    [Plugin] Face2Frame - Updated 27-Mar-2014
    66 Posts 19 Posters 66.8k Views 19 Watching
    • KrisidiousK
      Krisidious
      @gullfo said:
      i wasn't sure if that was a laminate or not but it's ok. in general, i see a lot of newer construction with the laminated i-beam for the headers (similar to floors and rafters) and a foam fill. i think the headers work as-is and folks can draw any details necessary to describe their preferred approach πŸ˜„ it would be really cool if you could "x" the ends of the lumber so a 2D / wireframe view can show it like a construction plan would...
      I considered that X as well, but not only at the ends but two faces all the way through studs, so that any stud in any location would show in sections as such. It would jump the polys up quite a bit but I don't think that would be a very big issue.
      By: Kristoff Rand
      • sdmitchS
        sdmitch
        Just posted an update to Face2Frame. Now does floors, faces on the XY plane, and adds "X"s to ends of studs, headers and/or joist.
        http://sdmitch.blogspot.com/
        • LAUFERONL
          LAUFERON
          I'm french and i'd like the same famous plugin in metric units !
          A dream for woodworkers....
          • sdmitchS
            sdmitch
            Sorry, I don't do metric.
              You can 'metricate' it relatively easily...
              @wall_type = "Ext" #unless @wall_type
              @stud_size = "2X4" #unless @stud_size;
              @stud_space=16.inch #unless @stud_space
              @header_size = "2X8" #unless @header_size
              @corner_type = "A"
              @thickness=0.0
              could become
              @stud_size = "50mmX100mm" #unless @stud_size;
              @stud_space=400.mm #unless @stud_space
              @header_size = "50mmX200mm" #unless @header_size
              @corner_type = "A"
              @thickness=0.mm
              Then in the html code... make similar edits so
              <option value='2X2'>2x2</option>
              <option value='16\"' selected>16\"</option>
              becomes
              <option value='50mmX50mm'>50mmx50mm</option>
              <option value='400mm' selected>400mm</option>
              and so on...
              Now the cases for the stud sizes...
              case @stud_size when "2X2" : dx = 1.500.inch; dy = 1.500.inch;
              becomes
              case @stud_size when "50mmX50mm" ; dx = 38.mm; dy = 38.mm;
              OR whatever...
              Fix all 8 or so of those sizes...
              unless @wall_type=="Int" || (@stud_size!="2X4" && @stud_size!="2X6") case @stud_size when "2X4" case @corner_type when "A" ; studs=self.A_2X4(xa,ya,p,v,dx,dy)
              Needs to be looked at...
              unless @wall_type=="Int" || (@stud_size!="50mmX100mm" && @stud_size!="50mmX150mm") case @stud_size when "50mmX100mm" case @corner_type when "A" ; studs=self.A_50mmX100mm(xa,ya,p,v,dx,dy)
              Then rename the matching
              def A_2X4(vx,vy,p,v,dx,dy)
              as
              def A_50mmX100mm(vx,vy,p,v,dx,dy)
              etc
              The parts like 1/2" plywood spacer need 0.5 replacing with 12.mm or whatever is the equivalent ?
              Parts of the code like dx+0.01 which add a 1/100" spacing could be adjusted to 0.25.mm or some other small metric equivalent ?
              As can [ruby:13xikt90]dx2-0.02[/ruby:13xikt90] to be [ruby:13xikt90]dx2-0.5.mm[/ruby:13xikt90]
              It just a matter of steps through every line and deciding what is needed...
              • KrisidiousK
                Krisidious
                Counting in multiples and intervals of 10 is sorcery... Witch craft I say! Someone get a rope and a rock.
                By: Kristoff Rand
                • V
                  virtualelvis
                  What am I doing wrong? I cannot figure out how to find this
                  plugin to use it..
                  I put it in my plugins folder.. but I can't figure out how to use it...
                  I looked under draw and plugins...
                  thanks for helping a noob.. d
                  • KrisidiousK
                    Krisidious
                    Go to Plugins>SDM Tools>Face Tool>Face2Frame
                    By: Kristoff Rand
                    • sdmitchS
                      sdmitch
                      Updated to be SU2014 compatible.
                        I've added it to the PluginStore.
                        http://sketchucation.com/pluginstore?pln=Face_to_Frame
                        • KrisidiousK
                          Krisidious
                          Not using 2014 yet, but thanks for the work guys...
                          By: Kristoff Rand
                          • utilerU
                            utiler
                            Hi Sam, I note above you said you haven't considered converting this plugin for metric use and TIG has outlined how to 'metricate' it. I'm a little unsure how this is done; Do I try and open the script and edit it? A little risky given I nothing about coding....
                            Cheers.
                            Just Curious...
                            • PixeroP
                              Pixero
                              You could try opening it in a texteditor. I use Notepad++.
                              Set the language to Ruby and try to find the lines described by TIG.
                              • sdmitchS
                                sdmitch
                                Cheers.
                                Better leave it to the "professionals". I'll take a look at it and PM you a copy to try.
                                • utilerU
                                  utiler
                                  Thanks for the vote of confidence, Pixero but I'm likely to blow it up.... πŸ˜†
                                  Just Curious...
                                  • B
                                    billmorr
                                    Is it just me or has this plug in stopped working in Sketchup Pro 2017???
                                    • sdmitchS
                                      sdmitch
                                      @billmorr said:
                                      No it's not just you. SU2017 strikes again. I will try to fix the problem if I can.
                                      • sdmitchS
                                        sdmitch
                                        @billmorr said:
                                        Face to Frame updated for SU2017 compatibility. Download new version for PluginStore or blog.
                                        • 3 / 4
