    SU 2014 and Plugins
    36 Posts 16 Posters 7.0k Views 16 Watching
    • Bob JamesB
      Bob James
      @dave r said:
      Bob, see Jim's post above. If you're the only one using the plugins on your computer, use Appdata/Roaming... If you use the SCF Plugin Store or the Extension Warehouse, they'll go there automatically.
      Plugins just for your use can must go in:
      Code: Select all
      %APPDATA%/SketchUp/SketchUp 2014/SketchUp/Plugins
      This is not
      AppData**Roaming**\SketchUp\SketchUp 2014\SketchUp\Plugins
      Or am I missing the obvious?
        No. My error. Or Jim's. Here's a screen shot that might help.
          To find your default Plugins folder, in the Ruby Console use:
          Sketchup.find_support_file('Plugins')
          It should return your personal 'User' Plugins folder... e.g.
          C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
          • BoxB
            Exactly as said in the first reply to the thread.
              But you quoted what it ought to be, rather than telling him how to find what it actually is set to be... 😒
                driven
                if your prepared to use 'Ruby Console'
                copy paste this
                UI.openpanel(Sketchup.find_support_file("Plugins"))
                then hit enter...
                @TIG, maybe SCF_ could have a 'Plugins folder' menu item???
                  copy paste this
                  then hit enter...
                  Good tip.
                  Good idea... 😒
                  • I
                    ilay7k
                    I work in another 3d app. App's developers made command-console's command which points where user can have own preferences dir with such dirs: _bugreports, library, plugins, prefs, tex, updates
                    i prefer if we can select plugin-dir in preferences of sketchup or simply override it by command: sketchup.exe -userdir "X:\skippyDir"
                    • cottyC
                      cotty
                      @ilay7k said:
                      You can add folder with Fredos Additional Plugin Folders.
                      my SketchUp gallery
                      • I
                        ilay7k
                        Hi Carsten
                        Thanks for info.
                        BUT i want it will be by default and from true TSKU dev.team
                        Ok?
                        • Al HartA
                          Al Hart
                          @tig said:
                          copy paste this
                          then hit enter...
                          Good tip.
                          Good idea... 😒
                          Notice that:
                          returns the right path even if a "Plugins" folder exists in program Files, e.g.
                          C;/Program Files (x86)/SketchUp/SketchUp 2014/Plugins
                          But, if, like one of our clients, you have created a subfolder of Plugins in Program Files, such as:
                          C;/Program Files (x86)/SketchUp/SketchUp 2014/RPS
                          then
                          Sketchup.find_support_file("Plugins/RPS") returns the wrong folder - the one in Program Files when it should have found the one in AppData where we installed it.
                          (even though the client put it there, it is the wrong place)
                          I suspect this is a bug in SketchUp 2014.
                          C:/Users/alh/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Plugins/RPS
                          Al Hart
                          IRender nXt from Render Plus
                            driven
                            @al hart said:
                            ... But, if, like one of our clients, you have created a subfolder of Plugins in Program Files, such as:
                            then
                            @Al,
                            for your clients path, shouldn't it be Sketchup.find_support_file("RPS") as it doesn't include "Plugins"?
                            • Bob JamesB
                              Bob James
                              $LOAD_PATH
                              ["D:/Dropbox/Plugins",
                              "C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib",
                              "C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific", "C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools",
                              %(#FF0000)["C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins",
                              "C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins"]]
                              • Al HartA
                                Al Hart
                                @driven said:
                                @Al,
                                In my example, RPS was a subfolder in Plugins.
                                It was supposed to be in:
                                where we install it, but there was a rouge copy in:
                                because the user had either copied the SU 2013 version there, or tried to install the SU 2014 version of the plugin in the wrong place.
                                My point is that if both of these folders exist, Sketchup.find_support_file("Plugins/RPS") should only return the one in the proper Plugins folder.
                                We have solved the problem by first locating
                                Sketchup.find_support_file("Plugins") which works properly, and then verifying that
                                Sketchup.find_support_file("Plugins") + "/RPS" exists.
                                But we think that Sketchup.find_support_file("Plugins/RPS") should have found to correct file.
                                Al Hart
                                • BoxB
                                  I think the rogue copy of the plugin folder is caused by installing a plugin via a separately downloaded plugin installer getting it wrong.
                                  I downloaded and installed Twilight as the first plugin on one of my PCs then when I went to use the Plugin store to install something else it flagged the second folder and asked what I wanted to do. Either choice didn't work, so I simply removed the rogue folder manually and all was well.
                                  • emerald15E
                                    emerald15
                                    I'm not sure if this is one for Sketchucation or a Twilight forum... but here goes.
                                    I'm trying to install Twilight into SU2014 - according to the Twilight site I select the v1.5.4 specific for SU2014 and it will install automatically. However, when I open SU2014 I get this error message. The Twilight extention in checked in the system preferences window but there it no toolbar for it.
                                      @Emerald
                                      Contact Twilight - it initially looks like a problem with their installer ?
                                      • B
                                        blue442
                                        Curious, do you double click files to open them?
                                        I found that by double clicking on files to open them, some (all??) plugin's don't load correctly. However using the sketchup 2014 shortcut, then opening the file once sketchup is running all plugins work fine.
                                          @Blue442
                                          Please explain what you mean ?
                                          That doesn't sound right ??
                                          • tt_suT
                                            tt_su
                                            Yes, there is some problems is you launch SketchUp under windows via SKP files that are no on the same drive as your SketchUp installation. Some paths get messed up and the standard library doesn't load properly.
                                            However I don't think that is the case of Twilight Render, I see in the error message a reference to a .so file - which is a binary file which has to be compiled against the Ruby interpreter we ship. Since we updated the Ruby interpreter in SketchUp 2014 all plugins that use binary extensions must be updated.
