. I do have shortcuts established.
        Yep, in MAC is it's foobar... 😒
        I suspect it's the special-characters that MACs use for the modifier keys...
        Those will break the server's JS...
        Gábor and I need to look at it tomorrow...
          driven
          I did try
          			myscuts = (Sketchup.get_shortcuts.to_s.gsub(/⌃/,'Ctrl').gsub(/⌥/,'Alt').gsub(/⇧/,'Shift').split(',').sort.join("\\n"))
          which almost works on the ruby side if I encode the page UTF-8,
            "AltT\tdoThreeDText;"\n "B\tselectPaintTool;"\n "C\tselectCircleTool;"\n "CtrlAltShiftT\tviewTop;"\n["Space\tselectSelectionTool;"
          the last entry for Space is screwed up, and then I get a load error on the html...
            Yes, the script must be encoded as UTF-8-without-BOM to be fully compatible with all versions of SketchUp - I was surprised it hadn't broken v2.14 Ruby2... 😒
            Try this
            myscuts = Sketchup.get_shortcuts.sort.join("\\n").gsub(/#{'⌃'}/, 'Ctrl').gsub(/#{'⌥'}/, 'Alt').gsub(/#{'⇧'}/, 'Shift')
            Should perhaps work for MACs ?
            It is something like I am going to test with Gábor tomorrow...
            BUT... do you have any idea why on my MAC Sketchup.get_shortcuts returns [] - so that myscuts == "" - unless I have used one shortcut before that, then it works ?
            • G
              Gábor
              The main problem is that in case of Mac we do not have the menu name at the beginning of each action, so the Javascript and maybe also the HTML has to be prepared first to handle this situation. The javascript populates the paragraphs based on the menuname what is missing in case of MAC. More tomorrow.
                driven
                on my mac it works from the off...
                ...and, I do have a 'hunch',
                I may depend on some of your startup 'Preferences'...
                I think SU is using these send_actions internally for those as well and 'that' triggers the plist read...
                try enabling 'Auto activate paint tool' and see if they appear...
                I can't get it to revert to 'not' showing...
                  We'll Skype on Monday morning [UK time] 😒
                  • G
                    Gábor
                    Version 0.2.0 is out now in the pluginstore. It addresses the MAC issue. MAC users, please test.
                      driven
                      getting there...no picture'gram' for ⌃ which is labeled as Opt, but is Control
                      • G
                        Gábor
                        @driven said:
                        getting there...
                        Thanks for the tests and advices. Now my only concern is: How does that ^Opt got there and what does it mean? Any clue?
                          driven
                          ruby returns this "⌃⌥⇧T\tviewTop:"
                          on a mac
                          ⌘ . . . . . ⌘ . . . Command, Cmd, Clover, (formerly) Apple
                          ⌃ . . . . . ⌃ . . . Control, Ctl, Ctrl
                          ⌥ . . . . . ⌥ . . . Option, Opt, (Windows) Alt
                          ⇧ . . . . . ⇧ . . . Shift
                            Doh!
                            My fault... 😒
                            Muddled up the modifier key coding...
                            Preparing v0.3.0 which will fix the missing Ctrl !
                            Gábor - you'll need to redo the symbol mapping for Ctl/Opt/Cmd and Ashift ...
                            Update should be ready tomorrow...
                            • G
                              Gábor
                              OK, we will deal with it tomorrow. Now I have other stufff to complete. Sorry.
                                driven
                                far more worrying...
                                I edited my Preferences to remove that one, as it didn't work anyway
                                [you can't even add them with more than one modifier anymore]
                                after a restart, I'm back to a unfilled dialog...
                                removed and re-downloaded... still blank
                                are you modifying live?
                                EDIT: got them back...
                                it seems after removing a shortcut, the .get_shortcut returns [] [TIG's issue...]
                                you have to make a new one and use it, before SU reports it and all the others...
                                very odd
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  It would be great to be able to edit the shortcuts right inside SU.
                                  • G
                                    Gábor
                                    It's among the plans for further dev.
                                      Yes once we get it working acceptably on PC & MAC [coming soon 😉 ], then we plan to look at editing and 'syncing' of your shortcuts across your Computers/SketchUpVersions... but that's in the future...
                                      • G
                                        Gábor
                                        Version 0.3.0 is in the pluginstore now. The new version addressed several MAC related issues found in 0.2.0. Please test. Especially MAC users.
                                          Version 0.3.1 is in the PluginStore.
                                          It address a known problem with MACs - where the native method Sketchup.get_shortcuts erroneously returns [] if you have not used a shortcut during that SketchUp session.
                                          To prevent empty list getting made the Shortcuts.plist is now read in directly and the dialog is compiled using that data...
                                          Can you all please install this update in case it has broken something else - it has already been tested on various SketchUp versions, and on PC and MAC - but you never know... 😕
                                          • KrisidiousK
                                            Krisidious
                                            So let's see some shortcuter file sharing...
                                            By: Kristoff Rand
                                            • 3 / 5
