    [Plugin] Toggle Units
    159 Posts 47 Posters 144.8k Views 47 Watching
      dtrarch
      Hi all
      I needed to add extensions.rb to plugins and edit
      toolbar_manager.html
      tustrings.en
      to correct english(engeniery) to Engineering (.en)
      Now works and spells OK 👎 👎
      Thank you Matt and what do you play ?
      dtr
        dtrarch
        Error
        • H Offline
          hygicell
          it works ! 😍
          many, many thanks jimini-billy-bob !
            Matt666
            What do I play?
            Frenglish at its best !
            My scripts
            • BoxB Offline
              I believe he is referring to this
              @matt666 said:
              Hi Pete! Thank you for your kind words..
              i don't use SU and Ruby anymore, my new job as musician doesn't need for these kind of software! 😄
              But I love programming so I will try to do something for you..
              I just have to reinstall SU!
                Matt666
                Aaaah! ^^ I am a drummer!
                My scripts
                • CadFatherC Offline
                  CadFather
                  yeah, we know the types...bad dudes! 😆
                    There was a single method (arguments) error in the extension 'loader' .rb.
                    I've corrected it to method(arguments) so it is now v2014 compliant.
                    I updated it for the PluginStore entry [v3.000]...
                    http://sketchucation.com/pluginstore?pln=Matt_Toggle_Units
                      brendanherri
                      Hello all,
                      I still have some troubles with this very usefull extension.
                      It also seems to be related to a UTF8 issue as you can see the error message below.
                      I have Win7 64bit pro. Any idea ?
                      Erreur de chargement du fichier C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb
                      Error: #<ArgumentError: invalid byte sequence in UTF-8>
                      C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:16:in split' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:16:in block in module:Toggle_Units'
                      C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:15:in each' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:15:in module:Toggle_Units'
                      C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:5:in <module:Matt_Tools>' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:4:in <top (required)>'
                      C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                      C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in register_extension' C:/Users/dell/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in <top (required)>'
                        driven
                        The language string files haven't been encoded as UFT8 and have a silly extensions [.en, .fr]...
                        it would be simpler to use .txt so people can edit their own copies.
                          Dam' - missed it - I'll look & update asap...
                            Only the FR file was wrongly encoded as ANSI !
                            The EN one worked fine...
                            The plugin's HTML file shows NO encoding at all - which is just weird !
                            It'll be fixed and an update published shortly...
                            [mod=:3i457397]Update v3.001 with correctly encoded FR file etc now in the PluginStore.
                            .[/mod:3i457397]
                              brendanherri
                              Works fine !
                              Thank you TIG, you're great.
                              Merci beaucoup.
                                jimmylomax
                                First, this extension is incredibly valuable for me. So many thanks for it! When I find things like this I feel stupid [face palm], I didn't seek it earlier... so much time wasted!
                                2nd on feature request for presets. For example, it would be amazing if I could have/make three:
                                1. decimal, mm, 0mm precision (sometimes I do my detailed work or reference other models)
                                2. decimal, in, 0.000" precision (most of the time when I'm doing detail work, this is my preference)
                                3. architectural, 0" precision (my output presentations are almost always feet and whole inches)
                                • atelierpaarA Offline
                                  atelierpaar
                                  Hello
                                  I just installed SU 2019
                                  Unfortunately i get the following errocode :
                                  Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb
                                  Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units/Toggle_Units.rb:205: Invalid return in class/module body
                                  return if not settings.include?("tr...
                                  C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
                                  C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in register_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Matt_Toggle_Units.rb:62:in <top (required)>'
                                  anyone any idee how to fix this problem ?
                                  thanks for looking into the this
                                  Uli
                                    The newer Ruby version is unsympathetic to coding errors !
                                    Using a plain-text editor, like Notepad++, edit the file:
                                    Find line #205
                                    return if not settings.include?("true")
                                    Add an initial #
                                    #return if not settings.include?("true")
                                    Save the file and restart SketchUp, to test it...
                                    Other 'returns' in the code seem OK...
                                      atelierpaar
                                      Hello and good morning,
                                      thanks TIG, that was it. What a difference a # makes !!
                                      Toggle_Units works fine again.
                                      thanks again for your quick reponse
                                      Uli
                                      • W Offline
                                        wrc86
                                        Find line #205
                                        Add an initial #
                                        Perfect TIG thanks! it worked perfect on mac SKP2019
                                          sherman23
                                          Isit possible to show a tutorial process on doing the changes for Skp 2019. in a Picture format. Thanks
                                            samyell77
                                            Find line #205
                                            Add an initial #
                                            Amazing - thanks TIG!!! (and Matt666 for the original). Was really panicking as I couldn't find an alternative to this, really great to get it working on 2019!
                                            SU Pro 2016
                                            Dell Precision M4800
                                            PC Windows 10
                                            Intel Core i7-4900MQ @ 2.80ghz
                                            Nvidia Quadro K2100M
                                            16gb RAM
                                            • 8 / 8
