    1.5k Posts 471 Posters 3.3m Views 470 Watching
      michelleyeo
      Yes, I don't get the round corner in the list
      • jeff hammondJ Offline
        @michelleyeo said:
        Dear TIG and Oxer,
        Many thanks for your reply.
        I've installed correctly and enabled the extensions however no sign for Roundcorner.
        Please helpppp
        according to your second picture, you haven't installed it correctly.. you're missing libFredo files.
        you can get that here:
        http://sketchucation.com/forums/viewtopic.php?t=17947
        (download the .rbz version underneath the word DOWNLOAD in the first post)
        to install it, go Sketchup (menu)-> Preferences-> Extensions..
        click the 'Install Extensions' button at the bottom then navigate to the libFredo .rbz file... it will be placed in the proper location for you..
        • W Offline
          wisar
          Great tool but I am wondering if I can undo the rounded corners if I want to revisit a design and make some changes like pushing and pulling a face?
          Cheers,
          W
          • mitcorbM Offline
            mitcorb
            Hi:
            You can undo the rounded corners while in the same session, but you cannot undo the round corners tomorrow.
            If you were using Blender you could simply switch it off, because rounded corners would be a modifier "channel"(?).
            In Sketchup, do the rounding on a separate copy, group or unique component of the original geometry.
            You could then save these copies out of your working file if you wish.
              Lyubov
              Please, help me to delete plugin from SketchUp Pro 2013, after Setting plugin Fredo6_Round Corner i decieded to delete him from foulder plugins, but now after openning SketchUp I have every time notice about that I have to install this plugin...(YOU MUST INSTALL LIBFREDO6 VERSION 5.2 OR HIGHER TO RUN FREDO ROUND CORNER)... Thank you so much for helping!! 😒
              • mitcorbM Offline
                mitcorb
                Hi, Lyubov:
                Your question generates many questions.
                Please visit this thread and see if an answer is there:
                http://sketchucation.com/plugin/696-SketchUcationTools
                Fredo6's RoundCorner is a very reliable plugin and requires a helper file called Libfredo. In fact, most if not all of his tools utilize the helper file.
                See if the above helps and post back if you need further assistance.
                Someone is sure to respond.
                • frankflafyF Offline
                  frankflafy
                  is it compatible with su2014? im trying and still get error.
                    Round Corner is indeed compatible with SU2014. What error do you get? Just saying you get an error is useless.
                    Make sure you've installed the current version of Round Corner AND Libfredo6.
                      frankflafy
                      sorry i just copy paste old plugins to a new plugins folder. and i got screwed.
                      but it fixed. thanx community.
                        Frank, it has been posted all over Sketchucation that copying and pasting plugins from an older installation is not advised.
                          keramare
                          THANX again
                            Antonius43
                            Just do not understand, do I need to pay for this plugin to work? After following the instructions I cannot find the toolbar? What a waste!!!
                            • massimoM Offline
                              massimo Moderator
                              No.
                              What a waste!!!
                              Waste? this is a great and must have plugin and many people use it successfully.
                              Correct.
                                Maybe you wil be more lucky with this!
                                Now there is a sort of integration of it inside Join PusPushPull Interactive!
                                  It is free to download, install and use [but of course you are free to donate to authors]...
                                  If you have installed the Plugin properly [and how did you do that?]... then you might need to restart SketchUp and activate the it under Preferences > Extensions... and then activate its Toolbar...
                                  Also having read the Plugin's installation instructions... you will be aware that you also need to have 'LibFredo' downloaded and installed to make this work [that's free too 😉 ]
                                    synthkim1
                                    Thank u so much,,,it's amazing
                                    • Z Offline
                                      ZRaupp
                                      took me a few minutes to get it working, had to run Sketchup as administrator..
                                        Why? Where and how did you install the plugin?
                                        • Z Offline
                                          ZRaupp
                                          I installed plug-ins before i followed the steps and it works... .. ..
                                            Whatever works, I guess, but you didn't really answer the question.
                                            You shouldn't have to run SketchUp 2014 as administrator to get plugins to work unless you aren't installing them in the correct location.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 73
                                            • 74
                                            • 12 / 74
