    [Plugin] Face2Frame - Updated 27-Mar-2014
    66 Posts 19 Posters 59.5k Views 19 Watching
    • KrisidiousK Offline
      Krisidious
      @mics_54 said:
      I haven't laminated headers in a decades...energy efficiency dictates 4x10 or 4x12 headers with 2 inches of foam insulation or spray foam on fully sheathed structures.
      Rich Boy... 🀣
      By: Kristoff Rand
        Krisidious
        I must admit I have not framed a house in probably 20 years and I don't provide framing details as framers from different areas do things differently and I assume know their trade better than I. So I would defer to those who know better.
        By: Kristoff Rand
          mics_54
          You're warm weather too...I do arctic construction.
          • gullfoG Offline
            gullfo
            i wasn't sure if that was a laminate or not but it's ok. in general, i see a lot of newer construction with the laminated i-beam for the headers (similar to floors and rafters) and a foam fill. i think the headers work as-is and folks can draw any details necessary to describe their preferred approach πŸ˜„ it would be really cool if you could "x" the ends of the lumber so a 2D / wireframe view can show it like a construction plan would...
            Glenn
            http://www.runnel.com
              Krisidious
              I considered that X as well, but not only at the ends but two faces all the way through studs, so that any stud in any location would show in sections as such. It would jump the polys up quite a bit but I don't think that would be a very big issue.
              By: Kristoff Rand
              • sdmitchS Offline
                sdmitch
                Just posted an update to Face2Frame. Now does floors, faces on the XY plane, and adds "X"s to ends of studs, headers and/or joist.
                http://sdmitch.blogspot.com/
                • LAUFERONL Offline
                  LAUFERON
                  I'm french and i'd like the same famous plugin in metric units !
                  A dream for woodworkers....
                  • sdmitchS Offline
                    sdmitch
                    Sorry, I don't do metric.
                      You can 'metricate' it relatively easily...
                      @wall_type = "Ext" #unless @wall_type
                      @stud_size = "2X4" #unless @stud_size;
                      @stud_space=16.inch #unless @stud_space
                      @header_size = "2X8" #unless @header_size
                      @corner_type = "A"
                      @thickness=0.0
                      could become
                      @stud_size = "50mmX100mm" #unless @stud_size;
                      @stud_space=400.mm #unless @stud_space
                      @header_size = "50mmX200mm" #unless @header_size
                      @corner_type = "A"
                      @thickness=0.mm
                      Then in the html code... make similar edits so
                      <option value='2X2'>2x2</option>
                      <option value='16\"' selected>16\"</option>
                      becomes
                      <option value='50mmX50mm'>50mmx50mm</option>
                      <option value='400mm' selected>400mm</option>
                      and so on...
                      Now the cases for the stud sizes...
                      case @stud_size when "2X2" : dx = 1.500.inch; dy = 1.500.inch;
                      becomes
                      case @stud_size when "50mmX50mm" ; dx = 38.mm; dy = 38.mm;
                      OR whatever...
                      Fix all 8 or so of those sizes...
                      unless @wall_type=="Int" || (@stud_size!="2X4" && @stud_size!="2X6") case @stud_size when "2X4" case @corner_type when "A" ; studs=self.A_2X4(xa,ya,p,v,dx,dy)
                      Needs to be looked at...
                      unless @wall_type=="Int" || (@stud_size!="50mmX100mm" && @stud_size!="50mmX150mm") case @stud_size when "50mmX100mm" case @corner_type when "A" ; studs=self.A_50mmX100mm(xa,ya,p,v,dx,dy)
                      Then rename the matching
                      def A_2X4(vx,vy,p,v,dx,dy)
                      as
                      def A_50mmX100mm(vx,vy,p,v,dx,dy)
                      etc
                      The parts like 1/2" plywood spacer need 0.5 replacing with 12.mm or whatever is the equivalent ?
                      Parts of the code like dx+0.01 which add a 1/100" spacing could be adjusted to 0.25.mm or some other small metric equivalent ?
                      As can [ruby:13xikt90]dx2-0.02[/ruby:13xikt90] to be [ruby:13xikt90]dx2-0.5.mm[/ruby:13xikt90]
                      It just a matter of steps through every line and deciding what is needed...
                        Krisidious
                        Counting in multiples and intervals of 10 is sorcery... Witch craft I say! Someone get a rope and a rock.
                        By: Kristoff Rand
                        • V Offline
                          virtualelvis
                          What am I doing wrong? I cannot figure out how to find this
                          plugin to use it..
                          I put it in my plugins folder.. but I can't figure out how to use it...
                          I looked under draw and plugins...
                          thanks for helping a noob.. d
                            Krisidious
                            Go to Plugins>SDM Tools>Face Tool>Face2Frame
                            By: Kristoff Rand
                            • sdmitchS Offline
                              sdmitch
                              Updated to be SU2014 compatible.
                                I've added it to the PluginStore.
                                http://sketchucation.com/pluginstore?pln=Face_to_Frame
                                  Krisidious
                                  Not using 2014 yet, but thanks for the work guys...
                                  By: Kristoff Rand
                                  • utilerU Offline
                                    utiler
                                    Hi Sam, I note above you said you haven't considered converting this plugin for metric use and TIG has outlined how to 'metricate' it. I'm a little unsure how this is done; Do I try and open the script and edit it? A little risky given I nothing about coding....
                                    Cheers.
                                    Just Curious...
                                    • PixeroP Offline
                                      Pixero
                                      You could try opening it in a texteditor. I use Notepad++.
                                      Set the language to Ruby and try to find the lines described by TIG.
                                      • sdmitchS Offline
                                        sdmitch
                                        Cheers.
                                        Better leave it to the "professionals". I'll take a look at it and PM you a copy to try.
                                        • utilerU Offline
                                          utiler
                                          Thanks for the vote of confidence, Pixero but I'm likely to blow it up.... πŸ˜†
                                          Just Curious...
                                            billmorr
                                            Is it just me or has this plug in stopped working in Sketchup Pro 2017???
                                            • 3 / 4
