    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 49.3k Views 14 Watching
      Doh!
      My fault... 😒
      Muddled up the modifier key coding...
      Preparing v0.3.0 which will fix the missing Ctrl !
      Gábor - you'll need to redo the symbol mapping for Ctl/Opt/Cmd and Ashift ...
      Update should be ready tomorrow...
        Gábor
        OK, we will deal with it tomorrow. Now I have other stufff to complete. Sorry.
          driven
          far more worrying...
          I edited my Preferences to remove that one, as it didn't work anyway
          [you can't even add them with more than one modifier anymore]
          after a restart, I'm back to a unfilled dialog...
          removed and re-downloaded... still blank
          are you modifying live?
          EDIT: got them back...
          it seems after removing a shortcut, the .get_shortcut returns [] [TIG's issue...]
          you have to make a new one and use it, before SU reports it and all the others...
          very odd
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            It would be great to be able to edit the shortcuts right inside SU.
              Gábor
              It's among the plans for further dev.
                Yes once we get it working acceptably on PC & MAC [coming soon 😉 ], then we plan to look at editing and 'syncing' of your shortcuts across your Computers/SketchUpVersions... but that's in the future...
                  Gábor
                  Version 0.3.0 is in the pluginstore now. The new version addressed several MAC related issues found in 0.2.0. Please test. Especially MAC users.
                    Version 0.3.1 is in the PluginStore.
                    It address a known problem with MACs - where the native method Sketchup.get_shortcuts erroneously returns [] if you have not used a shortcut during that SketchUp session.
                    To prevent empty list getting made the Shortcuts.plist is now read in directly and the dialog is compiled using that data...
                    Can you all please install this update in case it has broken something else - it has already been tested on various SketchUp versions, and on PC and MAC - but you never know... 😕
                    • KrisidiousK Offline
                      Krisidious
                      So let's see some shortcuter file sharing...
                      By: Kristoff Rand
                      • JQLJ Offline
                        JQL
                        Hi guys!
                        Any news on the ability to transfer shortcuts from windows to mac?
                        It would be very handy...
                        Thanks and best regards,
                        JQL
                        www.casca.pt
                        Visit us on facebook!
                          Working hard at v3 and under the hood stuff.
                          • JQLJ Offline
                            JQL
                            Thanks for the update Rich!
                            www.casca.pt
                              Pherim
                              The Plugins Menu was renamed to Extensions in SU2015, and Shortcutter does not recognize it any more and does not display the Shortcuts assigned to functions in it.
                                Thanks for flagging it.
                                  We are working on it !
                                    driven
                                    @ tig
                                    the mac code I used was
                                    require "pathname"
                                    target = Pathname(Sketchup.find_support_files("").grep(/User/)[0]).parent
                                    shortcuts = Pathname(target + "Shortcuts.plist")
                                    File.write(shortcuts,File.open(shortcuts,&;read).gsub("Plugins","Extensions")) if File.exists?(shortcuts)
                                    that's taken out of a general migration assistant but it should work stand-alone...
                                      It needs a minor adjustment server-side to parse for "^Extensions/|^Plugins/" - Gábor is on to it...
                                      It ought to work on PC or MAC as the string passed from the Ruby-side is the same...
                                        Can I ask someone to report what you now see in the Shortcutter dialog in SketchUp 2015?
                                          Krisidious
                                          Looks like this on Win 7 in SU 2015 64bit
                                          By: Kristoff Rand
                                          • BoxB Offline
                                            • 3 / 5
