    [PLUGIN]MITSUBA Render Exporter v1.5.0(20141109)
    102 Posts 18 Posters 200.2k Views 18 Watching
      tak2hata
      Hi,Unclex.
      Thank for your enjoying!
      Hi,Driven.
      I tested this on macOS 10.9.1 and sketchup2014 and mitsuba render 0.5.0.
      Select Mitsuba.app as Render engine like this video.
      And,I execute "commanline-access" from mitsuba menu once before test on mac.
      This maybe connect anything working well or,not.
      I hope this help you.
      Thanks.
      by TAK2HATA
        sergonavt
        8 version in the materials editor view shows only one material (Sophi_Hair) and does not show changes ??? in render all right, version 14, everything works
          driven
          hi,
          thanks for the video, adding the symlink to /usr/bin/mitsuba hasn't made a difference.
          materials is using 'mitsuba' for the previews...
          if I update after changes...
          the serialization just isn't occurring, the file remains empty, and I get the same error message...
          'Ruby Console' indicates all is well...
          'mitsuba log' seems ok
          2014-03-17 18;06;50 DEBUG main [Thread] Spawning thread "load"
          2014-03-17 18;06;50 INFO  load [sceneloader.cpp;101] Parsing scene description from "//Applications/su_render/Mitsuba_scene.xml" ..
          2014-03-17 18;06;50 INFO  load [scenehandler.cpp;675] In file "//Applications/su_render/Mitsuba_scene.xml" (near line 2); Parsing included file "Mitsuba_geometries.xml" ..
          2014-03-17 18;06;50 INFO  load [SerializedMesh] Loading shape 0 from "mitsuba_main.serialized" ..
          2014-03-17 18;06;50 DEBUG load [Thread] Thread "load" has finished
          but I get the error...
            driven
            the log in app/contents reports my gl settup
            2014-03-17 17;42;21 INFO  main [mainwindow.cpp;80] Mitsuba version 0.5.0 (Mac OS, 64 bit), Copyright (c) 2014 Wenzel Jakob
            2014-03-17 17;42;21 INFO  main [mainwindow.cpp;83] Configured for RGB-based rendering
            2014-03-17 17;42;21 DEBUG main [NSGLSession] Initializing NSGL session
            2014-03-17 17;42;21 DEBUG main [NSGLRenderer] Using an existing NSGL context
            2014-03-17 17;42;21 DEBUG main [GLRenderer] OpenGL renderer ; ATI Radeon HD 2600 PRO OpenGL Engine
            2014-03-17 17;42;21 DEBUG main [GLRenderer] OpenGL vendor   ; ATI Technologies Inc.
            2014-03-17 17;42;21 DEBUG main [GLRenderer] OpenGL version  ; 2.1 ATI-8.24.11
            2014-03-17 17;42;21 DEBUG main [GLRenderer] Capabilities; Framebuffers objects are supported.
            2014-03-17 17;42;21 DEBUG main [GLRenderer] Capabilities; GLSL is supported.
            2014-03-17 17;42;21 DEBUG main [GLRenderer] Capabilities; Floating point textures are supported.
            2014-03-17 17;42;21 DEBUG main [GLRenderer] Capabilities; Floating point color buffers are supported.
            2014-03-17 17;42;21 DEBUG main [GLRenderer] Capabilities; Fast buffer blitting is supported.
            2014-03-17 17;42;21 INFO  main [GLRenderer] Capabilities; Multisample framebuffer objects are NOT supported!
            2014-03-17 17;42;21 DEBUG main [GLRenderer] Capabilities; Vertex buffer objects are supported.
            2014-03-17 17;42;21 DEBUG main [GLRenderer] Capabilities; Geometry shaders are supported.
            2014-03-17 17;42;21 DEBUG main [GLRenderer] Capabilities; Custom texture filtering is supported.
            2014-03-17 17;42;21 WARN  main [GLRenderer] Capabilities; Synchronization objects are NOT supported!
            2014-03-17 17;42;21 INFO  main [GLRenderer] Capabilities; Bindless rendering is NOT supported!
            I'm on OSX 10.9.2 as well... but on an older iMac
              slbaumgartner
              I'm getting much the same error as John, though the message says "near line 25" instead of the line he reported. The /Applications/su_render/mitsuba_main.serialized file has size 0.
              What can we do to help debug this?
              MacBook Pro Retina, OS X 10.9.2
              Steve
              • sadyoS Offline
                sadyo
                Mitsuba seem work fine on my Sketchup 2014-Windowc 8.1 64bit
                But,
                How to implementing the clipmap/2D object in Mitsuba ❓ ❓
                http://s1.postimg.org/jtfu9opfj/image.jpg
                it won't appear in Renderer
                  driven
                  think I found the problem, but not the solution...
                  2014-03-18 11:44:26 INFO main [converter.cpp:127] Creating directory "textures" .. Caught a critical exception: boost::filesystem::create_directory: Permission denied: "textures"
                    tak2hata
                    @driven said:
                    Hi,john.
                    Ummm...
                    I guess the problem is delay of writing file.
                    Please search "mitsuba_main.dae" in "/applications/su_render" folder.
                    Tell me that file size.
                    And Start Mitsuba and import "mitsuba_main.dae" file.
                    Is there anything displayed on mitsuba window.
                    Now "mitsuba_main.serialized" is created in that folder.and it is not zero byte.
                    Seriarized file is binary mesh file of mitsuba render.
                    Please send me your "mtsuba_main.dae" If "mitsuba_main.serialized" is zero byte.
                    I will analyze it.
                    Thanks.
                    by TAK2HATA
                      slbaumgartner
                      When I import that file, I get the attached popup dialog and the log contains the attached messages. The serialized file is then not empty and mitsuba generates a rendered scene! So the problem definitely involves getting from the dae to the serialized file. However, the rendering contains only one instance each of Components that have multiple instances in the SketchUp file. The handling of my original textured material also is weird (looks like a grainy mass of dots instead of the original wood image).
                      Steve
                      mitsuba log.txt
                        driven
                        hi
                        dae is 54kb, fails to make texture folder...
                        mitsuba_main.serialized is empty...
                        if I import the dae into mitsuba, texture folder gets made on import, but is empty...
                        mitsuba_main.serialized is 12kb
                        plugins dae imported into mitsuba
                          slbaumgartner
                          Here are the folders and contents after importing the dae. As John reported, the textures folder exists but is empty, as is the output folder.
                          steves-macbook:su_render steve$ ls -lR ./*
                          -rw-r--r-- 1 steve admin 6673 Mar 17 21:23 ./Mitsuba_geometries.xml
                          -rw-r--r-- 1 steve admin 1365 Mar 17 21:23 ./Mitsuba_scene.xml
                          -rw-r--r-- 1 steve admin 5867 Mar 17 21:23 ./mitsuba_geom.txt
                          -rw-r--r-- 1 steve admin 30488 Mar 17 21:23 ./mitsuba_main.dae
                          -rw-r--r-- 1 steve admin 903109 Mar 18 09:04 ./mitsuba_main.exr
                          -rw-r--r-- 1 steve admin 3582 Mar 18 08:55 ./mitsuba_main.serialized
                          -rw-r--r-- 1 steve admin 1620 Mar 18 08:55 ./mitsuba_main.xml
                          ./output:
                          ./preview_cash:
                          total 80
                          -rw-r--r-- 1 steve admin 39202 Mar 17 17:31 su2objmtl_default_material.png
                          ./textures:
                          ./tx_default:
                          total 8
                          -rw-r--r-- 1 steve admin 3645 Mar 17 21:23 dark_mahogany.jpg
                            driven
                            the other thing I tried was exporting a dae directly from SU...
                            filesize 202 KB
                            texture folder empty
                            serialised 11 KB
                            Sophie is facedown on the ground [I don't think she's partially happy about it...]
                            she ain't happy...
                              driven
                              here are all the files for both...
                              this is after the Misuba.app import so it has a textures folder...
                              still empty after untitled was run...
                              su_render.zip
                                tak2hata
                                Here is the Flow of exporting to mitsuba in my plugin.
                                1.Create collada mesh without materials and transformation.(for instancing)
                                2.Convert the collada mesh to serialized mesh by mtsimport tool.
                                3.Export scene information iclude materials and instancing and transformation for serialized mesh.
                                Please open "mitsuba_scene.xml" in mitsuba render ,if there is correct serialized mesh "mitsuba_main.serialized" created from "mitsuba_main.dae".
                                That will be shown all correctly.
                                Mtsimport work fine?
                                Collada file created fine?
                                Seriarize file is not zero byte?
                                by TAK2HATA
                                  driven
                                  I can trap the create_directory error by appending at line 269 in mitsuba_main.rb
                                  the serialisation never occurs from the plugin...
                                  system(commandline, ;out => ['/tmp/log.txt', 'a'], ;err => ['/tmp/log.txt', 'a'])
                                    tak2hata
                                    In my mac that occurs.
                                    Here is log.txt.
                                    2014-03-18 23;21;32.391 mtsimport[308;507] ApplePersistenceIgnoreState; Existing state will not be touched. New state will be written to /var/folders/v2/nc5st2054wvghywgtfrszpf00000gn/T/org.mitsuba.Mitsuba.savedState
                                    2014-03-18 23;21;32 INFO  main [converter.cpp;137] Beginning conversion ..
                                    2014-03-18 23;21;32 INFO  main [collada.cpp;1596] Loading "mitsuba_main.dae" ..
                                    2014-03-18 23;21;32 INFO  main [collada.cpp;1642] Importing materials ..
                                    2014-03-18 23;21;32 INFO  main [collada.cpp;1669] Importing scene ..
                                    2014-03-18 23;21;32 WARN  main [collada.cpp;1288] instance_geometry does not contain a <bind_material> element!
                                    2014-03-18 23;21;32 WARN  main [collada.cpp;615] Referenced material could not be found, substituting a diffuse BRDF.
                                    2014-03-18 23;21;32 INFO  main [collada.cpp;1680] Done, took 0.0s
                                    2014-03-18 23;21;32 INFO  main [mtsimport.cpp;156] Encountered 14 warnings -- please check the messages above for details.
                                    Finished conversion (took 60 ms)
                                    In Sketchup Ruby Console
                                    system(%Q{'/Applications/Mitsuba.app/Contents/MacOS/mtsimport' '/Applications/su_render/mitsuba_main.dae' '/Applications/su_render/mitsuba_main.xml'})
                                    this return False?
                                    by TAK2HATA
                                      driven
                                      Here is my log.txt. after 2 attempts
                                      2014-03-18 13;58;36 INFO  main [converter.cpp;127] Creating directory "textures" ..
                                      Caught a critical exception; boost;;filesystem;;create_directory; Permission denied; "textures"
                                      2014-03-18 14;22;09 INFO  main [converter.cpp;127] Creating directory "textures" ..
                                      this return False?
                                      YES it returns false
                                      and if you use this version, you get the same error as the log file in Ruby Console...
                                      %x(/Applications/Mitsuba.app/Contents/MacOS/mtsimport /Applications/su_render/mitsuba_main.dae /Applications/su_render/mitsuba_main.xml 2>&1)
                                      2014-03-18 14:42:03 INFO main [converter.cpp:127] Creating directory "textures" .. Caught a critical exception: boost::filesystem::create_directory: Permission denied: "textures"
                                        tak2hata
                                        I get this return.
                                        2014-03-18 23;58;34.268 mtsimport[472;507] ApplePersistenceIgnoreState; Existing state will not be touched. New state will be written to /var/folders/v2/nc5st2054wvghywgtfrszpf00000gn/T/org.mitsuba.Mitsuba.savedState
                                        2014-03-18 23;58;34 INFO  main [converter.cpp;137] Beginning conversion ..
                                        2014-03-18 23;58;34 INFO  main [collada.cpp;1596] Loading "mitsuba_main.dae" ..
                                        2014-03-18 23;58;34 INFO  main [collada.cpp;1642] Importing materials ..
                                        2014-03-18 23;58;34 INFO  main [collada.cpp;1669] Importing scene ..
                                        2014-03-18 23;58;34 WARN  main [collada.cpp;1288] instance_geometry does not contain a <bind_material> element!
                                        2014-03-18 23;58;34 WARN  main [collada.cpp;615] Referenced material could not be found, substituting a diffuse BRDF.
                                        2014-03-18 23;58;34 INFO  main [collada.cpp;1680] Done, took 0.0s
                                        2014-03-18 23;58;34 INFO  main [mtsimport.cpp;156] Encountered 16 warnings -- please check the messages above for details.
                                        Finished conversion (took 42 ms)
                                        Is this problem security permission?
                                        by TAK2HATA
                                          driven
                                          the problem seems to be the path from boost to the file not having the correct permissions, if that makes sense...
                                          As the folder is in the HD/Applications/ I have tried it at /tmp/, ~/Desktop, ~/Documents and in Plugins, all fail...
                                          my copy of boost lives in /usr/local/bin/include, but it's a symlink to homebrew/cellar so that my be the issue...
                                          not following symlink from ruby, I'll check it again from terminal...
                                            driven
                                            that returns
                                            dyld; Symbol not found; __cg_jpeg_resync_to_restart
                                              Referenced from; /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                              Expected in; /usr/local/lib/libJPEG.dylib
                                             in /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                            Trace/BPT trap; 5
                                            • 1 / 6
