    Finding reversed faces after texturing?
    25 Posts 9 Posters 1.9k Views 9 Watching
    • KrisidiousK
      Krisidious
      I use Tig's method with magenta and tan. makes reversed faces easy to see.
      By: Kristoff Rand
        I also use TIG's method and have my default style set up so a green I'd never use in modeling is my back face color.
          AirWindSolar
          That helps a lot. Now I just need a quicker way to switch; I generally use just shaded w/texture, hidden line, and now "backface finder," and it would be really handy if I could cycle through those with a toolbar button or something, without having to keep the style window open among the clutter on my other screen.
          • BoxB
            That's one use for scenes. You can create scenes with different styles so you can quickly flick to monochrome or any other you want.
            • fredo6F
              You may wish to use also FredoTools::ReverseOrientFaces. It switches to monochrome and allow to pick / reverse face or do that in a bulk mode (that is extend orientation to all neighbours from the orientation of the face picked).
                I guess I've never found the Face Style toolbar to be all that difficult.
                If you just work in Monochrome mode in the first place and fix face orientation as you go, you shouldn't need to be bouncing between face styles anyway.
                • N
                  numerobis
                  same here πŸ˜‰ i use a neon green as backside material and a bright pink/purple as selection colour.
                  • KrisidiousK
                    Krisidious
                    [attachment=0:w3mazxtm]<!-- ia0 -->2014-04-08_15-01-48.png<!-- ia0 -->[/attachment:w3mazxtm]
                    I use that as well, but I find it often isn't enough to really see all of the small backfaces in the tight spots. Magenta sings...
                    And then there is the mysterious faces that get reversed unbeknownst to you...
                    By: Kristoff Rand
                      @krisidious said:
                      [attachment=0:j20cqzan]<!-- ia0 -->2014-04-08_15-01-48.png<!-- ia0 -->[/attachment:j20cqzan]
                      Why isn't it enough? Monochrome face style is the style that shows you face orientation.
                      @krisidious said:
                      Magenta sings...
                      Yes it does. I used to use magenta but I found the green I use now easier on the eyes and I can still see it when it is only a few pixels wide.
                      But if you are working in Monochrome face style, there's no reason to miss reversed faces when they occur.
                      • KrisidiousK
                        Krisidious
                        In my monochrome the backface is colored close to shadow color, Such as under eaves and in my 3D rocks and stone. When in tight spots it's often hard to see.
                        When they occur, yes... unless they occur after modeling and during tweaking. When you go into edit something, or if you eve make the mistake of hitting "orient faces"...
                        By: Kristoff Rand
                        • BoxB
                          I think you are missing the point, the back face default colour should be obvious so that while in Monochrome you can see it. Having your default backface similar to the shadow colour defeats the purpose.
                            Kris, I think you are confusing Monochrome and Hidden Line face styles.
                            Monochrome (with my green back face color)
                            Hidden Line. No face orientation information.
                              mac1
                              The entity info dialog will also show the front and back colors and you can even reverse those from there . However, that reversal does not reverse faces but can be very useful ,as noted in one of the SCF tuts, to show misapplication of component texture form the wrong context. To reverse face it needs to be done by the reverse face command. For small holes even change in color is not 100%. It is useful to mouse over model and watch for flashes at various orbits and help in IDing those.
                              • KrisidiousK
                                Krisidious
                                Lol... no, I'm not.
                                how many backfaces do you see?
                                By: Kristoff Rand
                                • pbacotP
                                  Where did you get such powers. I have not the time to even try all the plugins you've made.
                                    @krisidious said:
                                    Lol... no, I'm not.
                                    [attachment=0:3ipp4prq]<!-- ia0 -->backfaces.JPG<!-- ia0 -->[/attachment:3ipp4prq]
                                    If you've got the backface color set to magenta as you've said before AND you have exposed back faces AND you are showing us your model using Monochrome face style, there would be magenta showing. If you have applied some other color/material AND you are showing us a Shaded or Shaded with Textures face style, the magenta faces would be masked.
                                    By itself that screen shot doesn't give us enough information about the settings you are using. Show us a screen shot of the Faces settings in the Styles window. Also show the Background settings.
                                    • KrisidiousK
                                      Krisidious
                                      You are supposed to guess the number of backfaces showing first. then I show you the magenta. So you can agree with me that monochome alone is not sufficient for quick work.
                                      By: Kristoff Rand
                                        Kris, I don't have time for a game. You are not using Monochrome face style with the back face color set to magenta as you claimed earlier that you do. Either you are using Hidden Line face style with the background color set to something other than white or, if you are using Monochrome face style, you've set the back face color to the same color as the front face color.
                                        Hidden Line with Background Color Changed and Sky enabled.
                                        Monochrome with same Background color as above and Sky enabled.
                                        • KrisidiousK
                                          Krisidious
                                          My two natural faces are light tan and dark grey because I prefer it on my eyes and I can see most backfaces easily. but when I want to really search for backfaces I use my backface style.
                                          and here's the other's settings
                                          By: Kristoff Rand
                                            AirWindSolar
                                            Problem is I have idiots over my shoulder all the time, so everything has to be color coded right away to reduce the "what size is that?" interruptions.
