    [Plugin Library] LibFredo6 - v16.3a - 20 Oct 26
    2.3k Posts 587 Posters 11.9m Views 589 Watching
    • panixiaP
      panixia
      i added "MYPLUGIN.default_icons_visible" :smooth_curve in "bootstrap_curvizard.rb" and it worked great.. 😍
      then in fredotools.rb i tried :
      "MYPLUGIN.default_icons_visible [:FredoTools_ThruPaint]
      MYPLUGIN.default_icons_visible [:FredoTools_EdgeInspector]
      MYPLUGIN.default_icons_visible [:FredoTools_Report_LabelArea]"
      and it crashes the plugin at all and also pretty much crashes a lot of other scripts such as curviloft etc
      • T
        Tim Deaves
        I'm a newbie to SU and not much of a techie. I have SU 14.0.4900 and Windows 7 (SP 1). I live in Canada and I have an issue installing RoundCorners.
        I think I have installed LibFredo6 5.7a correctly as I can see it in SU/Windows/LibFredo 6 Settings, etc. SU starts up OK with no error messages.
        I then installed RoundCorner and when starting SU I get the following error messages;
        "Error Loading File Fredo6_!LibFredo6.rb
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        C:/Users/Tim Deaves/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:368:in match' C:/Users/Tim Deaves/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:368:in block (2 levels) in load_from_config'
        . (Similar messages)
        Error Loading File ZLoader__RoundCorner.rb
        Error: C:/Users/Tim Deaves/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:32: invalid multibyte char (UTF-8)
        C:/Users/Tim Deaves/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:32: syntax error, unexpected tIDENTIFIER, expecting keyword_end
        text = "Problème avec l'installation du plugin #{fro6__plugin}"
        C:/Users/Tim Deaves/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:33: syntax error, unexpected tIDENTIFIER, expecting keyword_end
        text += "\nLibFredo6 n'est pas install\é ou bien n'est ...
        C:/Users/Tim Deaves/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:33: syntax error, unexpected $undefined
        ..."\nLibFredo6 n'est pas install\é ou bien n'est pas dans le b...
        C:/Users/Tim Deaves/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ZLoader__RoundCorner.rb:33: invalid multibyte char (UTF-8)"
        I have unzipped RoundCorner in file folder ROUNDCORNER_Dir_23 in C:\Users\Tim Deaves\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins - together with the Fredo6_!LibFredo6 file folder.
        Thanks for your help.
        Tim
        • cottyC
          cotty
          I'm not sure but I think the mentioned ZLoader... is not a part of an actual RoundCorner installation. Did you downloaded the actual one?
          my SketchUp gallery
          • fredo6F
            @panixia,
            Please do not modify the code or you'll get unexpected results.
            By default for FredoTools and Curvizard, only the quick launcher is visible.
            Go the Default Parameters dialog box of each of the plugin to make the icons visible for the Tools you wish.
              Tim, you shouldn't be unzipping anything. I would suggest that you remove any and all of the files you unzipped into the Plugins folder and then download fresh, current copies as .rbz files and use Install Extension under Window>Preferences>Extensions to install them. Or better, use that method to install the Sketchucation Plugin Store and then use the Plugin Store to automatically install LibFredo6 and Round Corner.
              • fredo6F
                @Tim Deaves
                You seem to have a very old version of RoundCorner, and on top of that probably not well installed.
                Please download the latest one.
                My suggestion is that you use the Plugin Store tool for auto-installation.
                • fredo6F
                  @panixia,
                  Could you check the value of ENV["LOCALAPPDATA"] in the Ruby console.
                  In principle the configuration file is stored in a subfolder LIBFREDO6_DATA_Dir of this directory.
                  If ENV["LOCALAPPDATA"] is not defined, then it deafult to the temp directory, which, with your RAM disk is erased when you exit. So everything is lost.
                  • T
                    Tim Deaves
                    Thanks Fredo. You were correct. All sorted now.
                    Tim
                    • panixiaP
                      panixia
                      @fredo6 said:
                      @panixia,
                      first of all thanks for your answer.
                      I typed ENV["LOCALAPPDATA"] this returns me C:\Users\Panixia\AppData\Local
                      I tryed to copy the folder LIBFREDO6_DATA_Dir into it, but this doesn't work and sketchup loads with thrupaint and curvizard buttons missing.. maybe i'm doing something wrong. 😢
                      the most effective workaround i found so far is to place on desktop a link to ramdisk and a copy of LIBFREDO6_DATA_Dir (whith proper default parameters stored) to drag and drop into before i first run sketchup.. a bit dirty but all in all it works fine.. 😄
                      • fredo6F
                        The subfolder is created if it does not exist in ../local. Is this the case, or do you have permissions set that prevents it?
                          allor27
                          Hi I´v been trying to get the plugin on sketch up whole week and I still don´t get it it has driven me crazy! I downloaded the plugin and extracted it to plugin folder also as i installed it from the warehouse. Still I don't get it in my toolbar. What have I missed?
                          • BoxB
                            From the first post of the thread.
                            LibFredo6 is a shared library used by some of my plugins. It is NOT a standalone plugin. Plugins currently using LibFredo6 are:
                            FredoScale
                            Tools on Surface
                            RoundCorner
                            Curviloft
                            HoverSelect
                            GhostComp
                            SUClock
                            FredoTools
                            Curvizard
                            TopoShaper
                            JointPushPull Interactive
                            Which means there is nothing to appear in any toolbars, it is a helper file that works with other plugins.
                            You need to install the other plugins for it to have any purpose.
                            • P
                              paul brown
                              I am getting this error loading issue with Fredo6 on 2014 installing the plugin from Sketchucation. Anything that can be done?
                              • fredo6F
                                Paul,
                                It just menas that on your installation, one or several of my plugins have not been upgraded to latest version compatible with SU 14.
                                Please check
                                • P
                                  paul brown
                                  Have reinstalled all the Fredo plugins from Sketchucation and from Extension warehouse, same result. Have disabled all other plugins, same result. Installed Libfredo on its own. no problem, installed any of the other plugins in any order same results. They all give similar error messages. Ran Sketchup as administrator, same result (using windows 7 64bit). Disabled all the virus protection, same result. Don't know where else to go.
                                  • fredo6F
                                    Paul,
                                    You have a wrong file somewhere among my plugins (i.e. not encoded for UTF8), and it is most likely a file with extension .plugin.
                                    It may be a files remaining from an old installation.
                                    I suggest you clean up the folders and subfolders of my plugins, and then reinstall from with the PluginStore tool.
                                      Try the following...
                                      In SketchUp 2014 > Ruby Console:
                                      result?
                                      Sketchup.find_support_file('Plugins')
                                      result?
                                      It should be something like:
                                      C:/Users/PaulB/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                                      Sketchup.find_support_file('Plugins').encoding
                                      result?
                                      With admin powers, open the Plugins folder returned by this.
                                      Back up one step and select its icon...
                                      Right-click > Context-menu > Properties > Security > Edit...
                                      Should be preset to the default FULL - if not change it...
                                      Find the Sketchup.exe file in the main C:/Programs Files/SketchUp/SketchUp 2014/ folder...
                                      Right-click > Context-menu > Properties > Compatibility > Privilege Level pane > tick the 'Run this program as an administrator' option
                                      Find the Lib Fredo .rb and subfolder and physically remove it from Plugins.
                                      This ensures a fresh install with no incompatible files left around...
                                      Install the latest version of it either from the RBZ using Preferences > Extensions > Install... button, or using the SketchUcation PluginStore dialog within SketchUp...
                                      Restart SketchUp...
                                      Report results...
                                      NEVER install older versions from say v2013 Plugins or an older RBZ - get the latest versions, which are specifically updated to be v2014 compatible.
                                      Try the equivalent manual removal for any Fredo plugins, and reinstall then one at a time from their latest RBZs until you get an issue - then report back... 😕
                                      • P
                                        paul brown
                                        My installations are all the latest versions. I have deleted ALL my plugins all fredo directories and files and reinstalled just LibFredo and Fredo Scale from the extension warehouse, same result. Have enabled Sketchup to run as administrator, the default in the folder is set to full. I'll do a clean install of Sketchup 2014.
                                          Those results are expected.
                                          No issues.
                                          Are you sure you have deleted all of the Plugins from the 2104 Plugins folder 😕
                                          Delete ALL of the Fredo folders/files [again!].
                                          Restart SketchUp 2014.
                                          You should now only get the basic su_ files loading...
                                          Download the SketchUcation Plugin Store toolset...
                                          http://sketchucation.com/resources/plugin-store-download
                                          Install it using the Preferences > Extensions > Install... button...
                                          Restart SketchUp to make sure it completes the installation...
                                          Use the SketchUcation PluginStore [within SketchUp] to AutoInstall the 'Lib Fredo'...
                                          Tip: use the disalog's filters/search tools to find its AutoInstall entry.
                                          Next do the same to AutoInstall one of Fredo's plugins [like Fredo Scale].
                                          Now what happens ?
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v5.8c - 17 Apr 14
                                            LibFredo6 5.8c is a release for MoveAlong 1.0, which is just published as part of FredTools 1.8c.
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 113
                                            • 114
                                            • 39 / 114
