    [Plugin] Face2Frame - Updated 27-Mar-2014
    66 Posts 19 Posters 65.8k Views 19 Watching
      mics_54
      I haven't laminated headers in a decades...energy efficiency dictates 4x10 or 4x12 headers with 2 inches of foam insulation or spray foam on fully sheathed structures.
      • KrisidiousK Offline
        Krisidious
        Rich Boy... 🀣
        By: Kristoff Rand
          Krisidious
          I must admit I have not framed a house in probably 20 years and I don't provide framing details as framers from different areas do things differently and I assume know their trade better than I. So I would defer to those who know better.
          By: Kristoff Rand
            mics_54
            You're warm weather too...I do arctic construction.
            • gullfoG Offline
              gullfo
              i wasn't sure if that was a laminate or not but it's ok. in general, i see a lot of newer construction with the laminated i-beam for the headers (similar to floors and rafters) and a foam fill. i think the headers work as-is and folks can draw any details necessary to describe their preferred approach πŸ˜„ it would be really cool if you could "x" the ends of the lumber so a 2D / wireframe view can show it like a construction plan would...
              Glenn
              http://www.runnel.com
                Krisidious
                I considered that X as well, but not only at the ends but two faces all the way through studs, so that any stud in any location would show in sections as such. It would jump the polys up quite a bit but I don't think that would be a very big issue.
                By: Kristoff Rand
                • sdmitchS Offline
                  sdmitch
                  Just posted an update to Face2Frame. Now does floors, faces on the XY plane, and adds "X"s to ends of studs, headers and/or joist.
                  http://sdmitch.blogspot.com/
                  • LAUFERONL Offline
                    LAUFERON
                    I'm french and i'd like the same famous plugin in metric units !
                    A dream for woodworkers....
                    • sdmitchS Offline
                      sdmitch
                      Sorry, I don't do metric.
                        You can 'metricate' it relatively easily...
                        @wall_type = "Ext" #unless @wall_type
                        @stud_size = "2X4" #unless @stud_size;
                        @stud_space=16.inch #unless @stud_space
                        @header_size = "2X8" #unless @header_size
                        @corner_type = "A"
                        @thickness=0.0
                        could become
                        @stud_size = "50mmX100mm" #unless @stud_size;
                        @stud_space=400.mm #unless @stud_space
                        @header_size = "50mmX200mm" #unless @header_size
                        @corner_type = "A"
                        @thickness=0.mm
                        Then in the html code... make similar edits so
                        <option value='2X2'>2x2</option>
                        <option value='16\"' selected>16\"</option>
                        becomes
                        <option value='50mmX50mm'>50mmx50mm</option>
                        <option value='400mm' selected>400mm</option>
                        and so on...
                        Now the cases for the stud sizes...
                        case @stud_size when "2X2" : dx = 1.500.inch; dy = 1.500.inch;
                        becomes
                        case @stud_size when "50mmX50mm" ; dx = 38.mm; dy = 38.mm;
                        OR whatever...
                        Fix all 8 or so of those sizes...
                        unless @wall_type=="Int" || (@stud_size!="2X4" && @stud_size!="2X6") case @stud_size when "2X4" case @corner_type when "A" ; studs=self.A_2X4(xa,ya,p,v,dx,dy)
                        Needs to be looked at...
                        unless @wall_type=="Int" || (@stud_size!="50mmX100mm" && @stud_size!="50mmX150mm") case @stud_size when "50mmX100mm" case @corner_type when "A" ; studs=self.A_50mmX100mm(xa,ya,p,v,dx,dy)
                        Then rename the matching
                        def A_2X4(vx,vy,p,v,dx,dy)
                        as
                        def A_50mmX100mm(vx,vy,p,v,dx,dy)
                        etc
                        The parts like 1/2" plywood spacer need 0.5 replacing with 12.mm or whatever is the equivalent ?
                        Parts of the code like dx+0.01 which add a 1/100" spacing could be adjusted to 0.25.mm or some other small metric equivalent ?
                        As can [ruby:13xikt90]dx2-0.02[/ruby:13xikt90] to be [ruby:13xikt90]dx2-0.5.mm[/ruby:13xikt90]
                        It just a matter of steps through every line and deciding what is needed...
                          Krisidious
                          Counting in multiples and intervals of 10 is sorcery... Witch craft I say! Someone get a rope and a rock.
                          By: Kristoff Rand
                          • V Offline
                            virtualelvis
                            What am I doing wrong? I cannot figure out how to find this
                            plugin to use it..
                            I put it in my plugins folder.. but I can't figure out how to use it...
                            I looked under draw and plugins...
                            thanks for helping a noob.. d
                              Krisidious
                              Go to Plugins>SDM Tools>Face Tool>Face2Frame
                              By: Kristoff Rand
                              • sdmitchS Offline
                                sdmitch
                                Updated to be SU2014 compatible.
                                  I've added it to the PluginStore.
                                  http://sketchucation.com/pluginstore?pln=Face_to_Frame
                                    Krisidious
                                    Not using 2014 yet, but thanks for the work guys...
                                    By: Kristoff Rand
                                    • utilerU Offline
                                      utiler
                                      Hi Sam, I note above you said you haven't considered converting this plugin for metric use and TIG has outlined how to 'metricate' it. I'm a little unsure how this is done; Do I try and open the script and edit it? A little risky given I nothing about coding....
                                      Cheers.
                                      Just Curious...
                                      • PixeroP Offline
                                        Pixero
                                        You could try opening it in a texteditor. I use Notepad++.
                                        Set the language to Ruby and try to find the lines described by TIG.
                                        • sdmitchS Offline
                                          sdmitch
                                          Cheers.
                                          Better leave it to the "professionals". I'll take a look at it and PM you a copy to try.
                                          • utilerU Offline
                                            utiler
                                            Thanks for the vote of confidence, Pixero but I'm likely to blow it up.... πŸ˜†
                                            Just Curious...
                                            • 3 / 4
