    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • cottyC Offline
      cotty
      I'm not sure but I think the mentioned ZLoader... is not a part of an actual RoundCorner installation. Did you downloaded the actual one?
      my SketchUp gallery
      • fredo6F Offline
        @panixia,
        Please do not modify the code or you'll get unexpected results.
        By default for FredoTools and Curvizard, only the quick launcher is visible.
        Go the Default Parameters dialog box of each of the plugin to make the icons visible for the Tools you wish.
          Tim, you shouldn't be unzipping anything. I would suggest that you remove any and all of the files you unzipped into the Plugins folder and then download fresh, current copies as .rbz files and use Install Extension under Window>Preferences>Extensions to install them. Or better, use that method to install the Sketchucation Plugin Store and then use the Plugin Store to automatically install LibFredo6 and Round Corner.
          • fredo6F Offline
            @Tim Deaves
            You seem to have a very old version of RoundCorner, and on top of that probably not well installed.
            Please download the latest one.
            My suggestion is that you use the Plugin Store tool for auto-installation.
            • fredo6F Offline
              @panixia,
              Could you check the value of ENV["LOCALAPPDATA"] in the Ruby console.
              In principle the configuration file is stored in a subfolder LIBFREDO6_DATA_Dir of this directory.
              If ENV["LOCALAPPDATA"] is not defined, then it deafult to the temp directory, which, with your RAM disk is erased when you exit. So everything is lost.
                Tim Deaves
                Thanks Fredo. You were correct. All sorted now.
                Tim
                • panixiaP Offline
                  panixia
                  @fredo6 said:
                  @panixia,
                  first of all thanks for your answer.
                  I typed ENV["LOCALAPPDATA"] this returns me C:\Users\Panixia\AppData\Local
                  I tryed to copy the folder LIBFREDO6_DATA_Dir into it, but this doesn't work and sketchup loads with thrupaint and curvizard buttons missing.. maybe i'm doing something wrong. 😢
                  the most effective workaround i found so far is to place on desktop a link to ramdisk and a copy of LIBFREDO6_DATA_Dir (whith proper default parameters stored) to drag and drop into before i first run sketchup.. a bit dirty but all in all it works fine.. 😄
                  • fredo6F Offline
                    The subfolder is created if it does not exist in ../local. Is this the case, or do you have permissions set that prevents it?
                      allor27
                      Hi I´v been trying to get the plugin on sketch up whole week and I still don´t get it it has driven me crazy! I downloaded the plugin and extracted it to plugin folder also as i installed it from the warehouse. Still I don't get it in my toolbar. What have I missed?
                      • BoxB Offline
                        From the first post of the thread.
                        LibFredo6 is a shared library used by some of my plugins. It is NOT a standalone plugin. Plugins currently using LibFredo6 are:
                        FredoScale
                        Tools on Surface
                        RoundCorner
                        Curviloft
                        HoverSelect
                        GhostComp
                        SUClock
                        FredoTools
                        Curvizard
                        TopoShaper
                        JointPushPull Interactive
                        Which means there is nothing to appear in any toolbars, it is a helper file that works with other plugins.
                        You need to install the other plugins for it to have any purpose.
                          paul brown
                          I am getting this error loading issue with Fredo6 on 2014 installing the plugin from Sketchucation. Anything that can be done?
                          • fredo6F Offline
                            Paul,
                            It just menas that on your installation, one or several of my plugins have not been upgraded to latest version compatible with SU 14.
                            Please check
                              paul brown
                              Have reinstalled all the Fredo plugins from Sketchucation and from Extension warehouse, same result. Have disabled all other plugins, same result. Installed Libfredo on its own. no problem, installed any of the other plugins in any order same results. They all give similar error messages. Ran Sketchup as administrator, same result (using windows 7 64bit). Disabled all the virus protection, same result. Don't know where else to go.
                              • fredo6F Offline
                                Paul,
                                You have a wrong file somewhere among my plugins (i.e. not encoded for UTF8), and it is most likely a file with extension .plugin.
                                It may be a files remaining from an old installation.
                                I suggest you clean up the folders and subfolders of my plugins, and then reinstall from with the PluginStore tool.
                                  Try the following...
                                  In SketchUp 2014 > Ruby Console:
                                  result?
                                  Sketchup.find_support_file('Plugins')
                                  result?
                                  It should be something like:
                                  C:/Users/PaulB/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                                  Sketchup.find_support_file('Plugins').encoding
                                  result?
                                  With admin powers, open the Plugins folder returned by this.
                                  Back up one step and select its icon...
                                  Right-click > Context-menu > Properties > Security > Edit...
                                  Should be preset to the default FULL - if not change it...
                                  Find the Sketchup.exe file in the main C:/Programs Files/SketchUp/SketchUp 2014/ folder...
                                  Right-click > Context-menu > Properties > Compatibility > Privilege Level pane > tick the 'Run this program as an administrator' option
                                  Find the Lib Fredo .rb and subfolder and physically remove it from Plugins.
                                  This ensures a fresh install with no incompatible files left around...
                                  Install the latest version of it either from the RBZ using Preferences > Extensions > Install... button, or using the SketchUcation PluginStore dialog within SketchUp...
                                  Restart SketchUp...
                                  Report results...
                                  NEVER install older versions from say v2013 Plugins or an older RBZ - get the latest versions, which are specifically updated to be v2014 compatible.
                                  Try the equivalent manual removal for any Fredo plugins, and reinstall then one at a time from their latest RBZs until you get an issue - then report back... 😕
                                    paul brown
                                    My installations are all the latest versions. I have deleted ALL my plugins all fredo directories and files and reinstalled just LibFredo and Fredo Scale from the extension warehouse, same result. Have enabled Sketchup to run as administrator, the default in the folder is set to full. I'll do a clean install of Sketchup 2014.
                                      Those results are expected.
                                      No issues.
                                      Are you sure you have deleted all of the Plugins from the 2104 Plugins folder 😕
                                      Delete ALL of the Fredo folders/files [again!].
                                      Restart SketchUp 2014.
                                      You should now only get the basic su_ files loading...
                                      Download the SketchUcation Plugin Store toolset...
                                      http://sketchucation.com/resources/plugin-store-download
                                      Install it using the Preferences > Extensions > Install... button...
                                      Restart SketchUp to make sure it completes the installation...
                                      Use the SketchUcation PluginStore [within SketchUp] to AutoInstall the 'Lib Fredo'...
                                      Tip: use the disalog's filters/search tools to find its AutoInstall entry.
                                      Next do the same to AutoInstall one of Fredo's plugins [like Fredo Scale].
                                      Now what happens ?
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v5.8c - 17 Apr 14
                                        LibFredo6 5.8c is a release for MoveAlong 1.0, which is just published as part of FredTools 1.8c.
                                        • bobpineoB Offline
                                          bobpineo
                                          Hello Fredo,
                                          Love your Plugins, thank you!
                                          I keep getting this message..."libfredo6 will be updated at next startup of sketchup.
                                          I have tried reloading, deleting obsolete files etc etc.
                                          Can you help me figure out what is going on?
                                          Best BP
                                          plus the following:(after I get the initial libfredo update warning.
                                          Error Loading File C:/Users/Bob/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DBUR_UcsManager/dbur_ucs
                                          Could not find included file 'C:/Users/Bob/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/DBUR_UcsManager/dbur_ucs'
                                          Error Loading File C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager/DBUR_UcsManager.rb
                                          Error: #<NameError: uninitialized constant DBUR_Ucs>
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager/DBUR_UcsManager.rb:10:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager.rb:12:in register_extension'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager.rb:12:in <top (required)>' Error: c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: invalid multibyte char (UTF-8) c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: invalid multibyte char (UTF-8) c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: syntax error, unexpected end-of-input, expecting keyword_end data="90¡M5lªÙ[:}¶šä^Ÿ-Ú¢ßÓjt@+¡©t›p}x±" #just garbage ^ C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:in eval'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:in load' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:in module:Artisan'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:3:in <module:DM>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:1:in <top (required)>'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:18:in register_extension' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:18:in module:Artisan'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:5:in <module:DM>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:4:in <top (required)>'
                                          Error Loading File Fredo6_!LibFredo6.rb
                                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:368:in match' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:368:in block (2 levels) in load_from_config'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:367:in each' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:367:in block in load_from_config'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:366:in foreach' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:366:in load_from_config'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:726:in block in load_all_plugins' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:726:in each'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:726:in load_all_plugins' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6/Lib6Core.rb:438:in load_from_config'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6.rb:181:in startup' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6.rb:299:in module:LibFredo6'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Fredo6_!LibFredo6.rb:31:in <top (required)>' Error Loading File C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx/landfx_loader.rb Error: #<TypeError: no implicit conversion of nil into String> C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx/landfx_loader.rb:1:in load'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx/landfx_loader.rb:1:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx.rb:9:in register_extension'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lfx_Landfx.rb:9:in <top (required)>' Error: #<NoMethodError: undefined method downcase' for nil:NilClass>
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/Sketchup.rb:36:in file_loaded?' c:/program files (x86)/sketchup/sketchup 2014/tools/piga_richsection/richsection.rbs:997:in module:RSection'
                                          c:/program files (x86)/sketchup/sketchup 2014/tools/piga_richsection/richsection.rbs:65:in <module:PiGa>' c:/program files (x86)/sketchup/sketchup 2014/tools/piga_richsection/richsection.rbs:64:in <main>'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in eval' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/PiGa_RichSection.rb:37:in register_extension'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/PiGa_RichSection.rb:37:in <module:RSection>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/PiGa_RichSection.rb:26:in module:PiGa'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/PiGa_RichSection.rb:25:in <top (required)>' Error: #<Errno::ENOENT: No such file or directory - C:/Users/Bob/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Oscar/OSC_Language.lag> c:/program files (x86)/sketchup/sketchup 2014/tools/oscoolean.rbs:790:in readlines'
                                          c:/program files (x86)/sketchup/sketchup 2014/tools/oscoolean.rbs:790:in filter_texts' c:/program files (x86)/sketchup/sketchup 2014/tools/oscoolean.rbs:806:in class:OSCtb'
                                          c:/program files (x86)/sketchup/sketchup 2014/tools/oscoolean.rbs:780:in <main>' -e:1:in eval'
                                          Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                                            Hi Bob, you've got a lot of errors there and not all are related to Fredo's work. Is it possible you copied plugins from an older SketchUp version? I've got many of those same plugins installed on my PC and I don't get those errors.
                                            Make sure you have the most current versions installed.
                                            • 108
                                            • 109
                                            • 7 / 109
