    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 49.3k Views 14 Watching
      Gábor
      Version 0.2.0 is out now in the pluginstore. It addresses the MAC issue. MAC users, please test.
        driven
        getting there...no picture'gram' for ⌃ which is labeled as Opt, but is Control
          Gábor
          @driven said:
          getting there...
          Thanks for the tests and advices. Now my only concern is: How does that ^Opt got there and what does it mean? Any clue?
            driven
            ruby returns this "⌃⌥⇧T\tviewTop:"
            on a mac
            ⌘ . . . . . ⌘ . . . Command, Cmd, Clover, (formerly) Apple
            ⌃ . . . . . ⌃ . . . Control, Ctl, Ctrl
            ⌥ . . . . . ⌥ . . . Option, Opt, (Windows) Alt
            ⇧ . . . . . ⇧ . . . Shift
              Doh!
              My fault... 😒
              Muddled up the modifier key coding...
              Preparing v0.3.0 which will fix the missing Ctrl !
              Gábor - you'll need to redo the symbol mapping for Ctl/Opt/Cmd and Ashift ...
              Update should be ready tomorrow...
                Gábor
                OK, we will deal with it tomorrow. Now I have other stufff to complete. Sorry.
                  driven
                  far more worrying...
                  I edited my Preferences to remove that one, as it didn't work anyway
                  [you can't even add them with more than one modifier anymore]
                  after a restart, I'm back to a unfilled dialog...
                  removed and re-downloaded... still blank
                  are you modifying live?
                  EDIT: got them back...
                  it seems after removing a shortcut, the .get_shortcut returns [] [TIG's issue...]
                  you have to make a new one and use it, before SU reports it and all the others...
                  very odd
                  • jiminy-billy-bobJ Offline
                    jiminy-billy-bob
                    It would be great to be able to edit the shortcuts right inside SU.
                      Gábor
                      It's among the plans for further dev.
                        Yes once we get it working acceptably on PC & MAC [coming soon 😉 ], then we plan to look at editing and 'syncing' of your shortcuts across your Computers/SketchUpVersions... but that's in the future...
                          Gábor
                          Version 0.3.0 is in the pluginstore now. The new version addressed several MAC related issues found in 0.2.0. Please test. Especially MAC users.
                            Version 0.3.1 is in the PluginStore.
                            It address a known problem with MACs - where the native method Sketchup.get_shortcuts erroneously returns [] if you have not used a shortcut during that SketchUp session.
                            To prevent empty list getting made the Shortcuts.plist is now read in directly and the dialog is compiled using that data...
                            Can you all please install this update in case it has broken something else - it has already been tested on various SketchUp versions, and on PC and MAC - but you never know... 😕
                            • KrisidiousK Offline
                              Krisidious
                              So let's see some shortcuter file sharing...
                              By: Kristoff Rand
                              • JQLJ Offline
                                JQL
                                Hi guys!
                                Any news on the ability to transfer shortcuts from windows to mac?
                                It would be very handy...
                                Thanks and best regards,
                                JQL
                                www.casca.pt
                                Visit us on facebook!
                                  Working hard at v3 and under the hood stuff.
                                  • JQLJ Offline
                                    JQL
                                    Thanks for the update Rich!
                                    www.casca.pt
                                      Pherim
                                      The Plugins Menu was renamed to Extensions in SU2015, and Shortcutter does not recognize it any more and does not display the Shortcuts assigned to functions in it.
                                        Thanks for flagging it.
                                          We are working on it !
                                            driven
                                            @ tig
                                            the mac code I used was
                                            require "pathname"
                                            target = Pathname(Sketchup.find_support_files("").grep(/User/)[0]).parent
                                            shortcuts = Pathname(target + "Shortcuts.plist")
                                            File.write(shortcuts,File.open(shortcuts,&;read).gsub("Plugins","Extensions")) if File.exists?(shortcuts)
                                            that's taken out of a general migration assistant but it should work stand-alone...
                                            • 3 / 5
