    [Plugin] Face2Frame - Updated 27-Mar-2014
    66 Posts 19 Posters 64.3k Views 19 Watching
    • sdmitchS Offline
      sdmitch
      I'm really not 100% sure where I found the sign function but I believe it was in the Ruby Console. Apparently I typed something like sign(-5) and it returned -1 so I assumed that it was a common function. I do have Ruby 1.8.6 installed so maybe that's why it works for me.
      http://sdmitch.blogspot.com/
        I too get sign() in the RC... but with a standard SUp-Ruby only installation and DCs etc disabled I still get it.
        And it's not deined in any .rb files I have loading...
        So I must assume that there a .rbs file loading from somewhere that adds the global method...
        The alternative 'standard' way of n<=>0 is easy enough though...
        Another one that sometimes trips up scripters is group.definition [which is needed for adding instances of a group into another entities context etc, when 'copying' or 'moving' it to mimic Copy/Cut/Paste_In_Place...] - the method component_instance.definition does return the component's definition and some 3rd party tools add group.definition to the mix... but if you use that method and the recipient of your script hasn't got the other 3rd party script that adds it, then they'll get errors. The 'safe' way is to use group.entities.parent which returns that group's definition properly...
        • gullfoG Offline
          gullfo
          this is a very cool script! 😍 attached are a couple of examples of it in use. couple of things - the header spacing looks like there is overlap. also, after using the tool it's somewhat arbitrary if the dialog comes back or not πŸ˜• in example #1 i'd also tried to use it on a floor and on a ceiling. it's mostly there. in example #2 i tried to use it for a "soffit" and the vertical bits work as expected but the horizontal ones (like #1) are not computing right. this is definitely a great bit of work however it ends!
          face 2 frame example 1.skp
          face 2 frame example 2.skp
          Glenn
          http://www.runnel.com
          • sdmitchS Offline
            sdmitch
            Given the fact that the plugin was designed for vertical walls, I'm not surprised that it had a problem with floors and ceilings.
            The apparent overlap of the headers is the 3/4" plywood spacer between the headers.
            • KrisidiousK Offline
              Krisidious
              Yes that was my addition... Here in America on the jobs that I've worked we use Plywood in our headers.
              http://biytoday.com/header.jpg
              By: Kristoff Rand
                mics_54
                I haven't laminated headers in a decades...energy efficiency dictates 4x10 or 4x12 headers with 2 inches of foam insulation or spray foam on fully sheathed structures.
                  Krisidious
                  Rich Boy... 🀣
                  By: Kristoff Rand
                    Krisidious
                    I must admit I have not framed a house in probably 20 years and I don't provide framing details as framers from different areas do things differently and I assume know their trade better than I. So I would defer to those who know better.
                    By: Kristoff Rand
                      mics_54
                      You're warm weather too...I do arctic construction.
                      • gullfoG Offline
                        gullfo
                        i wasn't sure if that was a laminate or not but it's ok. in general, i see a lot of newer construction with the laminated i-beam for the headers (similar to floors and rafters) and a foam fill. i think the headers work as-is and folks can draw any details necessary to describe their preferred approach πŸ˜„ it would be really cool if you could "x" the ends of the lumber so a 2D / wireframe view can show it like a construction plan would...
                        Glenn
                          Krisidious
                          I considered that X as well, but not only at the ends but two faces all the way through studs, so that any stud in any location would show in sections as such. It would jump the polys up quite a bit but I don't think that would be a very big issue.
                          By: Kristoff Rand
                          • sdmitchS Offline
                            sdmitch
                            Just posted an update to Face2Frame. Now does floors, faces on the XY plane, and adds "X"s to ends of studs, headers and/or joist.
                            • LAUFERONL Offline
                              LAUFERON
                              I'm french and i'd like the same famous plugin in metric units !
                              A dream for woodworkers....
                              • sdmitchS Offline
                                sdmitch
                                Sorry, I don't do metric.
                                  You can 'metricate' it relatively easily...
                                  @wall_type = "Ext" #unless @wall_type
                                  @stud_size = "2X4" #unless @stud_size;
                                  @stud_space=16.inch #unless @stud_space
                                  @header_size = "2X8" #unless @header_size
                                  @corner_type = "A"
                                  @thickness=0.0
                                  could become
                                  @stud_size = "50mmX100mm" #unless @stud_size;
                                  @stud_space=400.mm #unless @stud_space
                                  @header_size = "50mmX200mm" #unless @header_size
                                  @corner_type = "A"
                                  @thickness=0.mm
                                  Then in the html code... make similar edits so
                                  <option value='2X2'>2x2</option>
                                  <option value='16\"' selected>16\"</option>
                                  becomes
                                  <option value='50mmX50mm'>50mmx50mm</option>
                                  <option value='400mm' selected>400mm</option>
                                  and so on...
                                  Now the cases for the stud sizes...
                                  case @stud_size when "2X2" : dx = 1.500.inch; dy = 1.500.inch;
                                  becomes
                                  case @stud_size when "50mmX50mm" ; dx = 38.mm; dy = 38.mm;
                                  OR whatever...
                                  Fix all 8 or so of those sizes...
                                  unless @wall_type=="Int" || (@stud_size!="2X4" && @stud_size!="2X6") case @stud_size when "2X4" case @corner_type when "A" ; studs=self.A_2X4(xa,ya,p,v,dx,dy)
                                  Needs to be looked at...
                                  unless @wall_type=="Int" || (@stud_size!="50mmX100mm" && @stud_size!="50mmX150mm") case @stud_size when "50mmX100mm" case @corner_type when "A" ; studs=self.A_50mmX100mm(xa,ya,p,v,dx,dy)
                                  Then rename the matching
                                  def A_2X4(vx,vy,p,v,dx,dy)
                                  as
                                  def A_50mmX100mm(vx,vy,p,v,dx,dy)
                                  etc
                                  The parts like 1/2" plywood spacer need 0.5 replacing with 12.mm or whatever is the equivalent ?
                                  Parts of the code like dx+0.01 which add a 1/100" spacing could be adjusted to 0.25.mm or some other small metric equivalent ?
                                  As can [ruby:13xikt90]dx2-0.02[/ruby:13xikt90] to be [ruby:13xikt90]dx2-0.5.mm[/ruby:13xikt90]
                                  It just a matter of steps through every line and deciding what is needed...
                                    Krisidious
                                    Counting in multiples and intervals of 10 is sorcery... Witch craft I say! Someone get a rope and a rock.
                                    By: Kristoff Rand
                                    • V Offline
                                      virtualelvis
                                      What am I doing wrong? I cannot figure out how to find this
                                      plugin to use it..
                                      I put it in my plugins folder.. but I can't figure out how to use it...
                                      I looked under draw and plugins...
                                      thanks for helping a noob.. d
                                        Krisidious
                                        Go to Plugins>SDM Tools>Face Tool>Face2Frame
                                        By: Kristoff Rand
                                        • sdmitchS Offline
                                          sdmitch
                                          Updated to be SU2014 compatible.
                                            I've added it to the PluginStore.
                                            http://sketchucation.com/pluginstore?pln=Face_to_Frame
                                            • 3 / 4
