    [PLUGIN]MITSUBA Render Exporter v1.5.0(20141109)
    102 Posts 18 Posters 200.2k Views 18 Watching
      slbaumgartner
      I'm getting much the same error as John, though the message says "near line 25" instead of the line he reported. The /Applications/su_render/mitsuba_main.serialized file has size 0.
      What can we do to help debug this?
      MacBook Pro Retina, OS X 10.9.2
      Steve
      • sadyoS Offline
        sadyo
        Mitsuba seem work fine on my Sketchup 2014-Windowc 8.1 64bit
        But,
        How to implementing the clipmap/2D object in Mitsuba ❓ ❓
        http://s1.postimg.org/jtfu9opfj/image.jpg
        it won't appear in Renderer
          driven
          think I found the problem, but not the solution...
          2014-03-18 11:44:26 INFO main [converter.cpp:127] Creating directory "textures" .. Caught a critical exception: boost::filesystem::create_directory: Permission denied: "textures"
            tak2hata
            @driven said:
            Hi,john.
            Ummm...
            I guess the problem is delay of writing file.
            Please search "mitsuba_main.dae" in "/applications/su_render" folder.
            Tell me that file size.
            And Start Mitsuba and import "mitsuba_main.dae" file.
            Is there anything displayed on mitsuba window.
            Now "mitsuba_main.serialized" is created in that folder.and it is not zero byte.
            Seriarized file is binary mesh file of mitsuba render.
            Please send me your "mtsuba_main.dae" If "mitsuba_main.serialized" is zero byte.
            I will analyze it.
            Thanks.
            by TAK2HATA
              slbaumgartner
              When I import that file, I get the attached popup dialog and the log contains the attached messages. The serialized file is then not empty and mitsuba generates a rendered scene! So the problem definitely involves getting from the dae to the serialized file. However, the rendering contains only one instance each of Components that have multiple instances in the SketchUp file. The handling of my original textured material also is weird (looks like a grainy mass of dots instead of the original wood image).
              Steve
              mitsuba log.txt
                driven
                hi
                dae is 54kb, fails to make texture folder...
                mitsuba_main.serialized is empty...
                if I import the dae into mitsuba, texture folder gets made on import, but is empty...
                mitsuba_main.serialized is 12kb
                plugins dae imported into mitsuba
                  slbaumgartner
                  Here are the folders and contents after importing the dae. As John reported, the textures folder exists but is empty, as is the output folder.
                  steves-macbook:su_render steve$ ls -lR ./*
                  -rw-r--r-- 1 steve admin 6673 Mar 17 21:23 ./Mitsuba_geometries.xml
                  -rw-r--r-- 1 steve admin 1365 Mar 17 21:23 ./Mitsuba_scene.xml
                  -rw-r--r-- 1 steve admin 5867 Mar 17 21:23 ./mitsuba_geom.txt
                  -rw-r--r-- 1 steve admin 30488 Mar 17 21:23 ./mitsuba_main.dae
                  -rw-r--r-- 1 steve admin 903109 Mar 18 09:04 ./mitsuba_main.exr
                  -rw-r--r-- 1 steve admin 3582 Mar 18 08:55 ./mitsuba_main.serialized
                  -rw-r--r-- 1 steve admin 1620 Mar 18 08:55 ./mitsuba_main.xml
                  ./output:
                  ./preview_cash:
                  total 80
                  -rw-r--r-- 1 steve admin 39202 Mar 17 17:31 su2objmtl_default_material.png
                  ./textures:
                  ./tx_default:
                  total 8
                  -rw-r--r-- 1 steve admin 3645 Mar 17 21:23 dark_mahogany.jpg
                    driven
                    the other thing I tried was exporting a dae directly from SU...
                    filesize 202 KB
                    texture folder empty
                    serialised 11 KB
                    Sophie is facedown on the ground [I don't think she's partially happy about it...]
                    she ain't happy...
                      driven
                      here are all the files for both...
                      this is after the Misuba.app import so it has a textures folder...
                      still empty after untitled was run...
                      su_render.zip
                        tak2hata
                        Here is the Flow of exporting to mitsuba in my plugin.
                        1.Create collada mesh without materials and transformation.(for instancing)
                        2.Convert the collada mesh to serialized mesh by mtsimport tool.
                        3.Export scene information iclude materials and instancing and transformation for serialized mesh.
                        Please open "mitsuba_scene.xml" in mitsuba render ,if there is correct serialized mesh "mitsuba_main.serialized" created from "mitsuba_main.dae".
                        That will be shown all correctly.
                        Mtsimport work fine?
                        Collada file created fine?
                        Seriarize file is not zero byte?
                        by TAK2HATA
                          driven
                          I can trap the create_directory error by appending at line 269 in mitsuba_main.rb
                          the serialisation never occurs from the plugin...
                          system(commandline, ;out => ['/tmp/log.txt', 'a'], ;err => ['/tmp/log.txt', 'a'])
                            tak2hata
                            In my mac that occurs.
                            Here is log.txt.
                            2014-03-18 23;21;32.391 mtsimport[308;507] ApplePersistenceIgnoreState; Existing state will not be touched. New state will be written to /var/folders/v2/nc5st2054wvghywgtfrszpf00000gn/T/org.mitsuba.Mitsuba.savedState
                            2014-03-18 23;21;32 INFO  main [converter.cpp;137] Beginning conversion ..
                            2014-03-18 23;21;32 INFO  main [collada.cpp;1596] Loading "mitsuba_main.dae" ..
                            2014-03-18 23;21;32 INFO  main [collada.cpp;1642] Importing materials ..
                            2014-03-18 23;21;32 INFO  main [collada.cpp;1669] Importing scene ..
                            2014-03-18 23;21;32 WARN  main [collada.cpp;1288] instance_geometry does not contain a <bind_material> element!
                            2014-03-18 23;21;32 WARN  main [collada.cpp;615] Referenced material could not be found, substituting a diffuse BRDF.
                            2014-03-18 23;21;32 INFO  main [collada.cpp;1680] Done, took 0.0s
                            2014-03-18 23;21;32 INFO  main [mtsimport.cpp;156] Encountered 14 warnings -- please check the messages above for details.
                            Finished conversion (took 60 ms)
                            In Sketchup Ruby Console
                            system(%Q{'/Applications/Mitsuba.app/Contents/MacOS/mtsimport' '/Applications/su_render/mitsuba_main.dae' '/Applications/su_render/mitsuba_main.xml'})
                            this return False?
                            by TAK2HATA
                              driven
                              Here is my log.txt. after 2 attempts
                              2014-03-18 13;58;36 INFO  main [converter.cpp;127] Creating directory "textures" ..
                              Caught a critical exception; boost;;filesystem;;create_directory; Permission denied; "textures"
                              2014-03-18 14;22;09 INFO  main [converter.cpp;127] Creating directory "textures" ..
                              this return False?
                              YES it returns false
                              and if you use this version, you get the same error as the log file in Ruby Console...
                              %x(/Applications/Mitsuba.app/Contents/MacOS/mtsimport /Applications/su_render/mitsuba_main.dae /Applications/su_render/mitsuba_main.xml 2>&1)
                              2014-03-18 14:42:03 INFO main [converter.cpp:127] Creating directory "textures" .. Caught a critical exception: boost::filesystem::create_directory: Permission denied: "textures"
                                tak2hata
                                I get this return.
                                2014-03-18 23;58;34.268 mtsimport[472;507] ApplePersistenceIgnoreState; Existing state will not be touched. New state will be written to /var/folders/v2/nc5st2054wvghywgtfrszpf00000gn/T/org.mitsuba.Mitsuba.savedState
                                2014-03-18 23;58;34 INFO  main [converter.cpp;137] Beginning conversion ..
                                2014-03-18 23;58;34 INFO  main [collada.cpp;1596] Loading "mitsuba_main.dae" ..
                                2014-03-18 23;58;34 INFO  main [collada.cpp;1642] Importing materials ..
                                2014-03-18 23;58;34 INFO  main [collada.cpp;1669] Importing scene ..
                                2014-03-18 23;58;34 WARN  main [collada.cpp;1288] instance_geometry does not contain a <bind_material> element!
                                2014-03-18 23;58;34 WARN  main [collada.cpp;615] Referenced material could not be found, substituting a diffuse BRDF.
                                2014-03-18 23;58;34 INFO  main [collada.cpp;1680] Done, took 0.0s
                                2014-03-18 23;58;34 INFO  main [mtsimport.cpp;156] Encountered 16 warnings -- please check the messages above for details.
                                Finished conversion (took 42 ms)
                                Is this problem security permission?
                                by TAK2HATA
                                  driven
                                  the problem seems to be the path from boost to the file not having the correct permissions, if that makes sense...
                                  As the folder is in the HD/Applications/ I have tried it at /tmp/, ~/Desktop, ~/Documents and in Plugins, all fail...
                                  my copy of boost lives in /usr/local/bin/include, but it's a symlink to homebrew/cellar so that my be the issue...
                                  not following symlink from ruby, I'll check it again from terminal...
                                    driven
                                    that returns
                                    dyld; Symbol not found; __cg_jpeg_resync_to_restart
                                      Referenced from; /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                      Expected in; /usr/local/lib/libJPEG.dylib
                                     in /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                    Trace/BPT trap; 5
                                      tak2hata
                                      @driven said:
                                      that returns
                                      > Trace/BPT trap; 5
                                      Avoiding this problem,
                                      I will write the code for serialized mesh exporter in ruby.
                                      Thanks.
                                      by TAK2HATA
                                        driven
                                        Good idea, it's probably the best long term solution...
                                        you can PM me if you want anything tested...
                                          driven
                                          I just had a thought and did some tests...
                                          commandline tool need to modify .bashrc to point to python...
                                          I don't use a .bashrc file, i use .bashprofile, so I created one under User/me/.bashrc and it's not written to...
                                          where is your .bashrc located, and exactly what does it contain??
                                            tak2hata
                                            I search in my mac.
                                            I found "bashrc" in "/private/etc"
                                            it contains this.
                                            # System-wide .bashrc file for interactive bash(1) shells.
                                            if [ -z "$PS1" ]; then
                                               return
                                            fi
                                            PS1='¥h;¥W ¥u¥$ '
                                            # Make bash check its window size after a process completes
                                            shopt -s checkwinsize
                                            # Tell the terminal about the working directory at each prompt.
                                            if [ "$TERM_PROGRAM" == "Apple_Terminal" ] && [ -z "$INSIDE_EMACS" ]; then
                                                update_terminal_cwd() {
                                                    # Identify the directory using a "file;" scheme URL,
                                                    # including the host name to disambiguate local vs.
                                                    # remote connections. Percent-escape spaces.
                                            	local SEARCH=' '
                                            	local REPLACE='%20'
                                            	local PWD_URL="file;//$HOSTNAME${PWD//$SEARCH/$REPLACE}"
                                            	printf '¥e]7;%s¥a' "$PWD_URL"
                                                PROMPT_COMMAND="update_terminal_cwd; $PROMPT_COMMAND"
                                            fi
                                            by TAK2HATA
                                            • 1 / 6
