    [Plugin] Face2Frame - Updated 27-Mar-2014
    66 Posts 19 Posters 66.8k Views 19 Watching
    • sdmitchS
      sdmitch
      Just posted an update to Face2Frame. Now does floors, faces on the XY plane, and adds "X"s to ends of studs, headers and/or joist.
      http://sdmitch.blogspot.com/
      • LAUFERONL
        LAUFERON
        I'm french and i'd like the same famous plugin in metric units !
        A dream for woodworkers....
        • sdmitchS
          sdmitch
          Sorry, I don't do metric.
            You can 'metricate' it relatively easily...
            @wall_type = "Ext" #unless @wall_type
            @stud_size = "2X4" #unless @stud_size;
            @stud_space=16.inch #unless @stud_space
            @header_size = "2X8" #unless @header_size
            @corner_type = "A"
            @thickness=0.0
            could become
            @stud_size = "50mmX100mm" #unless @stud_size;
            @stud_space=400.mm #unless @stud_space
            @header_size = "50mmX200mm" #unless @header_size
            @corner_type = "A"
            @thickness=0.mm
            Then in the html code... make similar edits so
            <option value='2X2'>2x2</option>
            <option value='16\"' selected>16\"</option>
            becomes
            <option value='50mmX50mm'>50mmx50mm</option>
            <option value='400mm' selected>400mm</option>
            and so on...
            Now the cases for the stud sizes...
            case @stud_size when "2X2" : dx = 1.500.inch; dy = 1.500.inch;
            becomes
            case @stud_size when "50mmX50mm" ; dx = 38.mm; dy = 38.mm;
            OR whatever...
            Fix all 8 or so of those sizes...
            unless @wall_type=="Int" || (@stud_size!="2X4" && @stud_size!="2X6") case @stud_size when "2X4" case @corner_type when "A" ; studs=self.A_2X4(xa,ya,p,v,dx,dy)
            Needs to be looked at...
            unless @wall_type=="Int" || (@stud_size!="50mmX100mm" && @stud_size!="50mmX150mm") case @stud_size when "50mmX100mm" case @corner_type when "A" ; studs=self.A_50mmX100mm(xa,ya,p,v,dx,dy)
            Then rename the matching
            def A_2X4(vx,vy,p,v,dx,dy)
            as
            def A_50mmX100mm(vx,vy,p,v,dx,dy)
            etc
            The parts like 1/2" plywood spacer need 0.5 replacing with 12.mm or whatever is the equivalent ?
            Parts of the code like dx+0.01 which add a 1/100" spacing could be adjusted to 0.25.mm or some other small metric equivalent ?
            As can [ruby:13xikt90]dx2-0.02[/ruby:13xikt90] to be [ruby:13xikt90]dx2-0.5.mm[/ruby:13xikt90]
            It just a matter of steps through every line and deciding what is needed...
            • KrisidiousK
              Krisidious
              Counting in multiples and intervals of 10 is sorcery... Witch craft I say! Someone get a rope and a rock.
              By: Kristoff Rand
              • V
                virtualelvis
                What am I doing wrong? I cannot figure out how to find this
                plugin to use it..
                I put it in my plugins folder.. but I can't figure out how to use it...
                I looked under draw and plugins...
                thanks for helping a noob.. d
                • KrisidiousK
                  Krisidious
                  Go to Plugins>SDM Tools>Face Tool>Face2Frame
                  By: Kristoff Rand
                  • sdmitchS
                    sdmitch
                    Updated to be SU2014 compatible.
                      I've added it to the PluginStore.
                      http://sketchucation.com/pluginstore?pln=Face_to_Frame
                      • KrisidiousK
                        Krisidious
                        Not using 2014 yet, but thanks for the work guys...
                        By: Kristoff Rand
                        • utilerU
                          utiler
                          Hi Sam, I note above you said you haven't considered converting this plugin for metric use and TIG has outlined how to 'metricate' it. I'm a little unsure how this is done; Do I try and open the script and edit it? A little risky given I nothing about coding....
                          Cheers.
                          Just Curious...
                          • PixeroP
                            Pixero
                            You could try opening it in a texteditor. I use Notepad++.
                            Set the language to Ruby and try to find the lines described by TIG.
                            • sdmitchS
                              sdmitch
                              Cheers.
                              Better leave it to the "professionals". I'll take a look at it and PM you a copy to try.
                              • utilerU
                                utiler
                                Thanks for the vote of confidence, Pixero but I'm likely to blow it up.... πŸ˜†
                                Just Curious...
                                • B
                                  billmorr
                                  Is it just me or has this plug in stopped working in Sketchup Pro 2017???
                                  • sdmitchS
                                    sdmitch
                                    @billmorr said:
                                    No it's not just you. SU2017 strikes again. I will try to fix the problem if I can.
                                    • sdmitchS
                                      sdmitch
                                      @billmorr said:
                                      Face to Frame updated for SU2017 compatibility. Download new version for PluginStore or blog.
                                      • 3 / 4
